Nsr125 just purchased with crank case full of mystery fluid
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3  Next
PostPosted: 10:25 - 18 Sep 2017    Post subject: Reply with quote
Shouldn't need to be particularly high-temp. Is liquid cooled. Any old gasket goo should work.
However, you shouldn't need it with a new gasket properly tightened down. Check it's not warped.
Tankie
PostPosted: 10:28 - 18 Sep 2017    Post subject: Reply with quote
It should go on dry, you may find the gasket will already have sealant on it
spitfire123
PostPosted: 22:31 - 19 Sep 2017    Post subject: Reply with quote
Right update
Fitted the new gasket kit
Exhaust gasket
New plug
Plenty of compression there ... put a syringe full of fuel down the fuel line till it was full , fired 10 or so times , dident start , took plug out , wet, let it air . Few syringes more of fuel , fires but no go , however
With no air box on and no fuel tank ( being repaired) will it actually fire up and run ?
I no my rs refuses to run without an air box .
I also haven't put coolant in yet (wanted to get it running first )
Any input appreciated
Spit
You won't be able to eat my dust......As it'll settle before you get there.
mpd72
PostPosted: 22:46 - 19 Sep 2017    Post subject: Reply with quote
spitfire123 wrote:
Right update
Exhaust gasket
New plug
Spit
Jetting will be miles out without an air filter. Way too
Lean.
TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, NSR125RW, YZF-750R Boost colours.
BMW 740i Sport, VW Transporter T5 GP LWB Shuttle 140ps DSG.
bypass2
PostPosted: 23:27 - 19 Sep 2017    Post subject: Reply with quote
Does the exhaust need cleaning out. maybe blocked full of petrol if so take the exhaust of and empty it out.
spitfire123
PostPosted: 08:39 - 20 Sep 2017    Post subject: Reply with quote
Cleaned and painted Smile
spitfire123
PostPosted: 08:40 - 20 Sep 2017    Post subject: Reply with quote
I thought as much .
spitfire123
PostPosted: 18:44 - 21 Sep 2017    Post subject: Reply with quote
Right
I've slapped the tank on
Put 3 litres of fuel in it , air box on
Fresh filter
It takes forever to fire and when she does run it's only for 5 seconds maximum, then cuts out and won't restart .
It will only start on full throttle also and will bounce around the rev range a bit ....
Would say a fuel issue
The carb looks new and I've had it apart and cleaned it !
Thinking of trying more fuel in the tank for a bit more pressure .
What do you all think ?
skatefreak
PostPosted: 18:58 - 21 Sep 2017    Post subject: Reply with quote
Open the carb drain and observe the flow with the fuel tap open. It should be consistent flow. If it slows/stops could be your float valve is blocked/restricted.
Consistent blue spark from the plug?
"Bikes are not cars and if you neglect them or ride like a cock then you will die, if you are lucky. This ends the theory section."
NSR125R, CBR 600 F3, GSXR 600 K1 (Track Bike), R1 4xv
spitfire123
PostPosted: 19:14 - 21 Sep 2017    Post subject: Reply with quote
It has a good consistent spark
Opend the carb drain screw , yup pissing out of there .
skatefreak
PostPosted: 19:18 - 21 Sep 2017    Post subject: Reply with quote
Is the reed block present and operating freely?
spitfire123
PostPosted: 19:29 - 21 Sep 2017    Post subject: Reply with quote
This one has little white plastic reeds
Opend and sealed ok
Gave them a little spray with Carb cleaner when I removed them.
However it does sound like the float bowl isn't filling quickly enogh .
spitfire123
PostPosted: 19:45 - 21 Sep 2017    Post subject: Reply with quote
Just gone out to it
Opend the carb drain and it was running through constantly.
Turned it over (full throttle ). It started up (bit smokey ) revs were bouncing around for 4/5 seconds , cut out and won't re-start .
Ahhh
mpd72
PostPosted: 20:20 - 21 Sep 2017    Post subject: Reply with quote
spitfire123 wrote:
Just gone out to it
Ahhh
Crankcase air leak? Crank seal?
spitfire123
PostPosted: 20:51 - 21 Sep 2017    Post subject: Reply with quote
mpd72 wrote:
spitfire123 wrote:
Just gone out to it
Ahhh
I hope not!
How would I test this ?
Fin
PostPosted: 20:52 - 21 Sep 2017    Post subject: Reply with quote
Revs bouncing around would suggest an air leak, everything else suggests fuelling issue, although the carb may be getting fuel the float height may not be adjusted properly and the carb might not be filling up with fuel properly. iirc the starter jet is the longest and sticks down the lowest so it may be the only one that is picking up fuel.
The bike should start and run without the air filter on, depending what NSR is they're a pain to wiggle on.
I learn from my big mistakes, but does learning mean not mistake 4 to kill?
mpd72
PostPosted: 20:57 - 21 Sep 2017    Post subject: Reply with quote
spitfire123 wrote:
I hope not!
Without it running, very difficult.
Usually you see fluids the wrong side of the engine or can feel the gearbox pressurising when revving.
Also depends where it might have gone.
Get the carb slot on first, check fuel flow from the tank, if no joy we need to start looking at air leaks. Intake rubber, reed block it crankcase.
spitfire123
PostPosted: 23:21 - 21 Sep 2017    Post subject: Reply with quote
[quote="Fin"]Revs bouncing around would suggest an air leak, everything else suggests fuelling issue, although the carb may be getting fuel the float height may not be adjusted properly and the carb might not be filling up with fuel properly. iirc the starter jet is the longest and sticks down the lowest so it may be the only one that is picking up fuel.
The air box is a nightmare
I'll guess I'll whip the carb off tommorow
spitfire123
PostPosted: 23:29 - 21 Sep 2017    Post subject: Reply with quote
Its not got any coolant in it at the moment to eliminate that .
I drained the gear oil out a few days ago and it seemed to be all there and not contained.
I think it is carb related although the carb looks pretty new , may of been untrasonic cleaned .
What do you mean by get carb slot on first?
Cheers again
bypass2
PostPosted: 00:16 - 22 Sep 2017    Post subject: Reply with quote
being carefull put the palm of your hand over the back of the carb mouth then try starting it. is the plug getting wet. are the float height set right.
spitfire123
PostPosted: 08:45 - 22 Sep 2017    Post subject: Reply with quote
Plug seems to be getting wet
Tired that before dident work it seemed a bit of fuel dripped out the front of the carb when my hand was removed.
It does occasionally stink of fuel , thats usaly when it fires up , chucks a load of smoke out and dies .
mpd72
PostPosted: 12:14 - 22 Sep 2017    Post subject: Reply with quote
Cheers again
Sorry, fat fingers on an Iphone. "Spot on first"
spitfire123
PostPosted: 17:48 - 22 Sep 2017    Post subject: Reply with quote
Right
Taken carb and reeds out
There is a shit load of fuel I can see spraying around in the crank
Wtf ???
Spit
spitfire123
PostPosted: 18:00 - 22 Sep 2017    Post subject: Reply with quote
Taken the plug out seems to be pretty dry
Blew the crank out with an air line
Seems my starter motor has now fried Sad
spitfire123
PostPosted: 12:45 - 23 Sep 2017    Post subject: Reply with quote
One of the reeds on the block (middle one out
Of 1 side of the bank) wasnt sealing 100% , so I've flipped them over . Seem a bit better, But can't see this being the cause ?
I've also just looked at the price of starter motors
There like £100 plus !
Other Motorcycle Parts
£81.39 - Buy It Now
£18.90 - Buy It Now
£81.39 - Buy It Now
Page 2 of 3
Debug Mode: ON - Server: discovery (www) - Page Generation Time: 1.29 Sec - Server Load: 2.68 - MySQL Queries: 16 - CDN Objects: 38 - Page Size: 133.26 Kb
