YBR125 07 (FI) Stator - Repair / Replacement?
Mazo
PostPosted: 11:49 - 22 Jun 2017    Post subject: YBR125 07 (FI) Stator - Repair / Replacement? Reply with quote
Well, it looks like the stator on my bike has failed. Wildly varying voltages across all three phases (70v, 50v, 40v) @ ~5000rpm and the battery is no longer charging (voltage output too low). Resistance between all three pins is 0.9-1.0 ohm.
Regulator looks OK from what I can tell. ~0.5v one way on the diode tests in the correct directions, nothing the wrong way around.
As far as I'm aware the fuel injected models have a different stator with 18 windings (though I've not opened mine yet to check!), compared to the carbed versions with far less and a different plug.
The stator in this image has the same 3 pin plug as my bike:
https://i.imgur.com/D8if5Rt.jpg
Does anyone know of decent places to get it reconditioned? I assume this will be much cheaper than a replacement unless used, but those seem to be hard to find.
WD Forte
PostPosted: 12:17 - 22 Jun 2017    Post subject: Reply with quote
Whats the resistance between the pins and ground?
bikers smell of wee
Mazo
PostPosted: 12:41 - 22 Jun 2017    Post subject: Reply with quote
Infinite, no continuity to ground from any of the stator pins.
PostPosted: 13:12 - 22 Jun 2017    Post subject: Reply with quote
https://www.westcountrywindings.co.uk/
Is what most people on here suggest, I haven't used them myself.
Nearly new one here for £95
https://www.ebay.co.uk/itm/Yamaha-YBR-125-ED-2016-Stator-Assembly-/162547270961?epid=648138954&hash=item25d8928531:g:uisAAOSwx2dYDIzV
Mazo
PostPosted: 14:55 - 22 Jun 2017    Post subject: Reply with quote
Did see that one on ebay, but not sure if a 2016 will be different (especially since there was a facelift model in 2010).
Gave west country windings a ring earlier, £126 for reconditioning
Rang Electrex World and they don't do them for the YBR125 - but they pointed me towards bbbikeshop.co.uk which will exchange for £75, so that's sounding like the best option so far unless one pops up on ebay shortly.
PostPosted: 16:43 - 22 Jun 2017    Post subject: Reply with quote
I checked the part numbers for the 2014 model (2016 numbers not on the websites) are different but it superceeds the 2007 part.
STATOR ASSSY
3D9H141012
Replaces 3D9-H1410-10
The last post was made 6 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.5 - MySQL Queries: 17 - Page Size: 51.21 Kb
