Author |
Jay2903 |
Jay2903 Scooby Slapper
Back to top |
jaffa90 |
jaffa90 World Chat Champion
Back to top |
bypass2 |
bypass2 Spanner Monkey
Back to top |
Bru |
Bru Trackday Trickster
Back to top |
Jay2903 |
Back to top |
Jay2903 |
Back to top |
Jay2903 |
Back to top |
Jay2903 |
Back to top |
Suntan Sid |
Posted: 22:15 - 23 Aug 2017 Post subject: |
Plug leads and earth connections ____________________ "Everybody needs money, that's why they call it money!" |
Back to top |
bypass2 |
Back to top |
Jay2903 |
Back to top |
Jay2903 |
Back to top |
jaffa90 |
Back to top |
Jay2903 |
Back to top |
jaffa90 |
Back to top |
jjdugen |
jjdugen World Chat Champion
Back to top |
Jay2903 |
Back to top |
redeem ouzzer |
Back to top |
Jay2903 |
Back to top |
Bru |
Posted: 19:10 - 24 Aug 2017 Post subject: |
Hi. If you are convinced that your electricals are good, then it is back to the carbs. A severely blackened plug suggests an overly rich mixture.
Could be float height, as suggested earlier. Or a sticking float or float needle, not allowing fuel in the carb... Unfortunately as I have learned, carbs need to cleaned scrupulously. Despite cleaning the carbs out (and how well did you do it), the miserable things do like a good clogging; it could even be something irritating like muck from the tank clogging the carbs, depending on how good that fuel filter is (or if it was fitted from the start).
Clearance checks are vital; is there any chance that something is not opening, or opening too much, so messing up the running - along with any carb problem?
Air, fuel, spark... Have you tried spraying the outside of the carb rubbers (between carb and head) with carb cleaner, to see if the engine picks up? Could be an air leak running a cylinder lean... Constant refitting of carbs and rubbers can put a kink in the works. |
Back to top |
Jay2903 |
Posted: 19:21 - 24 Aug 2017 Post subject: |
Bru wrote: | Hi. If you are convinced that your electricals are good, then it is back to the carbs. A severely blackened plug suggests an overly rich mixture.
I still think it's electrical.
Carbs are clean + nothing is sticking. I've been through them twice and the fuel tank is clean too
Back to top |
Jay2903 |
Back to top |
temeluchus |
Back to top |
bypass2 |
Back to top |
Bru |
Back to top |
The last post was made 6 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
