Author |
Mark65 |
Mark65 World Chat Champion
Posted: 10:08 - 17 Aug 2017 Post subject: Fitting New Stator Cover |
Hi,
I will be fitting my new genny cover next week, it has no paper gasket so uses a silicone sealant, My local Honda uses Wurth Super RTV (black), I also see a Honda Bond 08718-0004 and the 13-15 manual says ThreeBond TB1207B Black Silicone Liq. Gasket, they are all about the same price and non acidic. Or its equivalent, has anybody used these before.
thanks ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
Back to top |
jaffa90 |
jaffa90 World Chat Champion
Back to top |
stinkwheel |
Back to top |
Mark65 |
Back to top |
stinkwheel |
Posted: 13:23 - 17 Aug 2017 Post subject: |
100g will probably do the job 20 times over. All you need is a thin smear. Seal the end properly and keep it in the fridge in a zip lock bag to make it keep for longer (but get it back to room temp before using).
I personally use stuff called Permabond A136 on mating surfaces like that. It goes on as a liquid and smells of bubble gum. Quite expensive though. My 50ml bottle has lasted for years. Done several engine rebuilds with it. I like the way it remains a liquid until compressed so you can wipe off excess with a cloth and it's less likely to clogg oilways if you get any squeezout on the inside.
I suppose the thing is you're just wanting a flange sealant of some description. Blue hylomar would be fine too, or loctite flange sealant. The threebond is what it would have come with from the factory.
I would be less fussy about your brand of medium grip thread lock. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
Mark65 |
Posted: 15:50 - 23 Aug 2017 Post subject: |
Well that wasn't to bad, the casing was sticking on the lower dowel pin, once off I could see why, didn't look like any sealant was in front so allowed moisture between casing and had sandy brown deposits on there. The stator wiring was a bit fiddly to get through the frame as well.
Your right about a smear of sealant, I used the end of a model brush to smear it on very thinly after using the old casing for practice, when casing was joined and tightened only a tiny amount squeezed out, like a 1mm bit that just wiped off, put it back together and washed it, will take it for a test ride tommorow. I think I under torqued the stator bolts by 2 ft lbs but used the three bond thread lock so hopefully it won't come off.
Well that's a bit more confidence gained, thanks all. ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
Back to top |
The last post was made 6 years, 246 days ago. Instead of replying here, would creating a new thread be more useful? |
