Author |
Oldie |
Oldie Brolly Dolly
Posted: 21:18 - 05 Jul 2017 Post subject: Stuff that is worth buying |
Thought that I'd put together a very short list of things that have impressed me, all bike related of course, and are worth having for that time when you really need something that actually works. I wouldn't be surprised if most folk on here already use them but, hey ho....just passing the time.
I've deliberately kept it short so that others can give their own thoughts as I'm always interested to see what else is out there. Thanks.
Polish
HybridX Ultima – brings up a really superb gloss which repels water like nobody's business. So easy to apply and last a fair old time too. They have an assortment of these hydrophobic? treatments (all nano technology apparently) and it's definitely not snake oil. Makes washing the bike a doddle.
Corrosion Protection
Dynax UC is a spray on wax, ideal for keeping your classic bike pristine. Never used it on my daily ride but I guess it's easily as good as ACF50, FS365 etc.
Cleaning Solution
I still think that Sdoc100 is the best. I've tried over a dozen different solutions and keep coming back to this. Best applied partly diluted with a brush. Keeps your bike like new. HybridX also do a great cleaner but I think that it's more expensive.
Disc Protector
AHB Disc Protector - Now, this stuff actually works, but it's only really useful before winterising your bike, especially if you live up in the tundra. Spray it on your discs and they'll stay shiny. They say that it doesn't affect the pads.
Grease
Well there's loads of different types, but Fuchs Red Rubber grease is what you want for your brake pistons.
Fuel Stabiliser
I've found that the Lucas stuff you get on ebay is, by far, the most economical. I guess that's only important if you have loads of bikes (like me) but every penny counts!
Tools
The Halfords Professional series is great value and probably everyone has one of their sets. I particularly like the small 1/4” socket set which is usually available in the sales for £25, or less. It's just so versatile.
Whilst you've got your wallet out, get on ebay and buy a spring puller – one day you'll need it (might be years from now, but you'll need it).
Oh, and if you don't have it already, get some Penetrating Oil – so many uses it will amaze you. |
Back to top |
Howling Terror |
Howling Terror Super Spammer
Back to top |
Polarbear |
Polarbear Super Spammer
Back to top |
Hawkeye1250FA |
Hawkeye1250FA World Chat Champion
Posted: 23:03 - 05 Jul 2017 Post subject: |
____________________ 1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA |
Back to top |
Beehive Bedlam |
Beehive Bedlam World Chat Champion
Back to top |
stevo as b4 |
Back to top |
Raffles |
Raffles World Chat Champion
Back to top |
RhynoCZ |
RhynoCZ Super Spammer
Posted: 23:25 - 05 Jul 2017 Post subject: |
I have never used a fuel stabiliser.
I'm gonna add:
Lidl W5 chain cleaner (it's cheap, expensive stuff does the job as well)
I use it as a multi purpose degreaser (doesn't eat rubber nor plastics) and for the chain as well.
Lidl W5 chain spray (it's cheap, expensive stuff does the job as well)
I use it as a multi purpose lube (where grease would not work or wouldn't be reasonable) and for the chain as well.
Contactol and Dielectric grease
Contactol (not sure if it's called the same in the UK, it's a spray can with cleaner and lubricant for electric stuff) = a thing I use to clean and ''lubricate'' electrical contacts. Just spraying a switch and moving it back and forth fixes the issue. * When I was prepparing the MZ for MOT, the day I went to the MOT place my left turn signals were not working. I just sprayed the switch with the contactol, moved it left and right a couple of times and it worked = MOT passed. I didn't even have to take anything apart. Yes, it's that good!
Dielectric grease = a similar thing but in a grease form (not meant for switches), mostly used on the ground points and battery terminals. Also great under the spark plug caps, it keeps the moisture out.
Oxidation and corrosion of electrical connections is the main reason of the most electrical trouble, putting unnecessary stress on your charging and electrical system. Corroded ground points and battery terminals also lead to various issues, even electric things burning on your bike/car.
Such oxidation/corrosion can even start a fire.
Copper grease + multi purpose grease
I don't even have to explain this one, do I?
Copper for everything, that gets hot while operating (the grease burns off and leaves a thin copper layer, that's very slippery)
Multi purpose grease, for the rest of it (it's significantly cheaper than the copper grease)
Multimeter
+ learn how to use it. The amount of times people came here and started with, my bike didn't run so I changed the battery, reg/rec and so on and that didn't help, is ridiculous!
Tyre pressure gauge
When will people learn?!
Caliper (a very precise measuring device)
A cheap netbook or a smartphone with internet connection
Youbook and interwebz are your mate, study things before you break them.
BCF membership ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
Back to top |
Chuffin Nora |
Chuffin Nora World Chat Champion
Posted: 04:18 - 06 Jul 2017 Post subject: |
Back to top |
iooi |
iooi Super Spammer
Back to top |
RhynoCZ |
Posted: 10:06 - 06 Jul 2017 Post subject: |
I thought we were over this. Once again, me foreigner, me English no well. You being smart suggests, you obviously know what I mean when I say ''caliper''. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Back to top |
The last post was made 6 years, 295 days ago. Instead of replying here, would creating a new thread be more useful? |
