Stainless Drain Bolt
Mark65
PostPosted: 19:33 - 16 Jul 2017    Post subject: Stainless Drain Bolt Reply with quote
My coolant drain plug on the front of my engine gets hit with water and crap it seems even with the Fenda Extenda and was looking rusty even though it always has ACF50 on, I have changed it for a stainless bolt today and wondered if it would cause any corrosion problems?. I was thinking it shouldn't as its the fancy coolant that is supposed to work with all metals?.
Thanks
Pete.
PostPosted: 20:20 - 16 Jul 2017    Post subject: Reply with quote
Mostly, no. Some stainless grades are superbly resistant to corrosion (and equally difficult to machine) but most of the 300 series will work fine as a drain plug and should never tarnish. It's probably 303 stainless because that's easy to machine.
a.k.a 'Geri'
dansp1
PostPosted: 21:15 - 16 Jul 2017    Post subject: Reply with quote
https://en.wikipedia.org/wiki/Galvanic_corrosion
Johnnythefox
PostPosted: 21:29 - 16 Jul 2017    Post subject: Reply with quote
Could try one of the plastic/nylon reusable type? no rust...
Mark65
PostPosted: 21:45 - 16 Jul 2017    Post subject: Reply with quote
Bolt has A2 on it, thanks
Commuter_Tim
PostPosted: 22:17 - 16 Jul 2017    Post subject: Reply with quote
Leave the bolt loose, then the dripping oil will prevent rust. Thumbs Up
DISCLAIMER: This may or may not be terrible advice.
I ride a Bandit 600... badly.
Raffles
PostPosted: 22:26 - 16 Jul 2017    Post subject: Re: Stainless Drain Bolt Reply with quote
A smear of COPASLIP or a wrap of PTFE tape around the thread should reduce the likelihood of any problems.
kramdra
PostPosted: 23:44 - 16 Jul 2017    Post subject: Reply with quote
Threadlock is very good preventing corrosion, I use it on a lot of bolts where it is not specified.
mentalboy
PostPosted: 03:40 - 17 Jul 2017    Post subject: Reply with quote
This was my first thought. Aluminium and Stainless are poor bedfellows.
Are most sump plugs not usually steel plated with Chromium, Brass, etc?
Make mine a Corona.
MCN
PostPosted: 16:18 - 17 Jul 2017    Post subject: Re: Stainless Drain Bolt Reply with quote
Copper and SS are not a god mix due to Galvanic effect.
SS needs moly as a lube.
Thread lock or PTFE paste will work OK.
Or paint a standard steel/iron plug with plenty of rust-proof paint.
tom_e
PostPosted: 12:42 - 18 Jul 2017    Post subject: Reply with quote
If there's oil dripping from your coolant drain plug you've got bigger issues than some corrosion.
Commuter_Tim
PostPosted: 21:22 - 18 Jul 2017    Post subject: Reply with quote
DISCLAIMER: I may or may not have misread the thread and thought OP was talking about his sump bolt. Doh!
I did wonder why he gave a shit if that was rusty. Laughing
The last post was made 6 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 17 - Page Size: 74.93 Kb
