What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 266, 267, 268 ... 407, 408, 409  Next
pompousporcup...
PostPosted: 21:35 - 18 Jul 2017    Post subject: Reply with quote
fitted a micron 4-2-1 exhaust on the gpz900r as well as some hideous blue RAMAIR (why not, black is boring) coolant hoses to replace the 20+ year old originals
10 more jobs and i will be riding it again
PostPosted: 20:09 - 19 Jul 2017    Post subject: Reply with quote
Sold it.
https://www.bikepics.com/pics/2016/10/15/bikepics-2794513-full.jpg
Now to decide the fate of the 350...
B0ndy
PostPosted: 17:28 - 22 Jul 2017    Post subject: Reply with quote
HRC rear brake reservoir fitted
https://i.imgur.com/qLakF9v.jpg?1
CBF 125 -> CB400SF -> GSX600F -> ZX6R (G1) -> GSXR1000 K4 -> ZX6R (B1H Stunt bike) -> VFR800 -> R1 5PW -> Sprint 1050 -> Fireblade 929 -> ZX10R C2H
techsnap
PostPosted: 19:58 - 22 Jul 2017    Post subject: Reply with quote
Sold it.
That's me done with biking for now.
Kawasaki Jimbo
PostPosted: 15:37 - 23 Jul 2017    Post subject: Reply with quote
Tried to get the carburettors off because I reckon the massive flat spot at 8000-9000 revs might be due to worn (Dynojet) needles and/or jets. Now having a tea break to calm down after struggling to even see the carb clamp bolts, let alone undo them. Still one in the middle to go.
Pete.
PostPosted: 15:46 - 23 Jul 2017    Post subject: Reply with quote
Will the bike still be on the needle at those revs?
a.k.a 'Geri'
M.C
PostPosted: 16:23 - 23 Jul 2017    Post subject: Reply with quote
techsnap wrote:
Sold it.
It won't last. I stuck a deposit down on another before mine had even been collected Rolling Eyes
Kawasaki Jimbo
PostPosted: 16:39 - 23 Jul 2017    Post subject: Reply with quote
I knew I should have asked here first. I'm not sure if you're telling me it won't, or just asking, but I know you're savvy so I might be due a "Doh!" moment. I thought the needle functioned between 20-80% of throttle range? The ZX6R revs to 14k. What else might it be? Coils?
lilredmachine
PostPosted: 18:28 - 23 Jul 2017    Post subject: Reply with quote
Upped the boost, fitted clip ons, cleaned it a bit, new clutch lever. Got a date with the strip in August at the Bulldog.
https://s9.postimg.org/s4oysts9b/20228814_10155557298548485_7463655465465033516_n.jpg
https://s13.postimg.org/kxhv9e3tj/20245947_10155557300083485_1930744412731030453_n.jpg
https://s9.postimg.org/kkbl34e1b/20292951_10155557299233485_5777338405674616170_n.jpg
https://s11.postimg.org/946ojigvn/20293036_10155557299733485_289525693030232226_n.jpg
And if you are thinking 'did he cut out the inside of the fairings'? Then yes, I did. Because fuck cosmetics, I need speed!
ThatDippyTwat
PostPosted: 18:31 - 23 Jul 2017    Post subject: Reply with quote
https://i.imgur.com/CYOuGXkl.jpg
Pulled Main and Idle jets - Previous owner upped the jets already ("Tuned, innit laaaa"), 105+35 vs stock 100+30. Put new jets to those values in, went to test it, anaaand the battery is flat. Will test tomorrow, if it's still shit, I'll chuck stock values in as it's still got an airbox, not a K&N.
Guess I'm getting a lift into work tomorrow, it's started to piss it down and I don't fancy lifting the tank to get it back on in that.[/img]
grr666
PostPosted: 08:26 - 24 Jul 2017    Post subject: Reply with quote
Scoots in for MOT at 09.00
Edit - And passed clean sheet. Tester was complimentary about its mechanical condition.
He was not so complimentary about the cosmetics as it has been chucked down the road a few times by the last owner. Laughing
Hong Kong Phooey
PostPosted: 08:47 - 24 Jul 2017    Post subject: Reply with quote
I'll bet that's a handfull. Be interested to know the 1/4 mile time. Standard length swingarm?
P.
PostPosted: 08:59 - 24 Jul 2017    Post subject: Reply with quote
He has extenders at the end, top pic.
lilredmachine
PostPosted: 21:20 - 24 Jul 2017    Post subject: Reply with quote
6" over, lowered 2" in the back, 2" in the front and run with tie-downs. It still wheelies. A lot.
https://s17.postimg.org/jh9feaxz3/banditlaunch5done.png
Hence the clip-ons, trying to get weight further forward. You can see I haven't even got the clutch out in that pic and she's already up.
It's over 200hp and about 150lb/ft of torque so it's a handful, it's also about 250kg with all the turbo gear and extra oil (5.2 litres in this!). It's built primarily for road riding with a nod to straightline every now and then. Best time so far is a 10.009 @143. Really want to run a 9 hence the clip-ons and a bit of extra boost. Hopefully should push me over the threshold.
PostPosted: 21:33 - 25 Jul 2017    Post subject: Reply with quote
At the weekend I cleaned up a load of spare footrest hangers for the Cagiva. Picked a set and repainted them. Look OK, then found out the n/s front one I had chosen had a stripped thread where the gear lever bolts.
Ooops.
Ordered a helicoil kit and fixed that tonight.
Wonder what else I need to helicoil Laughing
Katy
Wheezybiker
PostPosted: 15:21 - 26 Jul 2017    Post subject: Reply with quote
Put the tyre pressures up to fat man mode as I weigh a bit more than previous owner and also tweeked the preload on the rear suspension
It's a Yamaha xj6 and put the preload from 3 to 4 having read the book and watched the videos
chickenstrip
PostPosted: 18:14 - 26 Jul 2017    Post subject: Reply with quote
Caught one of the chain adjuster bolts on the point of seizing, so left them overnight with a bit of penetrating fluid, which fortunately was sufficient for the job, as I don't have anything suitable to get heat on them. Today, cleaned them up and copper greased them. Now both can easily be screwed all the way in and out by hand.
Examined the chain, as I thought I spotted a seized link the other day when applying a squirt of lube, but after cleaning and checking, all seem fine.
Pigeon
PostPosted: 21:29 - 26 Jul 2017    Post subject: Reply with quote
Fitted some cheapo shorty levers. Bought gold ones to sync with the gold forks and brake calipers and yellow shock.
Didn't work. They look appalling. On the plus side, add some tinsel and the bike looks very festive.
Added some cheapo stomp grips to try and stop banging the tank like a randy dog every time there is a whiff of a bump in the road.
Added 1/2 turn preload to shock which seemed to take some pressure of the front, bike feels more balanced again.
Tracer1234
PostPosted: 00:01 - 30 Jul 2017    Post subject: Reply with quote
Fazer The Bastard wrote:
Tried Harpic on my downpipes and gave the rest of the bike a wipe down with an oil soaked rag.
https://i.imgur.com/8Aefwcp.jpg
No fairy liquid this time then lol??
Jokes aside, looks good, Im going to keep the Harpic in mind. The bike still riding Ok?
Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
pompousporcup...
PostPosted: 13:04 - 30 Jul 2017    Post subject: Reply with quote
Picked the thundercnt up in a tiny berlingo van after the attempted theft on Friday.
Fuckers broke the steering lock, screwdrivered the ignition and then to top it all off cut the ignition loom..assume they were trying to hotwire it. Absolute fkwits couldn't even manage to steal it properly. All caught on cctv, in broad daylight with people in sight. The office is remote enough that you wouldn't stumble upon the bikes, you'd have to be actively looking for them
Why they chose an old yamaha instead of the 20k ducati panigale is beyond me.
Now to start striping the front end down and replacing things
Tracer1234
PostPosted: 14:23 - 30 Jul 2017    Post subject: Reply with quote
Any damage else where? Be interested to see pictures of said carnage Sad
haroman666
PostPosted: 14:25 - 30 Jul 2017    Post subject: Reply with quote
De-glazed front pads and then went for a little bimble around the local area.
pompousporcup...
PostPosted: 14:40 - 30 Jul 2017    Post subject: Reply with quote
Tracer, no other damage other than what was already there, just the barrel, steering lock and loom.
Idiots couldn't even get it in neutral. It was in 4th lol will upload a pic later on.
PostPosted: 16:00 - 30 Jul 2017    Post subject: Reply with quote
Re-fitted a slightly bodged throttle cable to the Enfield with the proper bits.
Wouldn't start up.
Re-re-fitted the throttle cable.
Wouldn't start up.
Took a careful note of the mixture and idle screw positions, tried $MANY combinations of same plus choke.
Wouldn't start up.
Re-re-re-fitted the throttle cable.
Tried $MANY combinations of mixture, idle plus choke.
Wouldn't start up.
Re-re-re-re-fitted the throttle cable, put everything back to initial positions.
Started up and ran just fine.
Brick Wall
The last post was made 6 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 267 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.1 - MySQL Queries: 17 - Page Size: 141.85 Kb
