Honda CB250(Y) Carb Deaccelerator Cable.
pike
PostPosted: 15:48 - 21 Sep 2017    Post subject: Honda CB250(Y) Carb Deaccelerator Cable. Reply with quote
I've had issues with a sticky throttle (when throttling down), turns out the throttle deaccelerator cable is causing the issue. I've removed it and now everything's fine, do I actually need that cable installed, it doesn't seem to do anything, is it required for MOT purposes?
I cant see the point of the cable at all. It's non adjustable, and no matter how I route the cable from handlebar to carb the problem remains, it sticks randomly, nothing wrong with the cable.
Thanks for any help.
sickpup
Old Timer
PostPosted: 16:20 - 21 Sep 2017    Post subject: Reply with quote
<subtle hint>Theres something wrong with the cable Thumbs Up </subtle hint>
pike
PostPosted: 19:42 - 21 Sep 2017    Post subject: Reply with quote
Hmm, was my first thought (of course), works fine connected to the carb but not when in situ at the twistgrip as well, twist grip is lubricated, no issues there. Loosening off the two cross head screws that secure the cable bracket helps, almost like something's out of kilter. Cant spot anything, it's extremely weird.
Snod Blatter
PostPosted: 21:29 - 21 Sep 2017    Post subject: Reply with quote
There will be a rough spot in the cable, either at a low point where water sits or at a tight bend when the cable is in its usual position/route so the inner has heavily worn the outer.
Top tip: There's something wrong with the cable.
You can try blasting brake cleaner down it and working the inner up and down, this can work wonders. Don't try and lube it, this just makes things worse/grabbier - it stops the nylon/teflon/whatever coating from working properly. But you will be best off with just replacing the cable.
Whether you are in danger of the butterfly sticking open without a cable to pull it closed is of course up for debate, it's hard to imagine that manufacturers fit cables for no reason but on the other hand very few people have ever experienced that phenomenon, as far as I know. Maybe you can be a guinea pig, thrash it and see?
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
Courier265
PostPosted: 21:59 - 02 Oct 2017    Post subject: Reply with quote
Never come across that before, I've owned a handful of the CB250 MC26's and throttle has never been a problem.
Just replace the cable with a genuine part.. why not go the whole hog and buy BOTH cables... Laughing
The last post was made 6 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 17 - Page Size: 46.02 Kb
