DVLA Registration
womble7
PostPosted: 23:38 - 17 Jun 2017    Post subject: DVLA Registration Reply with quote
Not sure what to do after doing some reading on the internet so I am after as much advice as possible.
I have a complete imported bike which has been cleared by customs and they are satisfied that all VAT and duty has been correctly accounted for, but this was done a couple of years ago and the bike is not yet registered with DVLA
I also have a UK frame with a V5 for the same model of bike.
Would it be easier to register the imported bike with DVLA or can i put everything onto the UK registered frame and just do a change of engine with DVLA?
I have read that if i register the imported bike then I need to insure it which i do not want to do yet as i dont want it on the road for a few months yet
PostPosted: 03:31 - 18 Jun 2017    Post subject: Reply with quote
Would I inform them of the engine change... No.
I'd use the registered frame though.
Stalk
PostPosted: 07:31 - 18 Jun 2017    Post subject: Reply with quote
No different to reframing a UK bike, and why not tell dvla about the engine number change? Been there, done that, no problems at all. And the numbers match the log book.
womble7
PostPosted: 08:09 - 18 Jun 2017    Post subject: Reply with quote
Changing everything over to the uk frame certainly seems like the easiest option but will dvla ask for any paperwork for the engine? When I change it on the v5?
PostPosted: 08:21 - 18 Jun 2017    Post subject: Reply with quote
No, just make sure it is engine from that bike and cc is same.
I never notified them of it, 3 times.
ThatDippyTwat
PostPosted: 08:39 - 18 Jun 2017    Post subject: Reply with quote
I did notify them of it. They wanted proof, I sent them a print of the ebay listing. New number on V5. Find a listing maybe?
Bru
PostPosted: 08:50 - 18 Jun 2017    Post subject: Reply with quote
Hi.
MOT inspector can check the engine number against the V5, and call you on it. This leads to a VOSA inspection, before the V5 can be updated and the bike made legit. This happened to me several years ago. The good old days of just submitting a change form to the DVLA are over.
Shaft
PostPosted: 10:53 - 18 Jun 2017    Post subject: Reply with quote
Bru wrote:
Hi.
Nope.
Engine number does not form part of the MOT test, we don't look at it, compare it, or report it, it's not on the radar in any way.
The only numbers we are interested in are the VIN and the index and there are circumstances where a vehicle can be tested with no number plate, so then it's just the VIN we look at.
If you had a problem with a number, it would be the VIN either being illegible, or partially/totally missing.
Suntan Sid
PostPosted: 11:22 - 18 Jun 2017    Post subject: Reply with quote
As a matter of interest, what happens, if on an older bike, with the VIN stamped into the frame, if the number has deteriorated and has become unreadable, can you have it, officially, reinstated?
The reason I ask is, on my 30+ year old traillie the frame has been powder coated, I had to scrape this away to reveal the VIN, which is not pristine because the frame had been blasted before the powder coating.
Shaft
PostPosted: 11:37 - 18 Jun 2017    Post subject: Reply with quote
When you input the details at the start of the test, it asks for the index and the last six digits of the VIN, then compares your input with the database - if there is a discrepancy, it won't let you proceed.
If you were to reinstate your VIN, eg with a Dremel, providing it matches the existing information, you're all good.
I should also add that a VIN is only required on vehicles used after 01/08/1999, so you don't need to worry about it at all.
It's not an MOT tester's place to report 'iffy' VINs, if it all matches up, that's it.
As an example, I used to test a 7/11 where the VIN consisted of six digits, applied to the frame with hand punches - it matched the database, so I had no option but to pass it.
Suntan Sid
PostPosted: 11:49 - 18 Jun 2017    Post subject: Reply with quote
Thanks for the reply.
This is not aimed at you, but it makes you realise how easy it would be to 'ring' a bike!
Shaft
PostPosted: 11:58 - 18 Jun 2017    Post subject: Reply with quote
If you have the information lodged on the database, then it's a piece of piss.
It's something I've always felt a bit uncomfortable about, but then we aren't the Police and if I refused to test a bike on a point of principle, no doubt the bloke down the road would test it, so I might as well take the money and run.
Bru
PostPosted: 14:37 - 18 Jun 2017    Post subject: Reply with quote
Shaft:
Heck, you are quite correct! I combined two experiences: a frame number which did not match that on the V5 (turned out to be a unnecessary prefix on the V5, which did require a VOSA inspection), and the small problem of 'proving' that my engine change was legit.
Sorry for the confusion.
Monkeywrenche...
PostPosted: 00:32 - 19 Jun 2017    Post subject: Reply with quote
As a small point, the numbers on the vehicle don't need to match the Database. If the Vin you enter doesn't match it'll ask again if you tell it the same number it will prompt you to make an entirely new entry to test the vehicle.
Then the owner will be issued with a certificate for the Registration and VIN you entered, then a whole process kicks in where they contact the keeper of the registration with 2 vins logged against it to check which is correct.
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
The last post was made 9 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.31 Sec - Server Load: 2.29 - MySQL Queries: 16 - Page Size: 87.76 Kb
