Brake pad wear
Shinigami
PostPosted: 11:19 - 06 Jun 2017    Post subject: Brake pad wear Reply with quote
I'm a tad confused Laughing
I put new pads on the rear of the fz6 last week and i checked them yesterday and they're severely worn down already, the caliper appears to move pretty freely, can push the piston in by hand fine.
Tested for rubbing by riding into work today without touching the rear brake and the disc is cool to the touch so no excessive rubbing (my mpg has actually increased since i cleaned the brakes and put the new pads in)
are the pads just rubbish/faulty?
Brenta sintered HH pads
Islander
PostPosted: 13:25 - 06 Jun 2017    Post subject: Reply with quote
Could you be unintentionally riding the rear brake? Check your foot position.
Shinigami
PostPosted: 13:41 - 06 Jun 2017    Post subject: Reply with quote
Had already thought of this and adjusted the pedal slightly out of easy reach and made a point of having my foot back so zero chance of accidentally touching the pedal
cb1rocket
PostPosted: 15:35 - 06 Jun 2017    Post subject: Reply with quote
photos of the disc's condiiton would help
pompousporcup...
PostPosted: 16:01 - 06 Jun 2017    Post subject: Reply with quote
Brenta is the problem. Buddy of mine had some as fronts on his cbf and they wore down so fast he almost ran them to the plate.
Use another brand. Where did you get yours? They may be fakes
Shinigami
PostPosted: 18:43 - 06 Jun 2017    Post subject: Reply with quote
bought them from wemoto, reckon i'll get back in touch with them, I can't see any reason for them to have worn down to 4mm in the space of 2 weeks, the pads these replaced certainly didn't....
Shinigami
PostPosted: 19:03 - 06 Jun 2017    Post subject: Reply with quote
holy crap, rode the bike today and checked them when i got home and they're down to about 1mm, again, disc not hot to the touch. I've put the nearly worn old ones back on as they now have more meat left on them.
Links to photos
https://drive.google.com/file/d/0B4AtRBvmYOYjX2g1Z2dkeG8tcDQ/view?usp=sharing
https://drive.google.com/file/d/0B4AtRBvmYOYjSmdyR1M2RWFSUTQ/view?usp=sharing
https://drive.google.com/file/d/0B4AtRBvmYOYjbjhRb2IzdW1qNVE/view?usp=sharing
https://drive.google.com/file/d/0B4AtRBvmYOYjNWJQZUdVQTdVYlE/view?usp=sharing
https://drive.google.com/file/d/0B4AtRBvmYOYjYjkta2RyRm94RHc/view?usp=sharing
not the first item i've had fail in rapid time from wemoto tbh, i bought these pads using credit from a clutch cable that failed within a month
Tracer1234
PostPosted: 19:06 - 06 Jun 2017    Post subject: Reply with quote
Are they made of marshmallow?
Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
Falco
PostPosted: 19:08 - 06 Jun 2017    Post subject: Reply with quote
are they wearing evenly?
I noticed my month old Brenta sintered HH bads on the rear have worn, but only on the piston side. I suspect I have been riding the rear brake just enough to gently push that pad on the disc, but not enough to bring the other one in.
That or unintentionally riding the brake evenly seem the most obvious causes.
I tell you what, mathematically, I'm having it
Shinigami
PostPosted: 19:09 - 06 Jun 2017    Post subject: Reply with quote
pics added to earlier post, both worn evenly
possibly made of marshmallows
pompousporcup...
PostPosted: 19:27 - 06 Jun 2017    Post subject: Reply with quote
My mate got his from wemoto too. It's not them. I trust wemoto and theyve not failed me yet on a part I needed. They're just shit pads and is why they're cheap...he went to EBC as I told him to and he has been fine since
Shinigami
PostPosted: 19:40 - 06 Jun 2017    Post subject: Reply with quote
they weren't cheap....they're only 3 quid cheaper than the EBC pads...and more than twice what my last pads were (which were cheapies but lasted somewhat longer than 5 days of commuting that these have lasted)
PostPosted: 20:46 - 06 Jun 2017    Post subject: Reply with quote
I would say bad pads if the old ones you have put back in don't wear as quickly.
That is stupidly bad wear. Even to wear down from inadvertently operating the brake would have the disc glowing to get that sort of wear on a good pad.
Unless your disc holes are somehow shaving the brake pad material off?
Triumph Trophy Launch Edition
pompousporcup...
PostPosted: 22:07 - 06 Jun 2017    Post subject: Reply with quote
That's a pity. I seem to remember 2 sets for the front being half the price compared to ebc.
My rear pads have done near 10k and have life left. They're ebc hh. Get those
pudder
PostPosted: 09:34 - 07 Jun 2017    Post subject: Reply with quote
OP, you haven't mistaken these for brake disks have you?
https://www.kasbahouse.com/images/11008.jpg
1993 Kawasaki AR50 (In bits) - 1984 Suzuki GP125 (Sold, but still ridden) - 1954 Matchless G3L (Being restored) - 2007 Suzuki Bandit 650
Shinigami
PostPosted: 09:43 - 07 Jun 2017    Post subject: Reply with quote
Laughing fairly sure.
At least wemoto have good CS, already had a response, sent pics over and should be sorting replacements.
skatefreak
PostPosted: 10:06 - 07 Jun 2017    Post subject: Reply with quote
TBH I have a lot of faith in weemoto. They are consistently a tad more expensive than the cheapest options of flea bay but I've not had any problems with anything yet.
That and order in the morning and often I've had it the next day!
Islander
PostPosted: 11:33 - 07 Jun 2017    Post subject: Reply with quote
That's a mind-boggling rate of wear! Shocked
Different brand this time?
cb1rocket
PostPosted: 13:52 - 07 Jun 2017    Post subject: Reply with quote
This is an odd one indeed, i had ebc fitted and they wore quickly too, so fitted some brenta pads like you and they were great.
maybe a faulty batch of pads
PostPosted: 14:27 - 07 Jun 2017    Post subject: Reply with quote
Usually I find if a brake is binding, it wears one pad more than the other. Not always the case but often.
Shinigami
PostPosted: 14:44 - 07 Jun 2017    Post subject: Reply with quote
Aye, these wore perfectly evenly which makes it more odd.
They've already dispatched a replacement pair but didn't ask if i wanted the same or not so they've sent brenta hh pads it seems, hopefully this set are fine.
Will be giving the brake a haul over the weekend anyway before I fit them to make sure all is good...and keep a close eye on them.
Shinigami
PostPosted: 18:52 - 21 Jun 2017    Post subject: Reply with quote
soooo....received the replacements (direct replacements, different batch number)
guess what....gone in a week again...this is after completely rebuilding my rear caliper, again disc isn't hot to the touch after a ride.
Decided either something seriously shitty with the brenta pads or my disc is fooked.
Got some cheap as hell kyoto pads to do a comparison with the brentas...3 days in and the kyotos have pretty much not worn at all.. i'll take pics at end of the week of the two sets to compare
Islander
PostPosted: 19:30 - 21 Jun 2017    Post subject: Reply with quote
Sounds like a bad batch of pads.
Shinigami
PostPosted: 14:52 - 05 Jul 2017    Post subject: Reply with quote
Contacted wemoto again who are crediting me the cost and raising issue with brenta, did a side by side test same miles/route with the brenta and a set of Kyoto pads, the brenta pads were nearly down to the bone after 5 days, the Kyoto have next to no wear on them
PostPosted: 15:29 - 05 Jul 2017    Post subject: Reply with quote
That's pretty shocking.
I went through a set of EBC pads in under 2000 miles, and I'm not a heavy braker.
Other people swear by them though.
My working theory is that every fecker is just randomly slapping pads together and not caring about consistent quality control.
The last post was made 6 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.59 - MySQL Queries: 17 - Page Size: 133.87 Kb
