Will pay for answering! Peugeot Vivacity 3 125cc
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2, 3  Next
Vivacity3
PostPosted: 13:43 - 17 Aug 2017    Post subject: Reply with quote
It is a 125cc
I just got a second hand regulator for £14 posted now even better price eBay is good
Evil Hans
PostPosted: 13:47 - 17 Aug 2017    Post subject: Reply with quote
Vivacity3 wrote:
It is a 125cc
Thought you said it was a moped? Wink
Triumph Sprint ST 1050. And it's Red.
Vivacity3
PostPosted: 13:55 - 17 Aug 2017    Post subject: Reply with quote
It's a 125cc moped Peugeot Vivacity 3 sixties 2011
French piece of SH*T !
But I love it for my city riding and keeps my R1 big bang safely in garage warm and safe
Evil Hans
PostPosted: 13:59 - 17 Aug 2017    Post subject: Reply with quote
Heh - the point I'm trying to make is that it is not a moped. In the UK mopeds are < 50cc and limited to about 45kph.
What you have, my friend, is a scooter.
smallfrowne
PostPosted: 15:55 - 17 Aug 2017    Post subject: Reply with quote
Vivacity3 wrote:
Results !!!!! The flasher relay is built-in the regulator rectifier 😊
Hang on though, how did you confirm the rectifier is acting as the flasher relay? That picture looks like a bog standard rectifer/regulator to me. I'm not convinced Very Happy
I know you've stripped the thing down and found nowt but I just looked in the Haynes book and saw this, though bear in mind I think it only covers years up to about 2005:
Haynes wrote:
If the bulbs and sockets are good, test the signal relay. On Speedfight models remove the top handlebar cover, on Trekker models remove the headlight panel and on Vivacity models remove the front panel to access the relay (see Chapter 7).
Note: The signal relay on later Vivacity Sportline
models (with the electronic speedometer) is integral with the instrument cluster (see Step 7).
Step 7:
On Vivacity Sportline models, remove the
rear handlebar cover and disconnect the
instrument cluster multi-pin connector (see
Chapter 7). Check for voltage at the black wire
terminal in the connector (see Step 4). If there
is voltage, reconnect the connector and use
the test light to check the output from the
purple wire terminal in the connector (see
Step 5). The light should flash; if it does not,
the relay has failed. It is not possible to renew
the cluster relay, but a new relay can be wired
into the turn signal circuit (consult a Peugeot
dealer or electrical specialist).
So... is it hidden in the instrument cluster?
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
Vivacity3
PostPosted: 17:40 - 17 Aug 2017    Post subject: Reply with quote
Ohh my god ! Maybe your right it's hidden inside the instrument then ? I already paid for regulator now lol
So if it still don't work I got to wire relay in there ? ! What a pain !
I dont even know how to do that
Proper crazy as I think your right ...
Vivacity3
PostPosted: 17:53 - 17 Aug 2017    Post subject: Reply with quote
Also that would kinda make sense as my Speedo Digi stopped working same time as my indicators did lol
Nobby the Bastard
Harley Gaydar
PostPosted: 18:08 - 17 Aug 2017    Post subject: Reply with quote
Do you like to enjoy the feel of wind in your big gaping vagina?
Sprint ST 1050
Vivacity3
PostPosted: 18:19 - 17 Aug 2017    Post subject: Reply with quote
Hahaahahha your funny
It's a city moped so many big bikes have been stolen from car park I park moped .... My moped is always there and locks chopped and bikes missing and police nearly every day and it's a 24hr right guard security car park in London.
My moped always there sometimes knocked over but always there and my big bang is safe in my garage waiting for me at weekends
I ride moped all week then big bang sat and sun 😎
Evil Hans
PostPosted: 18:22 - 17 Aug 2017    Post subject: Reply with quote
I think we've established that it's not a moped?
The term moped (assigned category AM on a UK driving licence) describes any low-powered motor driven cycle with an engine capacity not greater than 50 cc (3.1 cu in) and a maximum design speed of no more than 45 km/h (28 mph). Before 19 January 2013, the speed restriction was 50 kilometres per hour (31 mph), and mopeds registered before 1 September 1977 were required to have pedal-assistance.
Vivacity3
PostPosted: 18:33 - 17 Aug 2017    Post subject: Reply with quote
Well I learned something new 😃
Nobby the Bastard
Harley Gaydar
PostPosted: 18:38 - 17 Aug 2017    Post subject: Reply with quote
There isn' really a big bang R1. There's the normal straight 4 configeration thats used by most in line 4 bikes and cars and then there's the crossplane.
'Big bang' is a two stroke thing....
Sprint ST 1050
Vivacity3
PostPosted: 23:28 - 17 Aug 2017    Post subject: Reply with quote
How do I wire a new relay flasher to bypass my dead cluster relay that is built in to my speedometer instrument unit
The purple wire is dead and life from it when it should have life
smallfrowne
PostPosted: 14:35 - 18 Aug 2017    Post subject: Reply with quote
You want to make your wiring look something like this:
(obviously only focus on the wires going to and from the indicators.
https://i.imgur.com/dfHcnsz.png
Looks like you'll need to install a relay by tapping into a black wire (which is 12v supply with ignition on) to one side of the relay and the other side going to the indicator switch (purple wire). This is for a 2 pin relay, if you end up with a 3 pin one you will also have to connect its ground connection to ground (green).
Vivacity3
PostPosted: 16:59 - 18 Aug 2017    Post subject: Reply with quote
Sweet mate I give it ago tomorrow and let you guys know if it works or not as a new speedometer instrument is £147
Even eBay want like £70-85 lol
I only want indicators working lol
Vivacity3
PostPosted: 19:45 - 18 Aug 2017    Post subject: Reply with quote
Hiya
I tap in to black wire today connected the B to black wire and connected L to snipped purple wire
Tried indicators and nothing happened it done the same thing only lit up the dash and stayed green
I have now ordered a second hand Speedo instrument unit for £25 POSTED.
I'm hoping this will fix the Speedo and the indicators
Embarassed Evil or Very Mad
UnspeedySam
PostPosted: 00:00 - 19 Aug 2017    Post subject: Reply with quote
Nobby the Bastard wrote:
Google is your friend...
https://www.biker.ie/forum/showthread.php?t=49923
Pay my incoming £1000 fine for speeding pls.
This all seems a bit mental. Have you checked under the battery, as per nobby's post yet?
Riding: Does an Audi estate count?
Fixing: Honda VFR750 RC36 '94 and MZ ETZ 251 '90
Gone: ZZR600 '00, TRX850 '97, RXS100 '93, JS125-6B '07, BMW R1100RS '93, Kawasaki ZX-6R-J2 '01,Honda Bros NT400 NC25 '88
Nobby the Bastard
Harley Gaydar
PostPosted: 09:32 - 19 Aug 2017    Post subject: Reply with quote
the black wire is the live one. Check that you get 12v from it. You should be able to get continuity on the purple wire to earth when the switch is in either on positions.
Sprint ST 1050
Johnnythefox
PostPosted: 09:51 - 19 Aug 2017    Post subject: Reply with quote
earth if all bulbs intact?
Vivacity3
PostPosted: 14:42 - 19 Aug 2017    Post subject: Reply with quote
I have checked under the battery nothing there
It's inside the cluster unit built in m going with
I've got a new speedometer unit on way and I'm going to replace all x16 T5 amber indicator bulbs at same time
Hopefully my Speedo will work again with new as that stopped same time my indicators stopped
Parts arrive Wednesday fingers crossed it's just the instrument that needs replacing only
As all them tiny bulbs going to be a pain to replace I've not even tested bulbs as I believe it's the relay as I played around and tryed to bodge a chiense 125 regulator in there and left a black wire disconnected then that's when all my problems happened . I put original regulator back in there and found out indicators and Speedo not working also my main headlight bulb was blown aswel
I didn't turn on the indicators for them to blow that's why I think it's the cluster relay inside the instrument as someone on here told me
If it is inside the cluster and my new speedometer cluster should fix it all if so I'll send the guy some money on here
Nobby the Bastard
Harley Gaydar
PostPosted: 18:52 - 19 Aug 2017    Post subject: Reply with quote
have you checked that you are getting 12 volts on the black wire? I bet you aren't and thats why the indicators and speedo don't work.
Sprint ST 1050
Vivacity3
PostPosted: 18:59 - 19 Aug 2017    Post subject: Reply with quote
Yes I'm getting power from the black wire only when the key is on
Vivacity3
PostPosted: 21:43 - 25 Aug 2017    Post subject: Reply with quote
New Speedo instrument arrived I fitted it the Speedo is now working but still no indicators ?????????
Indicators are doing same thing as old instrument !!! Absolutely no power only silly constant green light on instrument only !!!!!!!
Please help in Changing all x16 bulbs tomorrow
Nobby the Bastard
Harley Gaydar
PostPosted: 11:15 - 26 Aug 2017    Post subject: Reply with quote
Told you.....
Have you checked that you get power in the purple wire at one of the bulbs when you have the indicators are on?
Sprint ST 1050
Vivacity3
PostPosted: 15:03 - 26 Aug 2017    Post subject: Reply with quote
It was the bulbs 😱
All bulbs blown replaced all x14 bulbs today and now I got indicators working and Speedo works good
Thank you guys for all your help .... Time I MOT the scooter now as been riding nearly 2 weeks with no MOT 😥
The last post was made 6 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.32 - MySQL Queries: 17 - Page Size: 135.4 Kb
