125cc Supermoto - 2 Stroke goodness
Bike Chat Forums Index -> General Bike Pictures Goto page Previous  1, 2, 3 ... , 13, 14, 15  Next
binge
Emo Kiddy
PostPosted: 15:42 - 13 Aug 2017    Post subject: Reply with quote
https://youtu.be/nkq7gTJZh7g
PostPosted: 17:36 - 13 Aug 2017    Post subject: Reply with quote
Hiya
Ouch on the radiator.
RS varies. Over a few thousand miles of general use mine (34mm carb) average 55mpg. Normal use about 50 but raised up a bit from running in (and the fuel strikes - ridden like very sedately it managed 74.5mpg Razz )
Katy
stevo as b4
PostPosted: 21:55 - 13 Aug 2017    Post subject: Reply with quote
She is sounding pretty good considering its not fully set up and it's only done 70miles or so. I reckon it'll sound a bit different after the dyno set up though as my crap two stroke ear, says it's not quite there jetting wise yet?
Pain on the sexy Rad leak though mate. Being alloy, I reckon for someone with the right gear, it'll be a 30second job hopefully for a drink token.
My 200 rad is at the most local alloy radiator specialist, and I've give them the go ahead to do an uprated thicker alloy replica. The quote made me almost spit my tea all over the floor, as it was about double what I'd expected.
Can't really put a price on keeping a tuned hotter running engine safe though, that's what I've told myself anyway. Laughing
binge
Emo Kiddy
PostPosted: 10:32 - 14 Aug 2017    Post subject: Reply with quote
Another little clip
https://youtu.be/BDzvqFOUkno
binge
Emo Kiddy
PostPosted: 21:56 - 14 Aug 2017    Post subject: Reply with quote
Okay.
It's booked in for a dyno on Friday.
If I was to fit a power valve after it's been set up. Will it need re jetting again?
Probably a question for Kickstart there. 😎
stevo as b4
PostPosted: 22:46 - 14 Aug 2017    Post subject: Reply with quote
Cool news!
I'm sure kickstart will know the answer to that, but when your at the dyno can you ask them to do a run with the power valve closed logging the fueling ratio, and then again for a run with the valve fixed open.
It would show you two things apart from the fueling changes needed. First it would show you how much midrange torque you gain with the power valve shut, and secondly where the two graphs cross it would show you the ideal rpm or close to it where you should want the power valve to open.
On my baseline run, I noticed that the fuel trace mirrors the dip in torque where my KIPS valve opens, and it momentarily goes lean, my guess is because there's suddenly much more air flow ability through the cylinder? I reckon that if your jetting is close that valve open or closed it won't change much apart from the transition between the two states.
PostPosted: 20:44 - 15 Aug 2017    Post subject: Reply with quote
As standard Aprilia didn't change the jetting on the older bikes when they restricted them. But that was comparing a moving power valve with the low power position blanking plate.
I would probably see how it goes when you fit the power valve.
Katy
binge
Emo Kiddy
PostPosted: 10:04 - 18 Aug 2017    Post subject: Reply with quote
Well, wont be dynoing it today.
Fucking rad has completely shat it's self.
So I've got a new one on order, should be here tomorrow.
And some new hoses as the old ones were a bit short and tightly pulled around the frame.
My pal has just bought a road legal Stomp pit bike with a CRF250 motor stuffed up it.
Cant wait to get out and have a blast with it. Wonder which bike will have the edge. 2t-125 or 4t-250.
PostPosted: 08:58 - 19 Aug 2017    Post subject: Reply with quote
If you are replacing the rad anyway, as a short term bodge some epoxy putty would probably work.
Katy
binge
Emo Kiddy
PostPosted: 19:01 - 22 Aug 2017    Post subject: Reply with quote
New rad fitted and filled up with water.
Quick road test yesterday, but the temp gauge has stopped working now. Laughing
This fucking bike.
Think it's just a flat battery. It's only a cheap gauge from OORacing.
One thing I noticed with the new rad. The water flows from bottom to top.
The old rad, it flowed from top to bottom.
Is that an issue?
https://scontent-lht6-1.xx.fbcdn.net/v/t1.0-9/20992940_526670074350689_6610207483855095394_n.jpg?oh=70401454c4040aa20e08d36670ecc3dd&oe=5A1EF5B4
I'm watching a few RotaxMax powervalve units on ebay. Missed the last 2 that were for sale.
Hopefully I'll get one and fit it before I get it back in for a Dyno.
My pals bike with the CRF250 lump in it.
It's built into a Stomp KZR frame. What I'd like to frame mine into eventually.
https://scontent-lht6-1.xx.fbcdn.net/v/t1.0-9/20881850_10212147820084116_7841892453880351097_n.jpg?oh=1d841a9a4da95e462ecbb71517ac4d1f&oe=5A1C7959
PostPosted: 19:09 - 22 Aug 2017    Post subject: Reply with quote
Is that an issue?
Very much an issue. Radiators work on the thermosyphon principle. Hot water enters the top and cools, gaining density which makes it fall lower in the radiator, drawing more hot water in the top and exiting colder water out the bottom.
Early cars had no water pump, they relied on this principle for the water flow.
Having said that, this article says that modern engines might be forced by the pump to run contrary to the natural thermosyphon so you might well be ok.
https://en.wikipedia.org/wiki/Thermosiphon#Engine_cooling
PostPosted: 19:23 - 22 Aug 2017    Post subject: Reply with quote
As Pete says, but how is it plumbed in to take coolant from the top of the engine and feed it to the bottom of the radiator? From the pics it looks like it would be possible to run the pipes to the other connections on the rad.
The Rotax water pump is not particularly powerful (impeller rather than pump). Doesn't need to be normally, but if pushing against natural water flow it might well struggle.
Katy
stevo as b4
PostPosted: 20:00 - 22 Aug 2017    Post subject: Reply with quote
Dude, I hope you can find an easy way to re route the pipes the other way, as I'd hate for you to cook a nice fresh Rotax if the current set up is an issue. If it's not cooling well enough this way, the dyno will kill it quickly, as bikes get hot quickly on the dyno anyway.
Oh and tell your mate that his bike has far too much engine forced to fit into far too little bike for anyone with an ounce of sanity! Laughing
Seriously though, a pit bike with a 14000rpm 40bhp 250 race engine must be one mean son of a bitch to try and use fully!
binge
Emo Kiddy
PostPosted: 10:13 - 23 Aug 2017    Post subject: Reply with quote
Yup. Top of engine to bottom left (near side) of rad.
It used to go to top left of rad but the new rad has a different lay out.
The right side (off side) of the rad has 2 ports. 1 top and 1 bottom.
Only other option is to see if I can cut a port off of the old rad and get it brazed onto the top left of the new rad. Giving it 4 ports. And just blanking off the spare 2.
binge
Emo Kiddy
PostPosted: 20:01 - 24 Aug 2017    Post subject: Reply with quote
And the 12's are on.
https://scontent-lht6-1.xx.fbcdn.net/v/t31.0-8/21013752_527939657557064_4098178256951719593_o.jpg?oh=882b5b9814d97a8dfa6f090fa39dd5ee&oe=5A31CBF4
Have another set of rims to fit some PMT Slicks to, for the track.
The PMT BlackFires that are currently fitted are road legal. Smile
Super stick tyres too. Start riding it properly now.
binge
Emo Kiddy
PostPosted: 14:16 - 27 Aug 2017    Post subject: Reply with quote
Well I should have put the thing on 12's from the start.
A totally different bike. Rides like a supermoto pit bike now. Can bank it over like my race bike without any fear of losing grip.
Went for a little rip with my pal on his 250 the other day.
Got my arse royally handed to me. No comparison what so ever!
I was hammering the life out of the Rotax, and the CRF250 pit bike was just lifting the front wheel and taking off, every time. Laughing
The thing is an absolute demon! Twisted Evil
https://scontent-lht6-1.xx.fbcdn.net/v/t31.0-8/21055846_528429804174716_5965641853653993877_o.jpg?oh=6225808617fbe164f3cf8393e514b5e5&oe=5A5B27FB
stevo as b4
PostPosted: 16:01 - 28 Aug 2017    Post subject: Reply with quote
That thing instantly looks as fucking hard as nails, with the 12's on instead! Can't believe the difference tbh!
And I'm a fan of cast alloy wheels, and liked the look alot before. Has the gearing changed much with the new wheels?
Oh and your mate is a total deranged loonie +100 Laughing
binge
Emo Kiddy
PostPosted: 18:56 - 12 Sep 2017    Post subject: Reply with quote
https://scontent-lht6-1.xx.fbcdn.net/v/t31.0-8/21318984_533595743658122_2339664316720284000_o.jpg?oh=8a8178cc88b55954d38c0fcdcbda85e5&oe=5A1B078C
binge
Emo Kiddy
PostPosted: 08:47 - 13 Sep 2017    Post subject: Reply with quote
Cracking day on track at Rowrah.
The 2-stroke had the pace to stay with most of the CRF150s qnd the KTM105, but It was the set up and myself holding it back.
Gonna spend a bit more time working with the suspension and geometry, and have another crack at Whilton Mill in October.
Footpegs are off, I'm making up some plates to move them a good 2 to 3 inches higher up, as cornering clearance was a real issue.
https://scontent-lhr3-1.xx.fbcdn.net/v/t31.0-8/21752761_536134063404290_5106462130831485801_o.jpg?oh=2f93a3fdddeb6c1e325ca9adb4f28879&oe=5A17C91F
https://scontent-lhr3-1.xx.fbcdn.net/v/t31.0-8/21728817_536133760070987_3036132355054115531_o.jpg?oh=a4778cad6cbf05ab95e2b343e52d058e&oe=5A602C5A
stevo as b4
PostPosted: 18:24 - 14 Sep 2017    Post subject: Reply with quote
Fucking love it!
You've gotta make that pic your screen saver too! Thumbs Up
Seeing the Rotax pit chasing down a CRF150 race bike is just epic tbh!
I knew it would have pace, I guess it's making as usable a possible and making it handle how you want it to is the key.
Need a sound clip of this thing on a track though x100! Smile
binge
Emo Kiddy
PostPosted: 18:37 - 29 Sep 2017    Post subject: Reply with quote
Had a little tinker this morning.
I've gone up to a 41t rear sprocket now, making the gearing a lot shorter than it was.
Original set up was 13" wheels, with 17:40 sprockets.
Then went to 12" wheels, with 15:39 sprockets.
But now i've gone with 15:41 sprockets on the 12s, and I think, I may even get away with dropping the front to a 14 for some of the smaller tracks, as I was only getting into 4th gear at Rowrah, and that's got some long straights on it.
I've moved the foot pegs up to 320mm (From 260mm) so have plenty of ground clearance now.
Enough to drop yokes down a bit on the forks to assist with faster turning in.
I've bought a coolant temp sensor which needs fitting.
And I've fitted a new number board, without a headlight.
Full track ready now.
And I'm in talks about having a nice seat cover made up as the cheapy one that's on it has ripped.
Hopefully I will be able to get it on a dyno before Whilton Mill next month.
https://scontent-lht6-1.xx.fbcdn.net/v/t31.0-8/22047906_543561339328229_3325367266449317824_o.jpg?oh=b36996c57d2f7d45d9483164dd1cb82b&oe=5A3C1981
https://scontent-lht6-1.xx.fbcdn.net/v/t31.0-8/22048021_543724105978619_4703465073735910621_o.jpg?oh=b60c8b738716cc37a7bffcf49496b171&oe=5A8891A6
stevo as b4
PostPosted: 22:26 - 29 Sep 2017    Post subject: Reply with quote
Looks tough as fuck on 12's with slicks! Thumbs Up
Interested to see what it makes on the dyno too! What is it geared for now 75ish?
binge
Emo Kiddy
PostPosted: 08:41 - 30 Sep 2017    Post subject: Reply with quote
Maybe slightly less.
Sure Kickstart will be able to help with the math. Smile
binge
Emo Kiddy
PostPosted: 10:23 - 02 Oct 2017    Post subject: Reply with quote
Booked and paid for Round-10 Whilton Mill.
Doing double practice on the Saturday, but only racing the open class (on the pit bike) on Sunday, as I'm only there to battle for the championship.
Currently in 1st place in the open class, 2nd is about 8 points shy of me. It's all to play for.
But, booked for Stock and open practice on the Saturday, so I can take the Aprilia and have some fun again. Very Happy
https://scontent-lht6-1.xx.fbcdn.net/v/t31.0-8/22104416_544605372557159_4664412235190018679_o.jpg?oh=a650d5294f8b7b521927ce39b7cf8a8b&oe=5A4B0F8C
binge
Emo Kiddy
PostPosted: 18:07 - 16 Oct 2017    Post subject: Reply with quote
I've bought a new frame to build the Rotax into.
It's proper pit bike sized, and will work better with my seat, plastics etc.
Lighter and smaller than the current frame too.
Not road legal unfortunately, but I'm not overly fussed. I'll be sticking the old frame up for sale, along with the yokes, forks, and wheels.
https://scontent-lht6-1.xx.fbcdn.net/v/t31.0-8/22467388_550688661948830_8440321018540355688_o.jpg?oh=32b0e4e6eeea727c50900575d316576e&oe=5A714CDD
The last post was made 8 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Page 14 of 15
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.21 - MySQL Queries: 16 - Page Size: 142.62 Kb
