Cbr 600 charging
baggylastard
PostPosted: 10:33 - 17 Jul 2017    Post subject: Cbr 600 charging Reply with quote
My 1998 cbr 600 seems to be not charging properly,had the meter out and I'm getting 13v with the ignition off, 14.3 at idle and 13.8 at 5000rpm after charging, now 12 hours later voltage with ignition off is 12.95.
I thought voltage should be lower at idle than at 5000rpm?
Haynes says to check the reg/rec for continuity and resistance but not too sure what I'm looking for, any help would be appreciated.
Voltage at the reg/rec is 12.4 so faulty connection somewhere between it and the battery?
jaffa90
PostPosted: 10:54 - 17 Jul 2017    Post subject: Reply with quote
Your readings sound ok to me so what`s the problem?
baggylastard
PostPosted: 14:49 - 17 Jul 2017    Post subject: Reply with quote
The main problem is it won't start after leaving it overnight, starter turns really slowly like there's not enough power, I did what the Haynes book describes as a leak test and got a reading of 0.4 milliamps. Is it normal for the voltage to be higher at idle? I thought volts were supposed to increase with engine speed? Thanks for your help
Ayup_Mi-Duck
PostPosted: 15:14 - 17 Jul 2017    Post subject: bats Reply with quote
Hi there. have you tried a new battery?
perhaps check the voltage when its just been turned off and then again in the morning before you try to start it.
Tankie
PostPosted: 15:52 - 17 Jul 2017    Post subject: Reply with quote
check for corrosion on electrical connections
jaffa90
PostPosted: 16:01 - 17 Jul 2017    Post subject: Reply with quote
Mine is the same and has been the last few years no probs.
What`s the voltage when switching on and when pressing the button?
mudcow007
PostPosted: 16:12 - 17 Jul 2017    Post subject: Reply with quote
How old is the battery?
Sounds like its not holding it amps to crank to me.
an has a bad case of the aids
P.
PostPosted: 16:16 - 17 Jul 2017    Post subject: Reply with quote
Voltage sounds OK, battery may just be aids.
baggylastard
PostPosted: 21:00 - 17 Jul 2017    Post subject: Reply with quote
12 hours after I last checked, battery with the ignition off is still 12.95, reads 12.65 withe ignition on and when pressing the starter shows between 8.5 or so and 12, battery's about 2 years old
Tankie
PostPosted: 21:20 - 17 Jul 2017    Post subject: Reply with quote
Battery Fucked ,replace
P.
PostPosted: 07:34 - 18 Jul 2017    Post subject: Reply with quote
Yup that's toast.
fatjames
PostPosted: 12:04 - 18 Jul 2017    Post subject: Reply with quote
I had to get one of these for my CBR not too long ago.
https://www.wemoto.com/bikes/honda/cbr_600_fw/98/picture/battery_motobatt_sealed_high_torque/
Keep an eye on your voltages after replacing - just in case something caused the battery to get deaded.
Ayup_Mi-Duck
PostPosted: 12:51 - 18 Jul 2017    Post subject: Reply with quote
buy a pre made/ charged one or you have to fuck about filling it and charging it like some bastard lemon and loose change cell.
https://www.thenakedscientists.com/sites/default/files/media/xcharging.jpg.pagespeed.ic.SKbr9dDyXn.jpg
The last post was made 6 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.66 - MySQL Queries: 17 - Page Size: 75.34 Kb
