Rg125 2st oil feed
spitfire123
PostPosted: 10:38 - 22 Jul 2017    Post subject: Rg125 2st oil feed Reply with quote
Hi all
Recently got hold of a fairly nice rg125 1992
Now I've taken the carb off as it needed a clean out, but there Dosent seem to be an oil feed going to the carb ?
So I took off the rear fairings to see where the 2st oil tank lines run to.
It seems to go in to the engine below the carb and another one comes out directly above and runs down the side of the engine somewhere?
Now I have an rs 125 I've recently built and that goes from to tank to oil pump to carb .
I can't work this out ?
There dosent seem to be any loose lines anywhere to go In the the carb line ?
And smokes like a goodun when it's running !
I'm thinking there definitely should be a feed in the carb !
Cheers
You won't be able to eat my dust......As it'll settle before you get there.
Nobby the Bastard
Harley Gaydar
PostPosted: 11:02 - 22 Jul 2017    Post subject: Reply with quote
I seem to remember the oil pipe going to the manifold, not the carb. The pump is on the rhs of the crank and so the oil pipe would come up from there.
Sprint ST 1050
spitfire123
PostPosted: 12:51 - 22 Jul 2017    Post subject: Reply with quote
Thanks for your reply
Yes you are correct it does go to the mani .
But there is a bit on the carb at the engine side that looks as if it should have a pipe going to it ?
Thanks again
Robby
Dirty Old Man
PostPosted: 14:39 - 22 Jul 2017    Post subject: Reply with quote
Find a workshop manual. There are a good few variations in 2-stroke oiling out there.
I'm no expert on 2-strokes, but it always seems to make sense to me to inject the oil directly onto the crank bearings and let the petrol mixture pick it up during primary compression.
spitfire123
PostPosted: 19:29 - 22 Jul 2017    Post subject: Reply with quote
I was thinking the same ,
Reading on google one line feeds the crank other should feed the carb , might explain why it's got the 40km in it .
I'll have another check .
Cheers
spitfire123
PostPosted: 19:33 - 22 Jul 2017    Post subject: Reply with quote
Right
Found it !
There is a tiny little uinion on the end of the oil pump for the 2nd feed for the carb , I couldent see it because the pipe had broken over the nipple and was black and covered in crap .
Anyway put a new pipe back on , connected up , just waiting for the liquid gasket to go off and it should be ready .
Thanks all !!
spitfire123
Cheers
The last post was made 6 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.88 - MySQL Queries: 17 - Page Size: 54.27 Kb
