Author |
mudcow007 |
mudcow007 World Chat Champion
Back to top |
Teflon-Mike |
Posted: 03:48 - 11 Aug 2017 Post subject: |
Guaranteed fix is a new crank case and a whole shed load of engine rebuild.
Bodges?
Anything gloopy wise is gong to have trouble sticking where metal is oily, & I wouldn't want to be doing daft like trying to burn off residue with a blow torch before applying gloop....
I might try a fibre washer and a load of bathroom silicone.. I wouldn't expect it to hold but at least slow oil loss to tolerable level before needing to re-do.
Metal-set, would be a wast, it wouldn't stick, and you'd have devls job flattng it to get a seal to stay.
Lumiweld would be the next best thing; but back to the blow torch, and hassle making seal suface.. can be 'cast' around steel plug threads though so might be worth a try, but I'd probably want the motor out and USD to tackle... and ponder whether be as sure and easy to hack the thing to bits..... of just ditch it and chuck in a Chinky lump from a MOT fail!
Back to top? I'd proably dran the oil; fluch with some paradin, clean up offeding area as est as; wop the lug in all but three turns, leave to drip, clean with thinners; get the mastic gun round it; leave to cure for a couple of hours; tighten plug up to a bit over finger-tight, if it felt like would take it; clean area with thinners, wop more mastic over and around, and HFTB... aint going to get worse, worst cas plug drops oils lost motor siezes, you are back to top and a rebuild with new cases of woping in a chinky take away. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Back to top |
temeluchus |
Back to top |
stinkwheel |
Back to top |
Andy_Pagin |
Andy_Pagin World Chat Champion
Back to top |
Tamsin |
Tamsin World Chat Champion
Posted: 19:36 - 11 Aug 2017 Post subject: |
Show us a picture of the casing, I'll see if I have one in stock |
Back to top |
Triumph1300 |
Triumph1300 Nova Slayer
Posted: 08:40 - 13 Aug 2017 Post subject: |
Clean thoroughly, araldite, or jb weld to build it up, sand back, fibre washer to seal it. ____________________ BWJ
Back on a BMW R80RT
Punctuation - the difference between knowing your shit, and knowing you're shit |
Back to top |
The last post was made 6 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
