Inspired by the heated grips thread.....
How do you connect yer grips?
Direct to the battery
21%
 21%  [ 3 ]
Ignition
78%
 78%  [ 11 ]
Total Votes : 14
Courier265
PostPosted: 22:14 - 17 Oct 2017    Post subject: Inspired by the heated grips thread..... Reply with quote
Seen a few vids on youtube and many people fit grips direct to the battery.....
Personally I wire them to the ignition.......
RhynoCZ
PostPosted: 22:29 - 17 Oct 2017    Post subject: Reply with quote
I'm going to say the ignition, just to make sure the grips are off while you're not on the bike. It'd be real stupid to forget to turn the heating off and leave the bike to find it couple of hours later with drained battery. Well that, given you don't leave the keys in the ignition when you get off the bike.
grr666
PostPosted: 22:37 - 17 Oct 2017    Post subject: Reply with quote
Voltage sensing technology in mine that switch themseves off if battery level drops. Wired direct to battery.
Islander
PostPosted: 22:45 - 17 Oct 2017    Post subject: Reply with quote
To the battery via a relay controlled from a switched live.
ScaredyCat
PostPosted: 23:18 - 17 Oct 2017    Post subject: Reply with quote
Via PDM60 ...
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 23:53 - 17 Oct 2017    Post subject: Reply with quote
However Triumph wired them I haven't bothered looking but they turn off with the ignition.
bamt
PostPosted: 00:18 - 18 Oct 2017    Post subject: Reply with quote
Via the ignition - whilst they turn themselves off if the voltage drops (when the engine isn't running) I don't particularly trust it, and don't like the idea that someone could fiddle with it and repeatedly turn it on.
I actually run via an ignition switched relay that feeds a fuse box that powers all my auxiliary stuff (phone charger, heated grips & seat, lighting, radio gear etc.). That also has a rather nifty function I hacked together that gives me a hold-up switch on the handlebars. The auxiliary power works as you'd expect (on and off with the ignition) unless you switch the hold-up on.
If I switch that on whilst the ignition is on, then my auxiliary relay remains powered even if the ignition is subsequently turned off and the key removed, so I can choose to do things like have my bike-mounted radio remain connected via bike-powered bluetooth to my helmet whilst I'm fuelling up (so using the ignition key in the filler cap) or leave the radio and auxiliary lighting running if I'm a short distance from the bike without needing to leave my keys in it. Once I switch the hold-up off, it won't switch back on until the ignition is turned on again - so it can't be enabled by someone and drain my battery whilst I'm not there.
On the other bike, which has fewer electronic bits, I still wired in a relay to the ignition for grips that should turn themselves off.
MCN
PostPosted: 07:38 - 18 Oct 2017    Post subject: Reply with quote
Lazy, incompetent, or not giving a shite are the only reasons to connect directly to the battery.
linuxyeti
PostPosted: 08:01 - 18 Oct 2017    Post subject: Reply with quote
Why bother, for the sake of 1 or 2 weeks a year? I rarely even put the thermal lining back in the jacket ..
Beware what photos you upload, or link to on here, especially if you have family members on them
grr666
PostPosted: 08:35 - 18 Oct 2017    Post subject: Reply with quote
Or having grips that switch off automatically with their built in tech. I have (inadvertently) tested this feature btw.
Yamaha say to connect direct to battery in their own instructions.
https://cdn2.bigcommerce.com/server4400/de554/products/1721/images/6542/Yamaha_Heated_grips2__62773.1442940357.1000.1000.jpg?c=2
Evil Hans
PostPosted: 08:40 - 18 Oct 2017    Post subject: Reply with quote
That's how I did mine. So the answer to the poll is "both".
PostPosted: 09:21 - 18 Oct 2017    Post subject: Reply with quote
Relay controlled auxillary circuit here.
Last chance to see Howto guide to fitting a relay before the photobucket of fail breaks it.
fatjames
PostPosted: 09:28 - 18 Oct 2017    Post subject: Reply with quote
I leave my bar muffs switched on throughout the winter. Never had a battery problem Cool
pompousporcup...
PostPosted: 10:07 - 18 Oct 2017    Post subject: Reply with quote
depends which heated grips.
The more recent Oxford grips turn themselves off after a while. Not entirely sure how that works but it did work on my bike.. For ease sake, i fit them direct to the battery
myvision
PostPosted: 11:08 - 18 Oct 2017    Post subject: Reply with quote
Ignition on one bike.
Straight to battery on another as they turn themselves off apparently.
VFR800FI, YZF600R Thundercat and FZS 1000
Andy_Pagin
PostPosted: 13:25 - 18 Oct 2017    Post subject: Reply with quote
Apparently they sense electrical noise in the wiring generated by the ignition doing it's thing when the engines running, no noise means the engine's off, so the grips switch off.
Hawkeye1250FA
PostPosted: 13:38 - 18 Oct 2017    Post subject: Reply with quote
Same.
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
bamt
PostPosted: 13:40 - 18 Oct 2017    Post subject: Reply with quote
Noise sensing is unlikely. It's far easier just to measure its voltage. Greater than say 13v means the engine is running, less than that means it is stopped. I'd be extremely surprised if anything else is done.
arry
PostPosted: 14:00 - 18 Oct 2017    Post subject: Reply with quote
I've had problems turning muffs on recently.
pompousporcup...
PostPosted: 14:29 - 18 Oct 2017    Post subject: Reply with quote
Thumbs Up sounds about feasible. They don't go off instantly but maybe after 3 or 4 minutes the light starts flashing and then they go dead
PostPosted: 14:48 - 18 Oct 2017    Post subject: Reply with quote
You obviously aren't inserting your fingers correctly. Start with them pointed and keep your thumb tucked in until you have your whole hand inside.
Freddyfruitba...
PostPosted: 14:54 - 18 Oct 2017    Post subject: Reply with quote
As do Oxford.
Well, surprised you may be, but that's exactly what the instruction manual says. Could be a lie of course, but there doesn't seem to be much gain for Oxford in doing that.
bamt
PostPosted: 17:55 - 18 Oct 2017    Post subject: Reply with quote
Having checked, the manual says it does both Smile
And yes, I am surprised.
Fisty
PostPosted: 18:06 - 18 Oct 2017    Post subject: Reply with quote
Do i go wrist deep or elbow deep?
Fatter and faster than Fret
Hawkeye1250FA
PostPosted: 11:34 - 19 Oct 2017    Post subject: Reply with quote
You should be able to lose your watch... not your belt.
The last post was made 9 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.09 - MySQL Queries: 18 - Page Size: 134.78 Kb
