cracked engine case, replacement sought
Renzakuken
PostPosted: 18:44 - 19 Sep 2017    Post subject: cracked engine case, replacement sought Reply with quote
Good evening all
Does anyone know where I can find a working engine case for the left side of my GSX650f?
I worry that buying off ebay and getting a scuffed second hand unit may cause more problems.
Currently a small amount of oil drips out of my engine case when it's on the side stand, i've no idea how much comes out when riding but frankly it doesn't bear thinking about.
CBR 125 2006 STOLEN
GSX600F 2003 SOLD
GSX650F 2009 CURRENT
mudcow007
PostPosted: 13:25 - 20 Sep 2017    Post subject: Reply with quote
is yours cracked?
leaking from gasket?
why dont you spray brake cleaner all over the cases to clean em up. start the bike on the stand an watch to see where its dripping from?
Teflon-Mike
tl;dr
PostPosted: 18:38 - 20 Sep 2017    Post subject: Reply with quote
As above.
First find the leak. It may just be the gasket. If so, drain oil, remove casing, clean meticulously, re-fit with new gasket.. hint gasket.. paper thing, not gloopy chit out of a tube!
Id casing is cracked... as above..... if o chunks of casing are missing, they can usually be repaired with aluminium weld, or a diligently applied bit of apropiate epoxy like metal-set... filed/sanded back to shape and then painted, before re-fit with new paper gasket.
Pinicle to repair though is reoval and cleaning; ali-weld or umiweld 'braze' and especially resin does not 'stick' to oil. Flange faces dont seal well if they have any old gasket left on them, and gloopy-chit is NOT good when it squidges into the chamber behind the casing to get into the oil and block oil-ways and filters or pumps and stuff!
Ultimately, if you want a fit and forget no faff fix, a ew case, IF it is the case is an expensive answer... I'd be dubiouse of any 2nd hand casing from a breakers.. where will it have come from? Whats the odds its any beter than what you got, coming from a bike that's either been crashed or siezed..... A-N-D..... e-brakers prices are some-times more than brand newbit from dealers... so IF you go down that route I'd check the price of new at franchise and independents before looking how optimistic breakers be.
But, in all liklihood short of some-one strippig treads or cracking the oss in a fill or drain plug, the case can be salvagd with ali-weld or epoxy or just new paper gasket.
Robby
Dirty Old Man
PostPosted: 16:45 - 21 Sep 2017    Post subject: Reply with quote
Usually drips around the side stand are chain lube gloop. It gathers around the front sprocket, and heat of the engine melts it. Looks like drip of really dark oil, because it's filthy stuff.
The last post was made 6 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.56 - MySQL Queries: 17 - Page Size: 47.69 Kb
