Hopefully a quick one.
Tracer1234
PostPosted: 19:00 - 25 Jul 2017    Post subject: Hopefully a quick one. Reply with quote
In all of your infinite wisdom. What is the best way to tell if the steering / front wheel is out of alignment?
It looks and feels like it is ever so slightly off, and now that I have noticed it, the feeling is exaggerated. And if it is, how hard is this to rectify.
Tyia Smile Karma
Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
pompousporcup...
PostPosted: 19:08 - 25 Jul 2017    Post subject: Reply with quote
Loosen all bolts bar the ones on the top yoke and bounce down compressing the forks in a few times. Then tighten everything back up from the top down (iirc)
Commuter_Tim
PostPosted: 20:37 - 25 Jul 2017    Post subject: Reply with quote
...To quickly re-align the front end.
To check alignment: The String Method.
Alternatively if you have a huge long straight bar (seriously who the hell even has one of these? except scaffolding stealing pikeys), use that instead of the string.
If something feels off and your bike has ever gone down, your handlebars could also be slightly bent.
Also bar end imbalances can be a factor.
I ride a Bandit 600... badly.
Tracer1234
PostPosted: 22:27 - 25 Jul 2017    Post subject: Reply with quote
Bike hasn't gone down, well not that I know of Its only done 1000 miles, and is in perfect condition. It looks and feels like the front wheel and handle bars, ever so slightly off.
Neutral
Commuter_Tim
PostPosted: 22:29 - 25 Jul 2017    Post subject: Reply with quote
Neutral
Curious, it happen any more or less at certain speeds?
trevor saxe-coburg-gotha
PostPosted: 07:06 - 26 Jul 2017    Post subject: Reply with quote
PSI?
PostPosted: 08:57 - 26 Jul 2017    Post subject: Reply with quote
...although a lot of people do have removable kickboards under their kitchen cabinets...
Smile
Commuter_Tim
PostPosted: 20:06 - 26 Jul 2017    Post subject: Reply with quote
Smile
True, but is that plank of wood really trustworthy enough to be a straight edge? Thinking
I'd be concerned of warping or bowing, but maybe I'm over thinking it.
PostPosted: 20:08 - 26 Jul 2017    Post subject: Reply with quote
Not if you hold it upright, but should be if flat. You can always check the board with string before using it Smile
PostPosted: 20:37 - 26 Jul 2017    Post subject: Reply with quote
Tea spat out you cccc comedian you. Laughing
Triumph Trophy Launch Edition
Commuter_Tim
PostPosted: 21:34 - 26 Jul 2017    Post subject: Reply with quote
Funny for sure, but I can't fault his logic either.
Stoker
PostPosted: 18:53 - 29 Jul 2017    Post subject: Reply with quote
Have you checked the bearings in the steering head?
As a motorcycle spends most of its life going straight ahead, the repeated shocks from the front can wear small indentations in the surfaces the bearings run on. This can make the bike feel like it's trying to run on tracks, or that you're continually crossing road repair joins.
To rule this out, jack the bike up so the front wheel is off the ground, and gently, very gently move from lock to lock, actually, from a couple of degrees either side of straight ahead. If you go millimetre by millimetre past the centre point, and you feel the bars settle slightly, yep, head bearings.
Haynes will tell you to look out for notchiness and stuff, but if you move the bars slowly, and you feel something between one degree either side of straight ahead, their's your culprit
grr666
PostPosted: 19:03 - 29 Jul 2017    Post subject: Reply with quote
It's a pretty new bike, I doubt it's done much mileage yet.
Tracer1234
PostPosted: 23:53 - 29 Jul 2017    Post subject: Reply with quote
Thank you for the reply. Insightful and worth remembering for future. As Grr Said, the bike has only done 900 Miles, so not sure this will be the problem just yet, but thanks Smile Thumbs Up
The last post was made 6 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.37 - MySQL Queries: 17 - Page Size: 90.89 Kb
