Author |
Commuter_Tim |
Posted: 23:20 - 10 Aug 2017 Post subject: Bandit front suspension diving |
The Bandit front suspension is bouncing back and forth like a rocking horse.
Every poorly contructed patch of road my front end just launches downward.
I don't believe the seals have blown, the seals on my CB500 were fucked from the moment I bought the bike, so I rode for a while before realising that wasn't normal.
They're not empty of oil, and they're certainly not leaking.
I'm 6 foot 3 and about 14 stone, I also have a terrible tendancy to lean on the bars (lanky and bad back).
So some diving i expect, but compared to my previous bikes it just doesn't seem right.
Even with blown seals and it pissing out oil, the CB500 forks would dive less than the Bandit does.
What's the best way to stiffen them up?
Is it a case of harder springs, or thicker oil or both? ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
Back to top |
Beehive Bedlam |
Beehive Bedlam World Chat Champion
Back to top |
mudcow007 |
mudcow007 World Chat Champion
Back to top |
Kawasaki Jimbo |
Back to top |
Qyburn |
Qyburn Renault 5 Driver
Posted: 08:35 - 11 Aug 2017 Post subject: Re: Bandit front suspension diving |
Commuter_Tim wrote: | What's the best way to stiffen them up?
Is it a case of harder springs, or thicker oil or both? |
Rapid dive on the brakes is more about damping than spring rate, the front is always going to dive but you want it to be a smooth controlled dive with the weight pressing the front tyre onto the ground. Not a rapid free-fall.
Having said that, if the springs are too soft it will make matters worse. Since they're a simple drop in fit, it makes sense to get that sorted as the first step. With the correct springs, you can then increase oil weight to get the damping that you want.
I don't know the Bandit, but if these are simple damper rod type forks you may still find that once the oil is thick enough to control damping properly, it becomes very harsh over bumps. For my SV the solution was to fit YSS fork valves (emulators). These provide a restriction on normal compression damping, making fork dive very much less, but the valve opens on sharper movements, reducing the harshness over bumps.
Hope this helps, ____________________ Lord Qyburn |
Back to top |
Robby |
Robby Dirty Old Man
Posted: 14:33 - 11 Aug 2017 Post subject: |
On basic forks like the bandit has, you have a few options to alter how they behave. It is worth knowing what these things do, and to avoid going too far or doing everything at once.
Springs. If your forks are diving all the time, your springs are too soft. You can either replace them with stiffer or progressive springs, or you can add preload, in the form of spacers. These can be a bit of pipe, old sockets, pennies - it doesn't really matter, as long it's the same length on both sides. Try adding an inch of preload - it's a good use for the old imperial sockets in your toolbox.
Oil weight. Oil weight governs damping, it slows down the fork moving both up and down. You generally want thicker oil when the fork is moving too much or jittering on rough roads. You should not use thick oil to mask diving forks, it slows them down in both directions, meaning your tyre can spend less time in contact with the road on rough surfaces.
Oil level/air gap. The air gap acts like a spring. Air is compressible, fluid is not. A smaller air gap can make forks firmer. Small changes here - I would usually add 5ml of oil per side, then ride it and see.
So in this case, I would go with an inch of preload on the springs and an extra 5ml of oil in each fork leg. Don't get too precious about the oil used - it's a tiny amount, so 10W40 engine oil will do. |
Back to top |
Qyburn |
Back to top |
Kickstart |
Back to top |
The last post was made 6 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
