Author |
Tigerlea |
Tigerlea Nitrous Nuisance
Posted: 10:50 - 19 Jun 2017 Post subject: Stripped round-head bolt underside of bike |
Right, as subject says, I've got a stripped bolt with a rounded head so plyers, grips, etc. aren't grabbing it. It's tiny. I was attempting to remove the [ill]legal license plate holder and put on the correct one, since I had the tools out to fix the gearshift and brake. There were three bolts which needed removing, and two came away happily, the third is hanging on for dear life to the point that I thought I had gotten it to unscrew (finally) but turns out it just stripped the inside of the bolt. Ensue anger and attempting every other way of removing I know – lubing it, grabbing it with other tools, using a larger size.. nothing is working.
Have checked forums and le Google, but all tips and tricks are the same as I've already tried, short of sheering off the head with tools I don't have.
Is there, by chance, any other suggestions on how to get this thing to move?! I even tried to wiggle the entire casing in case that loosened the bolt and it just won't budge.. |
Back to top |
bamt |
bamt World Chat Champion
Back to top |
rpsmith79 |
rpsmith79 World Chat Champion
Posted: 11:48 - 19 Jun 2017 Post subject: |
I'm guessing you are taking about a hex headed bolt, and you have rounded off the hexagon hole so that the hex/allen key is just spinning
Way to remove it all depend on what it's attached too/screwed into as stated above, but what we do in our fitting shop at work when we round them off (far to regularly) is to take a hammer and sharp punch, place the punch around the out edge and try to tap the thing round, 9 times out of 10 this works, failing that, get your drill out, at least you have a decent starting hole to go off ____________________ Current Bike: Honda CG125 ES4 // Honda CB600FS Hornet // Triumph Street Triple R |
Back to top |
Tigerlea |
Back to top |
bugeye_bob |
bugeye_bob World Chat Champion
Back to top |
ADSrox0r |
ADSrox0r World Chat Champion
Back to top |
Tigerlea |
Back to top |
fatjames |
fatjames World Chat Champion
Back to top |
bugeye_bob |
Back to top |
RhynoCZ |
RhynoCZ Super Spammer
Posted: 12:57 - 20 Jun 2017 Post subject: |
A lot of plastic stuff around and under it. I would cut a straight groove in it and use a screwdriver to get it out. I've done such thing when removing a timing belt cover on my mate's car and the bolts were as fecked as this one is. I didn't want to smash a larger bit there, as there was no space for that.
Either way, if you manage to get it out, buy a new screw!
Also, word of wisdom, always clean the Allen key screw heads, before you insert the Allen key. What you've got there, is possibly a result of a not seated properly Allen key. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
Back to top |
ADSrox0r |
Back to top |
rpsmith79 |
Posted: 14:39 - 20 Jun 2017 Post subject: |
That's a new one on me, never seen an impact screwdriver like that before, looks like a handy piece of kit though ____________________ Current Bike: Honda CG125 ES4 // Honda CB600FS Hornet // Triumph Street Triple R |
Back to top |
Pete. |
Pete. Super Spammer
Posted: 15:29 - 20 Jun 2017 Post subject: |
That's the original type impact driver. Very hand tool but a bit of a knack to using them well and you need to be confident with the hammer. ____________________ a.k.a 'Geri'
132.9mph off and walked away. Gear is good, gear is good, gear is very very good |
Back to top |
RhynoCZ |
Back to top |
kramdra |
kramdra World Chat Champion
Back to top |
RhynoCZ |
Back to top |
Tigerlea |
Posted: 11:09 - 03 Jul 2017 Post subject: |
Update...
Had it's MOT on Saturday – didn't realise it was due so ended up making friendly with a local garage to get it in last minute. Was told the bike would fail on the spot for the license plate. (Oh, joy)
Folks at the garage were super nice and replaced the plate for me.
Bolt is still in place.. So still want to remove it... but as it's currently got the legal plate on I've this opinion of "but... I'd rather be riding!"
When I feel like pulling out the tools and not being on the bike I'lll use the suggestions you guys gave me in the following order:
- torx bit
- straight groove
- melt the damn thing out
Cheers for the advice. Apologies for being a lazy git. With the weather as it's been I've been out and enjoying the ride rather than squatting on the ground dealing with the bolt... |
Back to top |
Hong Kong Phooey |
Hong Kong Phooey World Chat Champion
Posted: 13:59 - 03 Jul 2017 Post subject: |
RhynoCZ wrote: | A lot of plastic stuff around and under it. I would cut a straight groove in it and use a screwdriver to get it out. I've done such thing when removing a timing belt cover on my mate's car and the bolts were as fecked as this one is. I didn't want to smash a larger bit there, as there was no space for that.
https://cdn.bcf.44bytes.net/files/cut.png
Ah the old hexagon pentagon switcheroo, gets me everytime ____________________
Back to top |
Pigeon |
Pigeon World Chat Champion
Back to top |
The last post was made 6 years, 291 days ago. Instead of replying here, would creating a new thread be more useful? |
