Will pay for answering! Peugeot Vivacity 3 125cc
Vivacity3
PostPosted: 18:11 - 13 Aug 2017    Post subject: Will pay for answering! Peugeot Vivacity 3 125cc Reply with quote
Peugeot Vivacity 3 sixties 124cc moped
Indicators have stopped flashing all I get is the indicator on dash stay on permently if I click left or right
I have looked everywhere for relay flasher but can't find it
I looked behind headlight
Under seat
Both side fairing remove and looked
I can't find 1 does my ped even have 1 ?????
Please help me MOT in 4 days
Will PayPal you if you can tell me info on location
andys675
PostPosted: 19:14 - 13 Aug 2017    Post subject: Reply with quote
I worked on a lot of mk2 peugs and the relays were often in the floor
ps, £20k please
Vivacity3
PostPosted: 19:17 - 13 Aug 2017    Post subject: Reply with quote
Not in floor I already looked took whole front end of and most of the plastics lol
It's 2011
andys675
PostPosted: 19:20 - 13 Aug 2017    Post subject: Reply with quote
so it must be in the front section under the handlebars
Vivacity3
PostPosted: 19:24 - 13 Aug 2017    Post subject: Reply with quote
Nope look behind lighting unit
Looked behind glove box looked everywhere mate and no one knows
Someone said it's built in to the regulator ? But don't believe that .... But kinda am now
But regulator is a good £45 plus .... Might not even be that as charging is good ect
Wheezybiker
PostPosted: 19:59 - 13 Aug 2017    Post subject: Reply with quote
Have you checked all the bulbs?
Wheezybiker
PostPosted: 20:01 - 13 Aug 2017    Post subject: Reply with quote
Haynes or manufacturer manual should tell you
Nobby the Bastard
Harley Gaydar
PostPosted: 20:10 - 13 Aug 2017    Post subject: Reply with quote
Google is your friend...
https://www.biker.ie/forum/showthread.php?t=49923
Pay my incoming £1000 fine for speeding pls.
Sprint ST 1050
PostPosted: 10:47 - 14 Aug 2017    Post subject: Reply with quote
When you find it, assuming it's a PITA to replace, put an electronic one in there that'll flash at a constant rate over a wide range of wattages. They tend to be very reliable and will run both standard bulbs and LEDs or a mix of the two.
I'm rocking these ones if I need to replace a flasher relay. Pricier than many but very effective even on bikes with weedy charging systems.
https://www.ebay.co.uk/itm/12V-ELECTRONIC-INDICATOR-FLASHER-RELAY-CLASSIC-CAR-WITH-OE-CLICK-X-L-P-2-3-PIN-/181922797997
Make sure you order that one and not a positive earth one.
Robby
Dirty Old Man
PostPosted: 12:06 - 14 Aug 2017    Post subject: Reply with quote
It's more likely to be a blown bulb or two rather than the relay. If both of the rear indicators stopped working at the same time, see if the tail light and brake light also gave up - could be that the light cluster got unplugged, or its earthing wire (one wire serving all the rear lights and connected to the frame or the wiring loom) is disconnected or broken.
Indicator relays usually need all the bulbs in the circuit to work in order to flash. If one bulb is blown, then the remaining indicator bulb will light up but not flash.
Vivacity3
PostPosted: 16:13 - 16 Aug 2017    Post subject: Reply with quote
I have completely stripped every plastic panel from my moped today and there is no flasher relay ?
What happens is when I turn left or right ....it will stay constant light up on dash and none of the indicators flash only sign of power I get on the dash being constant lite up green.
Each indicator has about x4 mini bulbs in it not led but look like smaller version of 501 bulbs
I was playing around with my regulator when my battery was not charging and I fitted a 4 wire regulator to my 5 wire regulator wire but left the black disconnected I didn't charge battery so I put 5 wire regulator back on then I realized my headlight bulb was blown my rear 501 bulbs was blown and my Speedo sensor was blown and indicators not working
The fuse had a piece of wire in it so it burnt everything out
Do you guys reckon it could be x16 mini bulbs that it has blown then ????? As there is no flasher relay 100%
I chased whole loom no flasher relay
Please help please !
Thank you
Vivacity3
PostPosted: 16:24 - 16 Aug 2017    Post subject: Reply with quote
My indicator
Johnnythefox
PostPosted: 16:38 - 16 Aug 2017    Post subject: Reply with quote
look for this?
Vivacity3
PostPosted: 16:42 - 16 Aug 2017    Post subject: Reply with quote
I looked everywhere it don't exist on !y moped I looked everywhere
cb1rocket
PostPosted: 16:52 - 16 Aug 2017    Post subject: Reply with quote
Give us lots of photos of the bike stripped and the wiring. I'm certain we can show you
PostPosted: 17:56 - 16 Aug 2017    Post subject: Reply with quote
Can't see it in the parts fiche.
https://www.3xmotorcycles-superstore.com/products/PEPVI3V3L1254T/Vivacity-3-L-125-4T-Parts
Vivacity3
PostPosted: 18:50 - 16 Aug 2017    Post subject: Reply with quote
I know it's so strange ? How else would the indicators flash if there is no relay? I'm so confused it's doing my head in
Think I'm going to buy another regulator and go from there
As can't find an indicator relay only found cdi, regulator,starter relay.
I'm now out of MOT and trying to solve this problem
Kawasaki Jimbo
PostPosted: 18:55 - 16 Aug 2017    Post subject: Reply with quote
Not Peugeot but might be informative - https://www.pedparts.co.uk/blog/piaggio-gilera-led-indicator-flasher-relay-upgrade
cb1rocket
PostPosted: 20:57 - 16 Aug 2017    Post subject: Reply with quote
Follow the wiring from switch properly and see where it terminates. Then wire in a new relay
Vivacity3
PostPosted: 22:37 - 16 Aug 2017    Post subject: Reply with quote
Results !!!!! The flasher relay is built-in the regulator rectifier 😊
So I have to buy a new regulator rectifier to get my indicators to flash to pass MOT then send the £44 regulator back to eBay when MOT passes and stick my broken 1 back in till I can afford to buy the working regulator as pay day not till end of month and going in overdraft for a few days then hopefully they refund me 😎??
Thank you guys so much it was a pain bike stripped down for no reason at all but hey that's the joy of owning a ped/bike 😁😂😍
smallfrowne
PostPosted: 09:48 - 17 Aug 2017    Post subject: Reply with quote
Bet that's a relief, sort of. What a good bit of design.
You could probably chop the indicator wiring from the rectifier plug and route it to a standard flasher relay. Unless it's a really good bit of design and it's got magic wires too.
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
Vivacity3
PostPosted: 13:09 - 17 Aug 2017    Post subject: Reply with quote
I was thinking about that.
I got X5 wires red.black.green. at top of clip then at bottom of clip pink and yellow
How would I know what wires are the indicators ?
Also on eBay I have been offered a second hand regulator for my ped for £16 posted. I could afford this and keep it 1
But if I could wire a relay in place that would be better as I got a 2 pin 12v relay already
Vivacity3
PostPosted: 13:11 - 17 Aug 2017    Post subject: Reply with quote
My regulator looks like this guys
PostPosted: 13:17 - 17 Aug 2017    Post subject: Reply with quote
Just get the proper part. I'll save you time and money in the long run.
Evil Hans
PostPosted: 13:39 - 17 Aug 2017    Post subject: Reply with quote
Thought you said it was a 125? Wink
The last post was made 6 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.92 - MySQL Queries: 17 - Page Size: 128.88 Kb
