Author |
ThatDippyTwat |
Posted: 15:31 - 14 Oct 2017 Post subject: |
This is an '02 bike. The tyre is pre '00 as it's 3 digit. It's probably never been changed
https://i.imgur.com/Tmt5tZml.jpg
2.7mm at centre, plenty of tread left .... but...
https://i.imgur.com/6HqU1jAl.jpg
... this may be why it wouldn't hold pressure for more than a fortnight... cracked with age.
https://i.imgur.com/nIpw8RPl.jpg
Heidenau rear, Maxxis front now fitted. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
Back to top |
Stoker |
Stoker Nitrous Nuisance
Back to top |
ThatDippyTwat |
Posted: 18:22 - 14 Oct 2017 Post subject: |
24,000KM, 15K-ish miles. It's a Cruiser, and like so many lasses at the bar, has a fat arse and no weight up front. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
Back to top |
Courier265 |
Courier265 World Chat Champion
Back to top |
ThatDippyTwat |
Back to top |
pompousporcup... |
pompousporcup... World Chat Champion
Posted: 21:04 - 15 Oct 2017 Post subject: |
fitted the newly rejuvenated airbox rubbers into the airbox and fitted that. Squeezed a different set of carbs(recently rebuilt by me) in and spent an hour getting everything to line up properly. Fitted a K&N into the airbox.
plumbed up the temp fuel line on the 900r. Stock pilot jets, float heights but everything else stage 1 dynojet rather than the previous janky overfuelled stage 3 setup using velocity stacks and foam socks.
Well, what do you know. Fired straight up and had a solid idle. I have been dealing with a completely farked set of carbs the entire time not to mention the stage 3 hassles. All cylinders are now running within 10deg of each other
Balanced the new set, hooked up the fuel tank and went for a ride. No stumble anymore but there is a bit of hesitation if i crack the throttle quickly in 4th at 20mph (i know, why would you do that anyway)
Pulls amazingly in all gears and buzzes all the way to 'sorry judge' speeds.
Epic bike <3 |
Back to top |
linuxyeti |
linuxyeti World Chat Champion
Back to top |
natefz6 |
natefz6 Brolly Dolly
Back to top |
Courier265 |
Back to top |
thx1138 |
thx1138 World Chat Champion
Back to top |
neptune8 |
neptune8 Nova Slayer
Back to top |
Hahadumball |
Hahadumball World Chat Champion
Back to top |
Pete. |
Posted: 20:58 - 17 Oct 2017 Post subject: |
New boots! ____________________ a.k.a 'Geri'
132.9mph off and walked away. Gear is good, gear is good, gear is very very good
Back to top |
grr666 |
grr666 Super Spammer
Posted: 21:06 - 17 Oct 2017 Post subject: |
Got sawdust all over it whilst cutting a heavy duty circular template for my bricklayer to lay bricks around.
Why I never thought to close the shed door is beyond me but I'm having a busy week. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off. |
Back to top |
zark |
zark Trackday Trickster
Posted: 11:27 - 18 Oct 2017 Post subject: |
are they PR4's?
howmuchwherefrom?, plz ____________________ CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou... |
Back to top |
Pete. |
Posted: 13:40 - 18 Oct 2017 Post subject: |
Yes pr4's from Watling Tyres £243 fitted to loose wheels. ____________________ a.k.a 'Geri'
Back to top |
mudcow007 |
mudcow007 World Chat Champion
Back to top |
derillius24 |
derillius24 Trackday Trickster
Back to top |
Beehive Bedlam |
Beehive Bedlam World Chat Champion
Posted: 17:14 - 19 Oct 2017 Post subject: |
Looked better with the before belly pan. |
Back to top |
Matt B |
Matt B World Chat Champion
Back to top |
Courier265 |
Back to top |
M.C |
M.C Super Spammer
Back to top |
bamt |
bamt World Chat Champion
Posted: 19:03 - 22 Oct 2017 Post subject: |
I pulled the rear wheel off the Pan so it can get a new tyre tomorrow. That's the third new one on the back this year, plus it started the year on reasonably fresh rubber.
It was due an oil change too, so I decided to do that now rather than tomorrow. Annoyingly, I had a K&N KN-204C filter on it (maybe one of the faulty batch - but it's chrome and doesn't appear to have any date code on it to check). Normally I use HiFlo, but got this in a package deal with the Motul oil.
Why is that annoying? Well, I always fit filters by hand and in most applications can remove by hand too - but the access on the Pan is limited to get my hand around with sufficient grip to remove it once it's been on for a few thousand miles, so I normally remove it using one of those socket tools that fits the end of the filter then put the new one on by hand.
The K&N has a "convenient" nut on the filter and no standard flats on the end. As soon as I put any torque onto the nut with a ratchet, it ripped off and dangled by one weld. This wasn't me swinging on it - it had been fitted by hand and it didn't feel like I'd got up to the normal torque that'd break the seal. I couldn't get my hand around it enough to grip well, couldn't use my normal filter removal tool as the K&N has no flats (and no access to put it on and hammer it into place), couldn't get in with my boa due to the centre stand being in the way.
I had to put the back wheel back on so I could put it onto the side stand to get the boa onto the filter, which then spun off quite easily. That's the last time a K&N goes on my bikes - the Bandit has one currently (same deal on oil and filter), I hope that comes off OK. |
Back to top |
waffles |
waffles World Chat Champion
Posted: 16:31 - 23 Oct 2017 Post subject: |
Kicked the gixer, considered selling it.
It had a new battery, reg/rec and generator in April, I took it across Europe July/August and it broke down on the way home in France and had another brand new battery, reg/rec and generator (plus the cost of transport home) and now the fucker won't start again. Nothing. No lights, no fuel pump prime, not even a glimmer of a headlight.
What an arsehole. ____________________ Theory test - 19/8/09, CBT - 11/10/09, MOD 1 - 16/8/10, MOD 2 - 27/10/10
Current rides Suzuki GSXR 600, Honda MSX125 |
Back to top |
Copycat73 |
Copycat73 World Chat Champion
Back to top |
The last post was made 6 years, 229 days ago. Instead of replying here, would creating a new thread be more useful? |
