Bandit linkpipe/ Gasket
mudcow007
PostPosted: 10:47 - 27 Jul 2017    Post subject: Bandit linkpipe/ Gasket Reply with quote
Right, decided to sort my leaky pipe for once an for all.
where the link pipe slots into the collector end/ downpipes is 56mm OD, there is a slot cut into the bottom of this pipe but its been crushed closed.
The link pipe is 51mm OD
I bought a "standard" graphite gasket which is 58mm OD which obviously goes no where near it.
Now i could probably get the graphite gasket to fit if i uncrushed the collector pipe, but the ID of the gasket is about 55mm so the linkpipe will still be rattling around?
am i being a mong, or have i got the wrong gasket?
Evil Hans
PostPosted: 11:27 - 27 Jul 2017    Post subject: Reply with quote
My Bandit link pipe and collector is all weird sizes due to being repaired (badly) in the past (by me!)
Any chance some loon has butchered yours?
Edit - Although from memory, that pipe size sounds about right. You may have the wrong gasket!
Triumph Sprint ST 1050. And it's Red.
lilredmachine
PostPosted: 14:15 - 27 Jul 2017    Post subject: Reply with quote
Standard repair on Bandit headers for me has always been a 60mm stainless collar welded on where the old one snaps off. Bang your 58mm o/d gasket in, link pipe fits into that, clamp it down, forget about it.
mudcow007
PostPosted: 15:14 - 27 Jul 2017    Post subject: Reply with quote
cheers all
any recommendations how to open up the slot cut in the tube which has been squished shut - without deforming it all out of shape?
mudcow007
PostPosted: 15:04 - 28 Jul 2017    Post subject: Reply with quote
just cut a bit of pipe 60mm wide to try an force the collector end of the pipe open a bit to get the gasket in
Also took a few mil off the gasket to make it a bit easier to fit, hopefully will be able to nip it up with a clamp
who knew fitting a gasket could be this arsey
PostPosted: 15:18 - 28 Jul 2017    Post subject: Reply with quote
Tube of cheap silicone sealant, gloop, get on with your life.
mudcow007
PostPosted: 20:27 - 28 Jul 2017    Post subject: Reply with quote
i have tried silicone a few times (even the posh "Dow Corning" stuff) an it always seems to wobble loose.
i will try the gasket an silicone an hopeful it will sort it
ThatDippyTwat
PostPosted: 21:48 - 28 Jul 2017    Post subject: Reply with quote
Try some copper infused silicone.
I use it on a flex pipe on the exhaust, which moves a lot more than your headers will. Zero issues.
Islander
PostPosted: 22:20 - 28 Jul 2017    Post subject: Reply with quote
If you're going to use silicone then a low modulus type would probably be best.
The last post was made 6 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 17 - Page Size: 61.22 Kb
