Author |
lingeringstin... |
lingeringstin... Trackday Trickster
Back to top |
A100man |
A100man World Chat Champion
Back to top |
stinkwheel |
Posted: 23:51 - 06 Jul 2017 Post subject: |
Valves and compression no.
My limited understanding of such things is that having a longer stroke length than the engine they're designed for increases the chances of the piston canting over at TDC and BDC, causing the skirt to broach the oil layer and rub directly on the barrel.
This is why longer stroke engines tend to have longer piston skirts.
I could of course be entirely wrong in this understanding as it's tentative at best. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
chickenstrip |
chickenstrip Super Spammer
Posted: 23:54 - 06 Jul 2017 Post subject: |
stinkwheel wrote: |
Wouldn't a longer rod put less side load on the piston, which I would have thought would be desirable with a shorter skirt? ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
Back to top |
stinkwheel |
Back to top |
........ Borekit Bruiser
Back to top |
Commuter_Tim |
Back to top |
lingeringstin... |
Posted: 16:43 - 07 Jul 2017 Post subject: |
To my way of thinking there shouldn't be any real disadvantage to having a shorter piston so long as the crown height stays the same. The gudgeon pin is the pivot point and as far as I can see if it's in the same location then there really shouldn't be THAT much difference if the piston skirt was shorter by a little bit. I doubt the lateral forces of a few mm difference in rod length would be enough to cause any problems.
The whole point of this exercise is to fit the biggest bore pistons I can safely get into the bored out liner. It looks to me like the liner can be safely bored out to about 60mm or a bit more and there aren't any standard oversized pistons that big, so I've been looking at pistons for other things and have found a few that look like they might work.
The standard pistons for this barrel have slightly recessed crowns and are about 53mm diameter and 47.2mm top to bottom at the longest part. The other pistons seem to be flat top and come is sizes ranging from 57mm on up to too big for the liner so there's plenty of choice.
Standard piston, recessed top, about 47mm tall
https://s14.postimg.org/7go661bj5/piston.jpg
Shorter piston, flat top, about 43mm
https://s16.postimg.org/3utk6n9xh/exhibit_A.jpg
Longer piston, flat top, about 49mm
https://s17.postimg.org/65lvkgc27/exhibit_B.jpg
Using a longer piston might mean shortening the skirt a bit but I don't see that as a problem. I've done similar things in two stroke engines and it worked. Since four stroke pistons run in solid liners without ports I don't really see a problem running a piston a few mm one way or the other so long as it doesn't bottom out.
I'm sure it will work. The thing is, I can't find any information anywhere about anybody doing this to one of these Honda clone engines. Surely SOMEBODY besides me has wanted to stuff bigger pistons into a Benly? |
Back to top |
stevo as b4 |
Back to top |
The last post was made 6 years, 295 days ago. Instead of replying here, would creating a new thread be more useful? |
