Author |
Ayup_Mi-Duck |
Ayup_Mi-Duck Renault 5 Driver
Posted: 20:07 - 17 Sep 2017 Post subject: 91 ZZR 600: rear hub/wheel/swing arm affair |
Hi there guys.
Could someone please tell me what could have happened here?
the wheel had cocked over to the side and the sprocket bolts have machined out a bit of the swing arm.
think this is just the bearing shitting its pants or could it have been something else?
Im a bit fucked off [/img] ____________________ Pump, Pump, Squirt.
Back to top |
RhynoCZ |
RhynoCZ Super Spammer
Posted: 20:13 - 17 Sep 2017 Post subject: |
What happened there is, that photobucket changed their policy, so now you have to pay them, so you can post your pictures here. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Back to top |
johnsmith222 |
johnsmith222 World Chat Champion
Back to top |
Ayup_Mi-Duck |
Back to top |
johnsmith222 |
Back to top |
johnsmith222 |
Back to top |
johnsmith222 |
Posted: 20:35 - 17 Sep 2017 Post subject: |
https://imgur.com/a/EWLpM
ive added a black number 1 - this is the spacer that slides into the sprocket carrier bearing.
2 - outside spacer
3 - sprocket carrier bearing. |
Back to top |
Ayup_Mi-Duck |
Posted: 20:40 - 17 Sep 2017 Post subject: |
bluezedd wrote: | While you have the wheel off, check the rear wheel bearings. Those are the bearings that are still attached to the wheel.
If suspect on a bike that age, you might as well replace them. It's these bearings that have a tube between them.
The part that you actually show in your pic is the sprocket carrier bearing. It looks like it's actually this bearing which has killed itself. I can't confirm the condition of the rear wheel bearings.
If i remember correctly, there is a spacer which slides into the sprocket carrier bearing, and sigs against the wheel bearing. Check this is present.
Also, there should be a spacer on the outside of the sprocket carrier, between the swingarm and the outside of the sprocket carrier.
If you have any spacers missing. Get them from cornwall kawasaki.
Any bearings you could get cheaper from wemoto etc. |
I think you might be on to somethign there. Now I think about it, the wheel was sitting true but the carrier was cocked over/ hanging out.
I replaced the tyre a while back and when removing it, laid the parts out as they came off, i then put them back on as they were. I think I will just buy all the parts, clean it up, give it the lube and see how it goes... hope its not spragged the swing arm out....... that would be mega lolz.... ____________________ Pump, Pump, Squirt. |
Back to top |
skatefreak |
Back to top |
The last post was made 6 years, 224 days ago. Instead of replying here, would creating a new thread be more useful? |
