Author |
Alpineandy |
Alpineandy World Chat Champion
Back to top |
Polarbear |
Polarbear Super Spammer
Back to top |
UncleFester |
Back to top |
Alpineandy |
Back to top |
andy-b2 |
andy-b2 Two Stroke Sniffer
Back to top |
Polarbear |
Back to top |
UncleFester |
Back to top |
arry |
arry Super Spammer
Back to top |
B5234FT |
B5234FT Brolly Dolly
Back to top |
groovylee |
groovylee World Chat Champion
Posted: 10:04 - 30 May 2017 Post subject: |
classic pug HGF.
changing the head gasket isnt toooo hard a job on these, BUT....
check to see if the head bolts are reusable or not. many recommend changing them, or suffer the consequences later.
note you will also need to remove the cambelt to do the job, factor in for a new one, and tensioner, as you may as well do that while you're there.
i would also have the water pump and thermostat housing off to flush as much of the crap out as you can, as it takes bloody ages otherwise. you will want to take the rad out and fill with hot water, before chucking some dishwasher detergent in there, and leave for a while, then back flush it until it runs clear. basically, every pat of the cooling system will be full of mayo, so get as much out as you can while you have the engine apart.
you will need new gaskets / seals for the above.
get a haynes manual. you'll need it.
otherwise, perfectly doable by a DIY home mechanic, just take your time, label everything and bag it up. take many pictures to help with cable routing, hose connections, bolt placement, etc etc.
price everything you need up from Eurocar parts, along with whatever particular discount they have available at the time, and then you can make a call on whether to do it at all.
finally, when you get the head off, look very carefully at it. my old 320 E30 cracked the head, and i almost missed it until i took it to a place for chemical cleaning........
good luck ____________________ Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R |
Back to top |
skatefreak |
Posted: 10:14 - 30 May 2017 Post subject: |
If it's 2l diesel it will have a an oil cooler.
Tbh, the 307 are so horribly sh*te I would recomend fixing and selling.
Not sure if I just got a lemon (and the rest of half the internets) but it's one thing after another with those cars and it's been an education...
The major things I've done (off the top of my head) over and above the usual wishbones/drop links/belts and pumps:
turbo @ 55k,
Duel mass flywheel & clutch at 75km (were not OEM!),
2x Injectors,
Coms 2000 unit,
Electronic hydraulic steering pump,
DPF clean x3? + pressure diff sensor,
Cam sensor,
Fuel cap sensor.
All that in 3-4 years. I've just bought a spunky 95 306 because they are just better damned cars (cost £250 & burn veg like a champ so will pay for itself with free veg in no time!)
Propper bangernomics = putting money in your pocket instead of paying for depreciation! |
Back to top |
Wonko The Sane |
Wonko The Sane World Chat Champion
Back to top |
Polarbear |
Back to top |
bugeye_bob |
Posted: 13:38 - 30 May 2017 Post subject: |
groovylee wrote: | classic pug HGF.
good luck |
a few screen shots suggest there may be some special tools required. |
Back to top |
groovylee |
Back to top |
Nb |
Nb World Chat Champion
Back to top |
RhynoCZ |
RhynoCZ Super Spammer
Back to top |
lukamon |
lukamon World Chat Champion
Posted: 23:37 - 30 May 2017 Post subject: |
how on earth do people have to do so much to their cars? i owned a 2006 mx5 from 50k to 100k in 4.5 years, and was fairly insulted when i had to replace an original headlight bulb at 95k
saying that, people dont seem to have much mechanical sympathy; guy at old workplace had a civic type r, every single day he redlined it going out the carpark, then complained about the gearbox being shit and seeing smoke behind him sometimes. ____________________ killa wrote: Im an ass man myself |
Back to top |
skatefreak |
Back to top |
arry |
arry Super Spammer
Back to top |
RhynoCZ |
Posted: 09:37 - 31 May 2017 Post subject: |
skatefreak wrote: | My old 306, glow plugs, brake discs and one brake line in 4 years (usual consumables)...
Not all cars are equal. Some are downright gobshite... |
Not to accuse OP of anything, but I'd say not all owners are equal, when it comes to maitenence and repair of their vehicles. Yes, there are some mechanical failures, that are completely random and we can't predict them, such as my father's Seat 1.9TDi dropping a valve into the engine (320K on the clock, the engine was always maitained, never had a problem).
Then there are people that hear/feel something is wrong with their car, but don't care, as the car still runs and they presume whatever the issue is, it's not worth their time nor money to fix. Then their car gives up and all they have to say about it is the car was crap.
I've seen such things, I've met such people. No mechanical sympathy, no admitance of their fault. I only wonder what would they do, if they smelled gas in their house or there was a broken pipe leaking. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Back to top |
skatefreak |
Back to top |
- Super Spammer
Back to top |
RhynoCZ |
Posted: 13:10 - 31 May 2017 Post subject: |
My brother has a 307 (petrol), it's crap even though it's in perfect working order.
I don't know if my brother's car is any special, but the materials in the interior are very poor (not cheap, but not good), the interior has next to now sound dampening (excessive road and aerodynamic noise), the suspension is typically French (too soft, not responsive) and the whole car doesn't seem alright in speeds above let's say 40mph. I can only imagine how crappy a diesel version could be, with all the extra rattle.
I know it's kind of stupid, but whenever I'm supposed to go somewhere with my brother, I always insist on taking my much older PimpMobil and pay for the petrol, rather than spending any excesive amount time in his 307. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Back to top |
M.C |
M.C Super Spammer
Posted: 13:59 - 31 May 2017 Post subject: |
Shit French cars are shit, not seeing the need for a debate |
Back to top |
The last post was made 6 years, 330 days ago. Instead of replying here, would creating a new thread be more useful? |
