Exhaust linkage
Renzakuken
PostPosted: 13:34 - 25 Aug 2017    Post subject: Exhaust linkage Reply with quote
Hello all
I've just fitted a second hand beowulf exhaust to my gsx650f
I've noticed the join isn't great and the supplied linkage let's both noise and fumes out.
What's the best solution to this? Can I just wrap it in some thing or does anyone know a seller whod provide a replacement link?
Picture for reference
https://preview.ibb.co/g9JvZ5/DSC_2278.jpg
how do i upload images to the forum
CBR 125 2006 STOLEN
GSX600F 2003 SOLD
GSX650F 2009 CURRENT
el_oso
PostPosted: 14:44 - 25 Aug 2017    Post subject: Reply with quote
look up gungum by holts. They sell it Halfords, I've previously used this and works fairly well. Sets rock hard though so can be difficult to remove.
Next time I need to seal up and exhaust I'm going to give some heat resistant silicone a go, something that you'd use to seal around the flue for your boiler. They sell these kind of products in screwfix under the fire and heat sealants.
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 15:22 - 25 Aug 2017    Post subject: Reply with quote
I just use generic silicone sealant rather than high heat stuff. It's been fine from the collector backwards so far.
Islander
PostPosted: 16:08 - 25 Aug 2017    Post subject: Reply with quote
Or fit the graphite collar that's supposed to be in the joint Wink
P.
PostPosted: 18:43 - 25 Aug 2017    Post subject: Reply with quote
Might be my phone..but it looks to be there... Sitting after the fucking pipe Laughing rather than in.
Islander
PostPosted: 19:24 - 25 Aug 2017    Post subject: Reply with quote
I think you may just be right about that. Laughing
P.
PostPosted: 20:19 - 25 Aug 2017    Post subject: Reply with quote
If you are near me, we can refit the exhaust but that gasket thing needs to be inside the shiny new pipe and then clamped. Open up the new pipe a little and squish on. Bolt up and boom.
Renzakuken
PostPosted: 18:19 - 05 Sep 2017    Post subject: Solved (i think) Reply with quote
Hello all
Thank you for the very helpful & informative replies. What i've opted for a is a sealant on the outside of the pipe leading from the cat, which is sandwiched when I've installed the beowulf. I forget the brand but the heat causes it to harden and air-tight seal.
For good measure I've also used Exhaust wrap from Deamon Tweaks and then clamped it down using a jubilee clip.
Safe to say it's neither coming off any time soon and is no longer leaking.
CBR 125 2006 STOLEN
GSX600F 2003 SOLD
PostPosted: 18:44 - 05 Sep 2017    Post subject: Reply with quote
So you've opted to ignore the factory gasket designed to seal the pipe properly which is still in place and ready to use - in favour of bodging it with tape and gum.
Can't help some people...
Matt B
PostPosted: 08:16 - 06 Sep 2017    Post subject: Reply with quote
To be fair not all link pipes on the Bandit/GSX retain that OE gasket. The Scorpion link pipe on my 1200 did, but the Pipewerx one on the GSX1250 doesn't use it and has a smaller diameter on that end as a result.
Hard to say with the pic what's going on there, but it doesn't look right though.
P.
PostPosted: 10:57 - 06 Sep 2017    Post subject: Reply with quote
The graphite one is just chilling there. I'd have just slightly opened the end up, pushed the graphite one in slightly and worked it on gently.
*depending on mood that is... some times I just wanna fucking hammer it.
PostPosted: 12:36 - 06 Sep 2017    Post subject: Reply with quote
No, really Shocked I can't believe that Paddy Laughing
Triumph Trophy Launch Edition
The last post was made 8 years, 105 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.89 - MySQL Queries: 16 - Page Size: 76.87 Kb
