| lingeringstin... |
 lingeringstin... Spanner Monkey
| rcbikeracer |
 rcbikeracer Borekit Bruiser
 Posted: 08:20 - 02 Jun 2017 Post subject: |
running two spark plugs off one coil may result in the spark taking the path of least resistance, ie the spark plug that is not under compression.  |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 09:42 - 02 Jun 2017 Post subject: |
The 360-crank Benlys do run a single trigger, single CDi or points 'lost-spark' system, with a single Siamese coil, with twin HT-Leads.
Do you have one or two CDi's?
Where I have slapped 360 motors into Super-Dreams, I have retained the twin CDi's and twin coils, and taken a single trigger signal to both from a Y connector, manly for simplicity/revertability/reliability.
Firing two plugs off a single, single winding coil, splicing the HT lead, is a bit iffy to my mind; you are a likely to get just one spark at one plug, as volts take path of least resistance, or two much weakened sparks, or no sparks, or any combination of!
Using a siamesed coil, and notion of nicking one off a four to try it, seemed reasonable; but issue of coil impedance and load on the CDi deterred me, though that's how Honda did it on the Benley's... and they seem to use the same CDi.. so a CM/CD125/200 possibly a CB Two-Ffty 'twin' coil, would probably do the job.
Not sure how much you would save over two coils, though bar having to splice a second spade to the LT feed wire off the CDi, compared to using two separate coils.. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| lingeringstin... |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 15:06 - 02 Jun 2017 Post subject: Re: sparky |
| lingeringstink wrote: | Apparently this engine is supposed to use a single CDI triggered off the alternator AC and supposedly you can push start the bike with a dead battery. |
Yup, hat sounds about right; it's a four winding mag; three windings go to the reg/rect, ignition is stand alone circuit with its own winding to power up the CDi, and an induction trigger.
The self exited ignition circuit isn't particularly beefy.. that you 'can' bump start one with a flat battery has to be kept in the masculine pedantry of 'can' being potential, in an ambiguous chronology, rather than the feminine interpretation that 'can' is an absolute commitment, of instant compliance, if not sooner, like when they ask "'Can' you paint the hallway?".. then moan, that you haven't after three years, sort of thing.
Crank needs a pretty good rpm to make the volts to make a spark, which tends to beg a fairly healthy battery and starter.. I have never tried fitting a kicker to one of mine!
What on earth is the Lucas coil off? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| lingeringstin... |
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
The last post was made 9 years, 151 days ago. Instead of replying here, would creating a new thread be more useful? |
