FZS 600 - Not starting.
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3  Next
DRZ4Hunned
PostPosted: 15:01 - 15 Jul 2017    Post subject: Reply with quote
Can I have your old engine when you get rid, I had a sideways crash into a lorry a few weeks ago and smashed loads of my engine casings Laughing
DRZ400-SM
FZS600
Chris45
PostPosted: 15:32 - 15 Jul 2017    Post subject: Reply with quote
If it died that quick very likely to be an electrical issue. Check all the earth connectors and wiring is in good nick, no oxidized connectors etc. Double check the alternator/rectifier.
Hope this helps.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
arry
PostPosted: 15:36 - 15 Jul 2017    Post subject: Reply with quote
Compression test it; once results back we can go from there.
arry
PostPosted: 16:09 - 15 Jul 2017    Post subject: Reply with quote
It's the only way you'll know for sure. Going to need one in future anyway, so may as well grab one now. They're not massively expensive.
PostPosted: 16:16 - 15 Jul 2017    Post subject: Reply with quote
Is the fuel pump ticking when you switch it on?
Triumph Trophy Launch Edition
MCN
PostPosted: 17:18 - 15 Jul 2017    Post subject: Reply with quote
You need a BIG FAT BLUE-ISH spark or GTFO.
A watery yellow/orange fizz will not ignight fuel when under compressive forces.
If compression is so bad then the engine will turn over very fast and run on a little when you let go the fire button.
And compression in All Four Cylinders is unlikely to drop-off all of a sudden.
Possible one or two if a couple of valves have been bent.
PostPosted: 19:58 - 15 Jul 2017    Post subject: Reply with quote
If I was feeling a bit butcherish I'd spray some easy start into the carbs/airbox. If it fires it's not electrical and almost certainly fuel related.
Which is what I would think if you have been continuously trying to start it with choke on and can't smell fuel.
However I take no responsibility if you try this at home.
andym
PostPosted: 20:20 - 15 Jul 2017    Post subject: Reply with quote
Fazer The Bastard wrote:
https://i.imgur.com/Q1OVIrH.jpg
https://i.imgur.com/j0FcwWO.jpg
Trim your nails ya clatty bastard.... that's fuckin' mingin'
kramdra
PostPosted: 22:13 - 15 Jul 2017    Post subject: Re: FZS 600 - Not starting. Reply with quote
Is it worth the cost? You can ebay it and get a runner for not much more. It will still be a fzr6, least reliable and ugliest bike on bcf.
46k on your last mot, 70 seems unlikely in a couple of months.
kramdra
PostPosted: 23:20 - 15 Jul 2017    Post subject: Reply with quote
Was that 2015-2016 when the milage doubled? Laughing
RhynoCZ
PostPosted: 23:36 - 15 Jul 2017    Post subject: Reply with quote
Just an idea, since you had the head off. Did you put all the leads where they were before? I mean from coils to plugs. If you swap them around the bike won't start, as you mess up the firing order. Thumbs Up
Question Pulled the plugs which were wet not sure if it was petrol or oil.
Oil does not evaporate.
RhynoCZ
PostPosted: 00:00 - 16 Jul 2017    Post subject: Reply with quote
Yet another idea, how do your spark plug caps look? Any cracks, rust inside...? Cracks would let the spark jump/arch to the engine; rust isn't a good conductor.
I would also try to find any loose connection under the tank, you've had quite an adventure under there.
If it's carbureted, unplug the feed hose and fill the carbs via that.
If it's DFi, do as lads say, spray some ether (starter spray) into the airbox/intake.
Next thing to do would be the compression test.
As it ran before, I won't question your ability to do the valve clearances (you had the head off, you could have mixed up the shims)
yen_powell
PostPosted: 07:15 - 16 Jul 2017    Post subject: Re: FZS 600 - Not starting. Reply with quote
Then I'll buy an ugly MT10 and hold my crown for owning the ugliest bike on BCF.
Dream on....I've got a Versys.
XT1200Z and a DR350 in bits
andym
PostPosted: 11:56 - 16 Jul 2017    Post subject: Reply with quote
Oh, that doesn't sound good..... I've had a couple of engines that sounded like that in the past and sorted them. I COULD tell you what I done to sort them, but because you're a wee c**t I'll let you figure it out on your own (or when someone tells you, ya ungrateful little shit)
arry
PostPosted: 12:08 - 16 Jul 2017    Post subject: Reply with quote
It's difficult to say for sure but sounds low on compression.
Kawasaki Jimbo
PostPosted: 12:11 - 16 Jul 2017    Post subject: Reply with quote
Switch to reserve and try again. It happened to me.
The last post was made 6 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.75 - MySQL Queries: 17 - Page Size: 138.77 Kb
