Brake Levers
rudyperon
PostPosted: 10:38 - 16 Sep 2017    Post subject: Brake Levers Reply with quote
Hi.
I owned a 2016 Triumph Daytona 675R.
Brembo brakes and Ohlins suspensions.
A friend low sided my bike last Track Day.
Minor damages and was replaced.
My brake lever, that comes with Brembo Master Pump was slightly bent.
1. Is it possible to repair by applying heat and bend back to original state?
2. Can I use Non.R brake lever as replacement?
Thanks.
Rudy
kramdra
PostPosted: 17:48 - 19 Sep 2017    Post subject: Reply with quote
Nope alu does not like being worked, get a new one
PostPosted: 23:27 - 19 Sep 2017    Post subject: Reply with quote
Yes, I've straightened many levers but it needs to be done carefully and with knowledge of the metallurgical consequences of doing so.
You need to heat it to within a ballhair of molten so the metal becomes plastic. You re-bend it once and once only, don't try for perfection.
Then you need to heat the metal to near plasticity and slowly cool several times to re-anneal it becaue it has effectively been cold-worked.
If you rub soap on the metal. It'll burn to carbon. When the carbon starts to burn off, you are pretty much at the correct temperature.
After having done all this, I then try to break it.
Replacement Brembo levers are £35.
c_dug
PostPosted: 16:06 - 08 Oct 2017    Post subject: Reply with quote
Sorry to dig up a dying thread, but I had a go a straightening my clutch lever today, with surprising results in both success and colouration:
https://i.imgur.com/gNlpkSJ.jpg
Just thought I'd share.
Tankie
PostPosted: 19:25 - 08 Oct 2017    Post subject: Reply with quote
Novel , but it worked .
The last post was made 6 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 17 - Page Size: 44.95 Kb
