Struggling to upload images!
c_dug
PostPosted: 22:36 - 08 Aug 2017    Post subject: Struggling to upload images! Reply with quote
Trying to make a thread but none of my images are working, it's driving me absolutely mad!
This used to be so simple with photobucket but of course they've gone and fucked that, I've tried directly from google photos with no luck, Imgur isn't working for me either.
This is the thread: https://www.bikechatforums.com/viewtopic.php?t=321313&highlight=
Any advice?
Cant work out where I've gone wrong with imgur?
PostPosted: 22:39 - 08 Aug 2017    Post subject: Reply with quote
https://i.imgur.com/6aNQsS3.png
The images in your "Fuck this shit. No idea why all of my imgur images wont show up either?" post work fine.
CaNsA
LOL
Code:
[img]http://goo.gl/photos/v9NSdBpEiDEveQQV7[/img]
[img]http://lh3.googleusercontent.com/M5rDH1Zpuf1p52zwNSI2hhYHz1hBgw0kYimhBMAhHmAAUfn2oBd2FkqFkZR6QAg22yM1N0UG99qArV-Bw4rrSeuRJPyVw8IiTt5eoTAMhq6ckBvPbfpM3giUZ1xLql2nqyyfqoZvibN1UW5ckw3qvo1iM7qvm-iNzxhApQY_CRDpyNW86fHjzVc8wP-VFaEcJy4fLAU_yUOp7z8DkYJ0QKOBnxyM_kbc77ehGb2sAtSTR0QOueKvf8FhiGMmNtuMeznkFBwM6l4SiHY7jB9XHm7RiWW4ZQwEgnXUmVN-mtH1JWm4qGvkNz9cV6Oeed1Q28j2q5WJoQbaj-e2CsAk9rSuovJceAe7qYdXu3CxHP-t3xmEZirRaD9Eu4xqDbNLXNXsJDWDZLhQuoAaUbZww3-GWeHd93seHcQqU09Gdc5FJW_3VC26ynZ4J5jaioEbFmi6ED395442vOS6cnyWpwLgLyL43LZ8PcmlppfeJ3LyFFQjAPakv3oBIxjdNHpTmyVMKAgYtsZoSVhiUKexXcQiVEtr8dbZbA7_rh0OCkKCrQ1WAWPhDhpzPXG3M6i0l8bz_hwc34En2oKFjs6Oy5D6ubZ1NjlPxy261GPcoIBY0LrAsgulk2R0=w883-h662-no[/img]
Until this happened:
[img]http://lh3.googleusercontent.com/R4MmRPNu-N6RzvL7ZN_Q2v8gSHXX_jS5OaXHIjqFhVzski5ujnBzwEirdfkGGGdHnR-d-6Jw4m8m8S9_rN29ecIv_Rr4xuQln4lvm2-ihV2jlYWOqYDgDc5Nn3cBGrV5NNSHnk3EPDavvw9yed7br6KooMirSD1Swd-fbLK5YhEdFzsmix59qj2NZ--nf7JVuKG4XqY-b7_IfX5-JZxPXJcV2TNPMouUqIO5DUQ6_Xtp9uLqft3bciZ1eMLt6iyZ1q-a4piSR9vvHE2UYKSNs2ttIo0C6rcaOKXQAD2tLdtRJmN4RMAJo1hQuSxccGSoeZTscB7wtcLuiS2ZCVISkN4Ae4kp0Hs7-ZzVCwCzYsxrPQcZC2dGfBtzCNX-kHLDNbBS0M6gkDHSV-TVDtjJWdfsRfcF10yhrSdNJPI54g3ZTv14dTDMUZUFe4nFsKnzxY_qn49q8D6BPo7C8_m-1a82WOwnDWwEH12_7g-zjRnCuA5ru9yQ_QOKQrlSnp_D-5ZPledeiHRt6hrXHIHar6MeHlwp5pMj9kheRGfHWyES_j5_jCznJcLvQm3mCoEIT4U1TvAXokQIpWQS-nHMZHI5lXaqxiOOdwJm22IoB1mlP5JdGaBJ=w883-h662-no[/img]
Then I dug out the biggest die I could find, M22, and finished up the other end to make this:
[img]http://lh3.googleusercontent.com/lFSBztgbTIbM3JReBIABbczXF3FUq2_HQ7DBZJYfF7Xv653JJK7U6rqNlx5WX9AUCvkV9AqkiVIraV3GUrmeWLwUGdty1Mo_4jr98aL3QrkkG-a-YsBSBNK5uLfJSHTGQ8hVlRxnv9yRw1OccYVbV7NOrYOIQ0rJ2tobjya2wevn4gJsaSW_JAnlUaVpcK-nJ2j62_YCVY3jPRLTnkgOKbSoYkVGWIaeJuplRPbseL-SDQoaA7N8W2R4qVJEy69NH5N48FSdlQsSzJXMTeYNkxXLPv_7is8cgINv9-n3ftLkZa-uEeuo2reU5huctMHSotvxCWuQWVpP3uicMqQILWEwswMRanDXbcn3j6hbvB6JqtXXri2Uc4EqAs5latGiSyCiC4mdFHlqO2sF8GokJ7kxHXb0brPdkzi7l4e-P9iy6YKmxX1lAdtUqyEUnsrYv_62cKbP031s_oJhxx14bnqeqS7fBmjtV93cIyLVwHWvlw8Dr6MX19FqhakNSd-got4xJwEKq8QtVPdW7XwSKgdCS9DIZ3hMltvDdr_myBvyAJ3RAolafIawQl_bKGwyfp_QUMhWo_c8zP12GOxqQ01x4yBQ3xqysio4pkyT__8xuqP5mkAw=w497-h662-no[/img]
Next I roughly hacked up a bit of ally flat bar to make a holding mechanism, it has a U shaped slot that goes over the flange on the bottle, you can also see the one way valve installed on the end here, it's a 12mm push fit:
[img]http://lh3.googleusercontent.com/8YeHkJ1lHlhgzZvnsWvC3azmbZL0Bp3A2drZbH1DlF5nBNsX6bsV4eoEsoUjqX4MX6D9jplqe0aW1XkDKnHNqVgIRT5Mg1_Az1SiSGundNDy4Rbt3snTDeyBHwm7GBNC2JTUc4k0GhfEw9bXIn8F9El08o2G5Pqz6TPKleadAPGBIeTibii3BtnxAG43LeQVDmXvzI0YHRmM3Zz-BpfUOccwpMyAvieyDlHq-R7b5zBS_n6oUme1NJ96-xp_Za33T45k27XQipBdDmP2SUpoUmRnIghyG_vRLHqCiaMG8BOkzqPhfTKUJp5TAvXl6Kw0Xpt0kDJYw4Ev6UAuWgzOfF7r8QgRX8_k2b937XhiAkgSrnh7j8AKV_2fwe05DG36Xle7XLlBnA-jkmjG1x-eDtVN4q2mgZUNqbDehRv4WO1bugQgn3TUKPoP6NVL0Tf0ax5xkBY3Tv2P9hMKaI6GWqvyAVZ2UJyEJByhNGIrnPGJgbCPSbsFN4n4Qut_wmsBtKu35vp-h3hKBprYpdok7-uCgtru4eP9MRTnv9Q1TsYqPYQsyPMAWNUcVu-STSggOWWxHvE9fXk2adXTHA7td6olEjq1kY3R2hsQjwK6uWvlD8QmE0LX=w497-h662-no[/img]
Next I found a large piece of ally U channel and machined a piece of Nylon to fit in the gap, then attached my flat bar to the top, and drilled and tapped an M22 hole in the end, to create this:
[img]http://lh3.googleusercontent.com/4zL5kTYEPQTPohtNvn50JotSyEOfyNdSLzrUD83sxQ-vTIBdRasjr7KL188LtBt7eFv7Mg1RBVeQHfjpG0riL8Gern3Qp8XdPxta-MoF207OQ5t94kWIKTZ5rmOwiYZU3KmcOuvLz4g4RbqXMBl2wNuLB-T8dntcKVolvUf391mYctlJF9W0-_HXZ8NPEi7jpkjO2XCjid3PwR9CU2KTxegx23O-z6Cq8kaaBAi_qwtPWCj4qobsK6MxBqbo4EGRZI4rA8DKM5JU7udSmF8Ps1q1fzJ8nVdFEPwMRKGJXMBRD-bgieNbpFzDG2x2p5cwXPOhyit2AbPvYA7WR4iuzgB0tIINpj1qazrpsA3Kk9rF6-qlAsTkUIax-ogK9IojGLnUT3_iwA7ZQkgCAOZHz1-QpsOSoBcFww0vI2f4kD_WVSfuIroBB3UdkjI4o_czlbwG74NyDH2j_J_T__LuCH1kLvALAQk0ZxLZHb132D827QbCzZQdepYH8CqSuD545jdDnR_IkUD4dXwfIlKEgSb7CXz2UbBciKzk4gBpkPJ8pTa3M218_Zt1WIcclK5LzxmQUiYcO3NevcpFKgZMSp3wefpAWMyPvcz-IiTYhi4V1EQhfCvm=w497-h662-no[/img]
[img]http://lh3.googleusercontent.com/ltp-Hn9X0iWa71xjy5NNzoCu4ujwvRpjm_dTFp-zYfVBbV02CjrtwzyvAnoEoahhW2tf8sjbbkh5pdITyG3BoH651cNU1qv8ZDggWm8ZEoCiPKHlzK4gw95rouDqcbzWl-xOE_TrB1mtmTx7LbZsUMwCWHYyJnQ9X-GWfQ2HKwCJMYftZ2Xw7Efi5IF3nEg-zwayQzbkkcwQRa2bKWb6em_Q-BPmXsQBruI2Td3rg0E-sXazEx9QIaLLFN712Cu09a2nO9YsiyjvTk4PdqOc_SlVjt23ClXbTE5n3qnBV9ImmE8BT1tV5SD6BhqijDIW9quhqNarEEsIipAlTFyjfpTbXi51Cb98k5I9NjcPfnFeX0YGtY0_5JdRrVT90_IW3AJxlvce6ccu0EmRpFsNtDmL3xPXeIUqXnJTbJ1Wq3qAiIbYorJ2_EOqWZfSkkw_D_7Z_6HRSK9JryNUzAFt_GdYzFIfBi3DZqtclL0aZt0mKk8WzvDtgffpW1PFdOErmVgMjgDqrZlS436EAGpbPFvX7GCHnFdc69Iibf-LoersdpUwsYYkZTj_lijxDcO0k8Zhx6C63-60desGXlfalHzsaR5IuVO4XW89GsxjDF8UaAaPWxVr=w883-h662-no[/img]
[img]http://lh3.googleusercontent.com/AQyZQZv9o_5TMlRGBGtn3tWOegseFsTBpZp6yOixSjX5SJE03bjFv5wt6ViR_0apqbMzDIDctvPyp2RLhzNvTJW1Rpe1URR5ba01llL2ZYms5srTtnmdm51BnULgakbgx9GlGIx4IsfzpoN9tOy-CnJ3NO3RXpzurHY9QN2A-jGrjMbWksMCx_7FHQxE1ynwFyrDDOw5f00pSKmF8-NL6Ya_7OeP9R4BK5Z32hS5G4lmihr4cAYZqjDNHx2Wr0FauYYbGnWko2MYT0lkcjzyzxon_m20uRs4a8OI2iyuycKxt32EGAIvaUAI8R1ZH-EdfINknDJsg75JLtNP7Ym6XahJi7pv9yvlX3LnP0XozC26TwUPD6OIvwx95ng83tjz6wb-KlEPOYekUldlU0k39TRvkHSSdXR-gdP1hT5WTO4lt_8eCr0bAuCF8RMAf0DY9lo0gluNwSbmBSV8zgTXZzH7iNqiNvDBTm4UJJWab_NM6Tre4NrjW9Zfe5BCRfI0e0KcqBluN7So60tJ9ZQelvhkyNz6zvbO5Qs8Oujp1oQ2WmigFtaYrH4i9Kk1F_vAJ4mFmuBcdRShiKDU_ho1o171VqxVmNPY5LXtnyxDNiJ8paMVjkdt=w883-h662-no[/img]
c_dug
PostPosted: 22:44 - 08 Aug 2017    Post subject: Reply with quote
Yep, I'd "lol" too, if I wasn't losing my shit with it!
If the second post picture shows up, then I'm really confused, I've got the thread open on my phone with my account signed out (because my google ones show up anyway when I'm signed in) and I can't see it - is that because my account is signed out?
If so, I've been driving myself mad for an hour over nothing and I deserve your laughter!
CaNsA
PostPosted: 22:46 - 08 Aug 2017    Post subject: Reply with quote
image hosting from imgur.com looks like
Code:
[img]http://i.imgur.com/xxxxxx.jpg[/img]
c_dug
PostPosted: 22:48 - 08 Aug 2017    Post subject: Reply with quote
https://i.imgur.com/a77k4ZG.jpg
c_dug
PostPosted: 22:54 - 08 Aug 2017    Post subject: Reply with quote
So are they working now?
https://www.bikechatforums.com/viewtopic.php?p=4485603#4485603
owl
PostPosted: 22:56 - 08 Aug 2017    Post subject: Reply with quote
c_dug_the_bastard wrote:
Observation is the greatest source of wisdom.
Howling Terror
PostPosted: 22:57 - 08 Aug 2017    Post subject: Reply with quote
CaNsA
Blowies all round.
c_dug
PostPosted: 22:59 - 08 Aug 2017    Post subject: Reply with quote
5 dorra
Howling Terror
^^^@ him above you. You kissed me through my open visor. I have lost a lot of respect for you although I did achieve wood for most of the journey home.
CaNsA
PostPosted: 23:06 - 08 Aug 2017    Post subject: Reply with quote
That's the 2nd time I've kissed you as you were leaving... Does that mean it is now BCF BBQ Tradition?
Howling Terror
PostPosted: 23:08 - 08 Aug 2017    Post subject: Reply with quote
https://stream1.gifsoup.com/view5/2518807/thomas-rolling-eyes-o.gif
Guess so.
The last post was made 6 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.42 - MySQL Queries: 16 - Page Size: 90.94 Kb
