GS500 power loss.
morty1884
PostPosted: 16:27 - 12 Oct 2017    Post subject: GS500 power loss. Reply with quote
Hi i got my first bike 1990 gs500 few month back and starting to get problem when doing 70+mph it would loose power but keep going about 50mph. Past 2 times ived used it when on motorway it just cut out and wont restart. It trys to start but nothing will happen so got leave it for 5-10 then will start up and run great. Any help or tips would be great.
Paddy.
PostPosted: 16:47 - 12 Oct 2017    Post subject: Reply with quote
Switch the fuel tap to PRI.
Fill the tank and go for a ride.
inb4 cant lose power, it has none to start with
Current ride : Suzuki GSXR1000 L0 - Suzuki SV650 track bike - Yamaha Majesty YP250
My biking history so far
Rogerborg wrote: Whole life care for a VTR full of quadraspazzed Darrryls and Shoniq'uas cost mad dollah.
morty1884
PostPosted: 16:55 - 12 Oct 2017    Post subject: Reply with quote
It doesnít matte if I change the tap position it still does it.
Tankie
PostPosted: 16:59 - 12 Oct 2017    Post subject: Reply with quote
take the tap out and clean the strainer , the the bowl on the bottom of the tap ,while you down there, check to see if you have an inline filter,remove and replace
PostPosted: 18:39 - 12 Oct 2017    Post subject: Reply with quote
+1 on the fuel tap.
Chris45
PostPosted: 21:08 - 12 Oct 2017    Post subject: Reply with quote
...leave it for 5-10 then will start up and run great.
You've just answered you're own question my friend. As advised, check the fuel tap, take it off, clean it, and maybe even replace it, either way it's a fuel starvation problem, and as the bike runs fine after 10 mins or so, you can discount any carb problems.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
temeluchus
PostPosted: 21:55 - 12 Oct 2017    Post subject: Reply with quote
when it conks out try opening the fuel cap and setting it to prime.
morty1884
PostPosted: 13:54 - 13 Oct 2017    Post subject: Reply with quote
Thanks guys i will take fuel tap off this weekend and try it.
morty1884
PostPosted: 13:46 - 14 Oct 2017    Post subject: Reply with quote
Iíve cleaned the petcock and did notice bit Grease in there but rest looked ok. I also drained my tank and notice few paint chips floating around.
Chris45
PostPosted: 15:13 - 14 Oct 2017    Post subject: Reply with quote
There is also a breather pipe from the tank, usually routed down inside the frame of the machine, check the end isn't blocked.
morty1884
PostPosted: 15:20 - 14 Oct 2017    Post subject: Reply with quote
Not on mine it would seem the pipe is missing
morty1884
PostPosted: 15:25 - 14 Oct 2017    Post subject: Reply with quote
here some pictures
Tankie
PostPosted: 15:55 - 14 Oct 2017    Post subject: Reply with quote
Blow it through with an air line if you have access to one
Stoker
PostPosted: 17:14 - 14 Oct 2017    Post subject: Reply with quote
That looks a bit manky! As others have said, fuel starvation... if it was mine I'd be wondering about the state of the carbs too, but at this stage I'd settle for checking on delivery to the carbs first.
Free Pro-tip!
For years I didn't have access to an airline at home, and those cans of compressed air for hobbyists/photographers were horrendously expensive so I used to improvise with a can of lighter butane, have blasted out carbs, inflated footballs and tyres,cleared cack from the usb port on my phone, hallucinated, etc...The little adaptors that come in the lid have come in useful too Smile
PostPosted: 20:01 - 14 Oct 2017    Post subject: Reply with quote
Old Guitar Strings are great to clear those breathers.
Debug Mode: ON - Server: discovery (www) - Page Generation Time: 2.38 Sec - Server Load: 7.57 - MySQL Queries: 17 - CDN Objects: 33 - Page Size: 84.75 Kb
