FZS 600 - Not starting.
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2, 3  Next
Chris45
PostPosted: 12:24 - 16 Jul 2017    Post subject: Reply with quote
Shouldn't be popping when turning over like that, so reckon there is something more serious going on there. Also reckon you're wasting battery energy and starter motor effort. Time to begin the process of elimination and it's gonna take time.
1. Begin with the simple stuff. Check every electrical connector and test if appropriate. Have already mentioned rectifier/alternator. Are you getting lights, indicators, everything else okay?
2. Check all the air intake side and connectors are good and tight (no air leaks into the cylinders). Popping could be a symptom of timing out and/or weak mixture.
If no result from the above, time to get the spanners out. Pain in the arse I know but you've got a good garage there m8.
Let us know what the outcome is please.
Chris
Inverness.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
arry
PostPosted: 12:54 - 16 Jul 2017    Post subject: Reply with quote
His mum says thanks.
kramdra
PostPosted: 13:36 - 16 Jul 2017    Post subject: Reply with quote
Timing is off? ill admit very little experince with that.
Easy start rules out fuel or air leaks.
Even with bodged head gasket, compression is not going to disapear overnight on all 4. It would still run with lowish compression.
Tankie
PostPosted: 14:13 - 16 Jul 2017    Post subject: Reply with quote
IT's spark or fuel, so check the power to the ignition, if you spray a bit of brake cleaner up the intake and it pops and bangs then it will prove fuel starvation
MCN
PostPosted: 16:08 - 16 Jul 2017    Post subject: Reply with quote
Chris
Inverness.
Ether stating aid pre-ignites as it has a very low point of ignition. (That's why it is used to start stubborn engines).
That is what the popping sound will be.
PostPosted: 17:00 - 16 Jul 2017    Post subject: Reply with quote
Squirting a good dollop of easy start into the air intakes should get it to run for a few seconds even with no fuel. If it isn't doing that, then it's electric. Spark? Timing? Coils?
I suppose it could be low compression but the chances of all four cylinders passing the point of fuckedness at the same time?
Triumph Trophy Launch Edition
Petemate
PostPosted: 17:32 - 16 Jul 2017    Post subject: Reply with quote
arry wrote:
It's difficult to say for sure but sounds low on compression.
2 on this - I was about to post when I read that someone else suspected the same.
82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth
Petemate
PostPosted: 17:33 - 16 Jul 2017    Post subject: Reply with quote
From what Fazer said regarding the head gasket, my money is on just that. All four failing on compression. Sounds just like that to me.
arry
PostPosted: 19:05 - 16 Jul 2017    Post subject: Reply with quote
Only needs to be blowing across 2 and you'd have a non starter.
kramdra
PostPosted: 20:53 - 16 Jul 2017    Post subject: Reply with quote
had same issue, smashed up a spare plug and soldered it to the adaptor.
Compression tester is nothing more than a 250psi pressure guage, button-release-check valve, some hose and adaotors. Easy to bodge something together..
Raffles
PostPosted: 21:05 - 16 Jul 2017    Post subject: Reply with quote
Fazer The Bastard wrote:
Regarding the compression tester I can't find one with an M16 fitting....
Why don't you try searching for an M10 x 1.0 instead?
Raffles
PostPosted: 21:41 - 16 Jul 2017    Post subject: Reply with quote
Spark plug is 16mm so I thought I needed an M16 adaptor?
You must have a one off Fazer.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:53 - 16 Jul 2017    Post subject: Reply with quote
We can only hope....
Sprint ST 1050
RhynoCZ
PostPosted: 22:56 - 16 Jul 2017    Post subject: Reply with quote
Just an idea, did you torque down the head properly? Is there any oil in the coolant and vice versa? Did you put a head gasket there? Thinking
This is BCF, it just has got to be something silly.
Tracer1234
PostPosted: 23:51 - 16 Jul 2017    Post subject: Reply with quote
Using fairy liquid to clean your bike. I think there lies your problem.
Happy to help. Thumbs Up
Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
pompousporcup...
PostPosted: 11:17 - 17 Jul 2017    Post subject: Reply with quote
have the little spade clips come off the coils by any chance? It would turn over like in your vid but without spark on all 4 it isn't going to go.
redeem ouzzer
PostPosted: 12:56 - 17 Jul 2017    Post subject: Reply with quote
No one of the first things I did was give them a clean with WD40 along with the female connectors.
I hope it's fucked you sociopathic cunt Middle Finger
Be a REAL MAN!
The last post was made 6 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.88 - MySQL Queries: 17 - Page Size: 136.46 Kb
