Derbi senda r 50 idle problem
benceww
PostPosted: 10:51 - 02 Aug 2017    Post subject: Derbi senda r 50 idle problem Reply with quote
Hello guys! I need a little help. My Derbi Senda worked perfectly until the rubber between the carburettor and the engine is splitted. When i replaced it, the idle is fucked up. I cleaned the carburettor, idle screw tight, needle rised. But still not working. If i pull the throttle it works just not idling. When i clean the carb again its idling for a 20 and stall. Sometimes if i cold start it works but if i ride it for a few minutes its won't idling again.
What happened? Please help. Thanks!
jaffa90
PostPosted: 16:14 - 02 Aug 2017    Post subject: Reply with quote
Have you a diagram of the carb?
It sounds like the pilot jet is partly blocked.
PostPosted: 16:43 - 02 Aug 2017    Post subject: Reply with quote
The idle screw shouldn't be 'tight'.
Put the needle and the screw back to factory settings, then try again.
The last post was made 8 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 1.19 - MySQL Queries: 16 - Page Size: 36.09 Kb
