Author |
sidewinder |
sidewinder World Chat Champion
Back to top |
stinkwheel |
Posted: 23:35 - 07 Oct 2017 Post subject: |
Yes. Brim the tank (excludes oxygen, prevents condensation and rust) and add stabiliser. Run it for long enough to draw the stabilised fuel through the fuelling system. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
Tracer1234 |
Tracer1234 World Chat Champion
Back to top |
Bloggsy |
Bloggsy Spanner Monkey
Back to top |
MattEMulsion |
MattEMulsion World Chat Champion
Back to top |
kramdra |
kramdra World Chat Champion
Back to top |
MCN |
MCN Super Spammer
Back to top |
stinkwheel |
Posted: 10:23 - 10 Oct 2017 Post subject: |
kramdra wrote: | No, instead drain the tank into your other bikes?! run until the carbs are dry, there is no fuel to go off. Water will not get in the tank unless its already leaking, and draining will tell you if theres any water in there. This will also top up the battery. Assuming no alarm it will last winter fine. |
Nope. As MCN says, condensation forms on cold surfaces once it drops below the dew point of the surrounding air. Particularly surfaces with a high temperature conductance like metals and glass. We actually measured this in my kitchen when I was investigating a damp problem, it turns out the dew point was 13 degrees and the "damp" followed this temperature gradient on the wall. ie it was a condensation problem, not a damp problem.
In short, if you get condensation on the windows, you'll definately get it in the tank.
Corrosion (standard, ferric corrosion) requires oxygen and water. Even room air contains both oxygen and water vapour in all but the driest deserts. Leave a bit of bare metal exposed to the air in the UK and it WILL corrode.
Petrol is hydrophobic and as such, excludes both oxygen and water from the surface of the metal it's in contact with. If there are water droplets at the bottom of the tank they will start the corrosion process until the dissolved oxygen in the water is used up, then it will stop. The layer of petrol on top will prevent further oxygen saturation until it is agitated again.
So yes, brim-full tank. Or totally empty, dry and kept in the warm (over 13 degrees) ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
The last post was made 6 years, 193 days ago. Instead of replying here, would creating a new thread be more useful? |
