WAY too low geared.
lingeringstin...
PostPosted: 11:30 - 14 Sep 2017    Post subject: WAY too low geared. Reply with quote
New Chinese engine on bike, 15 front sprocket and 43 rear sprocket, 16" wheels. Went through all five gears within about a hundred yards. Could have crawled up the side of a house if I could get the traction. Smallest blip on the throttle was, as Clarkson says, POWER!
The problem is that I'm using 428 chain and sprockets whereas everything else that uses this engine seems to run 520 so I could find no information about sprocket sizes for 428.
And yes I know any "normal" person would just use 520 chain and an 18" wheel and be done with it but over the last couple of years I'd bought two identical 16" cast wheels that had sprocket carriers to take 428 sprockets for the rear of my bike when I was running an MZ engine.
Then I went and changed engines.
It took a shitload of research to find out what 428 sprockets would fit my new engine and be readily available at a decent price (cheap). You can always find a sprocket for anything if you just search for it by make and model, but the moment you start doing weird shit you're on your own and it's no use just trying to get the same tooth sprockets the MZ used because the gearboxes will be wildly different between the two engines and anyway the new engine is made in such a way that it can't take anything as big as an MZ front sprocket.
Other sprockets have been ordered now based on scribbles and conjecture. I'll have to see what happens.
DrDonnyBrago
PostPosted: 13:29 - 14 Sep 2017    Post subject: Reply with quote
Ok.
PostPosted: 13:32 - 14 Sep 2017    Post subject: Reply with quote
Balloon tyres are clearly the answer. Like those MZ swamp bikes.
lingeringstin...
PostPosted: 20:47 - 15 Sep 2017    Post subject: Reply with quote
It gets worse. Today I've been going around on 17/35 sprockets. Still way too low geared but could cruise at 40 without nailing the engine too much. Anything more than 40 and the engine would be screaming.
I am determined to stick with my 16" wheels. I quite like scuttling around at door handle level. In my experience really low bikes feel much more stable in dodgy conditions.
I have now ordered an 18t front sprocket, which there may not be room for on the engine but there's no way to know until it comes, and I've also ordered a 31t rear sprocket which is the smallest 428 one the JT catalog has listed that will fit my cush drive.
Rear sprockets of less than 31t are available but not ones that fit my cush drive so if I want to keep using the wheels I've already got then it's going to be adapter time which shouldn't be a problem to make if I have to using strimmer line, Super Glue, and walnuts mixed with the jellified foetus of an unborn Irishman's bairn at full moon, shot of scotch please, no water.
https://s26.postimg.org/hya3j5kcp/sprocket.jpg
Stoker
PostPosted: 21:56 - 15 Sep 2017    Post subject: Reply with quote
Front sprockets are easy, rears maybe too if you know someone with a lathe.
Front, Assuming that your existing front sprocket has useable splines, machine it down to a radius that can be combined with the machined internal radius of your new sprocket, get them tig'd together. Have used this method to keep a friends classic twinshock bikes running at trials.
Rear, have replaced like-for like gearing with different mountings using the same method.
lingeringstin...
PostPosted: 15:20 - 16 Sep 2017    Post subject: Reply with quote
The problem with the front sprocket is that there's only enough room on the engine to fit a 17 or 18. There's just no more room in there without taking the engine out, taking it apart and having the sprocket area on the engine case widened out, which is far too much trouble and expense to go to.
The rear is going to be the easiest way to go. I can't get a sprocket of the right number of teeth that will fit my cush drive so I'll just use an existing sprocket that does fit as an adapter. Easiest thing would be to lathe the teeth off my current sprocket so it's just a disc and then drill apprtopriate holes to accept a rear sprocket of the correct number of teeth for the gearing I desire.
Alignment won't be a problem. The front sprocket shaft is made in such a way that I've got a couple of inches leeway along the shaft and can use washers as spacers to line everything up.
The engine is a Honda copy which seems so far to be a very good copy that has almost universal parts interchangeability with Honda parts. Only differences I've found so far is that it uses a single cam chain instead of a double roller one like in a Honda engine.
The Honda engine this was cloned from seems to always be used with taller wheels than the 16" ones I'm using, and all the Hondas I've seen with that engine are much heavier than the skeletal framed MZ contraption I'm using now, so I can easily handle higher gearing than a normal Honda which is why I'm scratching about for sprockets. If people are claiming a truthful 80mph out of a Rebel, which is much heavier than my bike, then I'm sure I'll be happy with whatever mine does.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:50 - 16 Sep 2017    Post subject: Reply with quote
That extra half inch makes all the difference, as the prossy said to the bishop.
Sprint ST 1050
tom_e
PostPosted: 20:54 - 16 Sep 2017    Post subject: Reply with quote
I’m sure there’s a few places that can knock you up some custom rear sprockets with however many teeth you like and the correct shape to fit your setup for not too much cash. I’m sure Katy mentioned a place in another thread not long ago.
lingeringstin...
PostPosted: 14:31 - 19 Sep 2017    Post subject: Reply with quote
It would be nice to find custom sprockets at a reasonable price. I haven't looked into it for years but the last time I did was trying to work on vintage vehicles and they wanted a fortune just to make a sprocket so we resorted to cutting other things up and using a lathe to modify parts. Trouble is I don't have access to a lather anymore.
But I will check into custom sprockets. Most things are vastly easier to make nowadays than they were when I was working on vintage vehicles. Back then there were no computer controlled machines and a lot was done by hand. I would imaging a modern computer-encrusted "sprocket making machine" could knock up a sprocket to your own design specifics with no more trouble than making an OEM one.
lingeringstin...
PostPosted: 19:31 - 19 Sep 2017    Post subject: Reply with quote
Let's do a few calculations shall we?
Lower seat height by a couple of inches.
Going from 18" to 16" wheels means an inch lower.
Using struts in place of MZ shocks means a minimum of 6" lower, probably more.
Squishy air pressure in rear tyre can mean another inch lower.
Lowering the front end considerably also lowers things out a bit everywhere else.
So that's roughly about 9" give or take a bit, said the Bishop to the actress.
nowhere.elysium
The Pork Lord
PostPosted: 20:21 - 19 Sep 2017    Post subject: Reply with quote
You know what, this is just about demented enough a project for me to express an interest. I have a lathe, a mill, and a rotary table. If you can get me a suitably-sized chunk of billet, I may well be able to knock out a workable sprocket.
PostPosted: 21:12 - 19 Sep 2017    Post subject: Reply with quote
Get some more experience.
The stability isn't related to the height specifically - I have plnety of low bikes and generally they're much less stable due to smaller wheels.
Smaller wheels reduce stability not increase it, all things being the same.
Some time ago I got a +10 rear sprocket made up for a CRM125 for a not unreasonable price from some, err, British company that makes sprockets.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:35 - 19 Sep 2017    Post subject: Reply with quote
I didn't say that....
Sprint ST 1050
Nobby the Bastard
Harley Gaydar
PostPosted: 21:36 - 19 Sep 2017    Post subject: Reply with quote
But if you go back to 18" wheels it'll still only be an inch taller (I said half an inch cause I expected 17 inch wheels)
Sprint ST 1050
PostPosted: 22:28 - 19 Sep 2017    Post subject: Reply with quote
My bad - removed wrong quote.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:08 - 20 Sep 2017    Post subject: Reply with quote
NP - so long as you bring the bikes to bbq again...
Sprint ST 1050
PostPosted: 21:13 - 20 Sep 2017    Post subject: Reply with quote
We'll see - if someone could see to getting me one of these and somewhere to store it, it'd make that a lot more achievable! Razz
https://i.ebayimg.com/images/g/MI8AAOSwi8VZO~oL/s-l1600.jpg
(Unfortunately with plans for the week after, emptying and reloading the van caused a lot of stress and lost work etc Sad ... it did look like there'd be a week gap next year, but they got the dates wrong and there's not.)
The last post was made 6 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.6 - MySQL Queries: 17 - Page Size: 101.59 Kb
