Author |
GavintheTazma... |
GavintheTazma... Derestricted Danger
Posted: 22:51 - 20 Jul 2017 Post subject: GSX750F running problem |
I have a 1998 GSX750F which has a running problem, it seems to be misfiring and can only get 60mph out of it.
I have had it in at my local bike mechanic and he has stripped, cleaned, rebuilt and balanced the carbs, fitted new plugs, checked the resistances of the coils and HT leads (all ok), replaced the carb diaphrams and set the float heights.
He told me that the problem was still there and told me to try the following: change the exhaust (non standard), replace fuel for new, replace air filter to genuine (pattern fitted at present) and then check for an electrical fault. I think he couldnt be arsed with it any more and charged me £300 for the privilege.
I have changed the fuel, on removing the tank I noticed that the plug leads werent even attached to the plugs properly (not pushed on) and that one of the carb rubbers had been fitted incorrectly (trapped in air filter housing), replaced the exhaust for a full stainless Delkevic system and as for the air filter it has been in for months and have never had a problem with it before. I am yet to go for a test ride after completing all the work mentioned but thought I would ask on here for any advice to cure the problem. All advice/help will be very much appreciated.
Thanks, Gavin. |
Back to top |
Pete. |
Pete. Super Spammer
Posted: 23:03 - 20 Jul 2017 Post subject: |
'Mechanic' doesn't know what he's doing, he's just guessing and changing random stuff. Keep away from him.
You say the air filter has been in for months and you've had no trouble with it but you think that suddenly the exhaust might be at fault? doesn't make any sense.
If you were nearby I'd offer to look at it except that I have a very full schedule of work for the next month. ____________________ a.k.a 'Geri'
132.9mph off and walked away. Gear is good, gear is good, gear is very very good |
Back to top |
jaffa90 |
jaffa90 World Chat Champion
Back to top |
pepperami |
pepperami Super Spammer
Back to top |
GavintheTazma... |
Back to top |
pepperami |
Back to top |
lilredmachine |
lilredmachine World Chat Champion
Back to top |
lilredmachine |
Posted: 20:26 - 23 Jul 2017 Post subject: |
One thing I will say, the delkevic pipes you have installed are larger than the stock. Considerably.
I'm running similar on my 1200 motor and I had to stage 3 dynojet to make any sense of them. 155 mains. I am running an open pipe (111.7db ) though.
You should be able to get over 60 though. Have you checked the motor side carb rubbers? An air leak would explain some of what you are describing. Look for deep cracks or if you can get it idling and spray easy start or wd over the rubbers, if the revs rise you have an air leak. ____________________ Bikes: too many, too much for one man to maintain anyway. |
Back to top |
GavintheTazma... |
Back to top |
Snowdonia Rider |
Snowdonia Rider World Chat Champion
Posted: 16:58 - 28 Jul 2017 Post subject: |
This sounds exactly like what happened to my '98 GSX600F. Turned out the HT leads weren't connected to the the plug caps properly and some of the electrical wiring had gone shit. With that sorted it ran great. So I'd deffo start looking into your wiring. ____________________ I want your clothes, your boots and your motorcycle.
My YouTube channel: https://www.youtube.com/c/SnowdoniaRider |
Back to top |
GavintheTazma... |
Back to top |
GavintheTazma... |
Posted: 00:35 - 30 Aug 2017 Post subject: Post update |
Its now been over a month of trying to sort this problem out , I have fitted a genuine air filter, removed the inline fuel filter and replaced with a brand new fuel line WITHOUT an inline filter. I have checked all the wiring and all seems fine. I am getting really frustrated with this fault, as I have never had any problems with the bike in the 10 years of owning it. I am know thinking it could be the coils??? as the symptoms are no top end speed (feels restricted) and feels like its running on 3 cylinders over 4000 revs. I don`t want to keep spending out on "it could be this, or try that". I would be very grateful for any advice on what to do next. Cheers |
Back to top |
jaffa90 |
Back to top |
GavintheTazma... |
Back to top |
jaffa90 |
Back to top |
GavintheTazma... |
Back to top |
jaffa90 |
Back to top |
Pete. |
Pete. Super Spammer
Posted: 05:32 - 30 Aug 2017 Post subject: |
Forget the timing advance it would affect all cylinders not just one. ____________________ a.k.a 'Geri'
Back to top |
kev2b4 |
kev2b4 Two Stroke Sniffer
Back to top |
jaffa90 |
Back to top |
Pete. |
Pete. Super Spammer
Posted: 12:47 - 30 Aug 2017 Post subject: |
You don't think running on three will affect the top end speed? ____________________ a.k.a 'Geri'
Back to top |
Tdibs |
Tdibs Traffic Copper
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
GavintheTazma... |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
The last post was made 6 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
