welding or liquid metal? vtr engine borked
Hahadumball
PostPosted: 23:11 - 31 Oct 2017    Post subject: welding or liquid metal? vtr engine borked Reply with quote
Vtr chain snapped and twatted the sprocket cover which has the clutch piston on it too...
snapped all the bolt threads off the damn case
weld?
liquid metal?
ratchet strap around it? Very Happy
what do... its only got to take the pressure of the clutch piston.
avoiding having to replace the engine, its a monoblock so case isnt in the question.
https://i.imgur.com/pyIG64H.jpg
https://i.imgur.com/ET1bFna.jpg
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
jjdugen
PostPosted: 00:35 - 01 Nov 2017    Post subject: Reply with quote
Hate to say, but that looks like a replacement engine would be your best bet. Just maybe it can be welded. Everything would have to be scrupulously clean and that old chain grease gets right into the pores of the alloy. The clutch slave exerts quite a high pressure on the metalwork, it needs to be solid.
Hahadumball
PostPosted: 01:00 - 01 Nov 2017    Post subject: Reply with quote
ballbags.. seemed it was a failure of the chain rivet link that caused it.
possible but looks hard i could even get a ratchet strap around the engine for now.. i work way too much to get time to contemplate replacing the engine for a 3rd time.
mentalboy
PostPosted: 01:09 - 01 Nov 2017    Post subject: Reply with quote
You are Bodyguard and I claim my five ponds.
Make mine a Corona.
Hahadumball
PostPosted: 01:16 - 01 Nov 2017    Post subject: Reply with quote
nah bodyguard would pry the engine out with the forks.
only needs to get me to work and back for another week then i have a week holiday so actually get time to address it.
PostPosted: 02:17 - 01 Nov 2017    Post subject: Reply with quote
Jesus what a mess.
If (and it's a big if) a professional welder/business took that on the first thing they would say is no guarantees and give us your money first.
Hahadumball
PostPosted: 02:22 - 01 Nov 2017    Post subject: Reply with quote
no clue how it did all mounts, i was doing about 25-30 if that when it went, looked a right cunt as i overtook a corsa only to rev the shit out of it when the chain went bye byes
only other thing i can think of is longer bolts and tap into whats left...
and hope like fuck
generic image shows a decent length to tap into..
https://i.imgur.com/GFbxtl1.png
if i could get deep enough i could liquid metal on the parts i have and then use longer bolts...
its only got to last me a few months until i replace it with the winter steed of 4 wheels
3 i can drill and tap with loads left...
1 is a bit risky
and 1 is quite fucked and doubtful.. i could maybe add... 3-4 turns on whats left and chemical metal the broken part on and hope it holds just for extra strength...
otherwise the 3/4 will hold fairly well..
PostPosted: 10:23 - 01 Nov 2017    Post subject: Reply with quote
I mention this every time one of these comes up and nobody seems to take it on.
Aluminium solder will fix that. You'll be able to bridge that small hole and solder the bits back on. You'll need a good source of heat like MAP or oxy-acetylene.
PostPosted: 11:26 - 01 Nov 2017    Post subject: Reply with quote
Can you literally solder it like you would a copper pipe? Flux, heat and melt it, it'll suck it in? Thats interesting to know. Thumbs Up
PostPosted: 11:41 - 01 Nov 2017    Post subject: Reply with quote
It's probably closer to brazing. You clean and degrease the area, match the edges then go over the whole area you want the solder to key to with a stainless wire brush (don't know why, but it has to be stainless). You then heat the piece and rub the stick/rod of solder on. When it's hot enough, the solder flows into the metal.
One odd property is it will bridge a sizeable hole. It forms a kind of "bubble" that doesn't drop through.
Video is kind of slow but definately instructive:
https://youtu.be/n1njyuPBIH0
Hahadumball
PostPosted: 12:54 - 01 Nov 2017    Post subject: Reply with quote
that looks interesting... how much stress can it cope with though?
drilling out a bit deeper and threaded with m6 on 3/5 holes so far.. 1 i think it beyond saving but annoyingly its one for the clutch piston itself so im not sure i trust 2/3 bolts holding it on for now...
only time shall tell
PostPosted: 13:38 - 01 Nov 2017    Post subject: Reply with quote
Allen Millyard joins his crankcases with lumiweld. So lots.
Northern Monkey
PostPosted: 15:15 - 01 Nov 2017    Post subject: Reply with quote
Bodyguard's engine is in one piece, and he doesn't need a third
c_dug
PostPosted: 15:25 - 01 Nov 2017    Post subject: Reply with quote
Yesterday we had an aluminium part on an exhibit fail directly above an aluminium soldered joint. In other words the joint held but the metal failed.
If done right it's as strong as the metal it would seem.
Hahadumball
PostPosted: 19:25 - 01 Nov 2017    Post subject: Reply with quote
managed to bodge it, now to run this bike into the ground.
drilled and tapped what was left, metal putty the broken parts back on for asthetics and added a little thick aluminium bracket from the stator cover bolt to the bolt that holds the clutch piston to the sprocket cover for that extra bit of support just in case.
A100man
PostPosted: 20:28 - 01 Nov 2017    Post subject: Reply with quote
Come on let's see it then. I am nothing if not a bodge connoisseur..
Hahadumball
PostPosted: 20:40 - 01 Nov 2017    Post subject: Reply with quote
nothing much to see, 1 bolt still to go in but waiting on putty to set
looks normal just the aluminium bracket is new
https://i.imgur.com/nwdIZ3F.jpg
jjdugen
PostPosted: 20:47 - 01 Nov 2017    Post subject: Reply with quote
Actually..... That should work! The only stress point is the clutch slave, the rest just cosmetic. I applaud!
ZRX61
Victor Meldrew
PostPosted: 00:12 - 02 Nov 2017    Post subject: Reply with quote
I'd weld it if it was mine.
They're not one night stands, they're auditions.
mentalboy
PostPosted: 00:52 - 02 Nov 2017    Post subject: Reply with quote
I'll put money on his crankcases being aluminium, that case is magnesium alloy which is a complete and utter bastard to weld/solder/braze.
Make mine a Corona.
c_dug
PostPosted: 01:28 - 02 Nov 2017    Post subject: Reply with quote
Top bodge Thumbs Up
PostPosted: 12:14 - 02 Nov 2017    Post subject: Reply with quote
c_dug wrote:
Top bodge Thumbs Up
I agree, paint the bracket black and then flog it on ebay, 'Good condition'. No one can come and see it because of ebay rules so your quids in.
I am jesting, obviously Laughing
Hahadumball
PostPosted: 14:49 - 02 Nov 2017    Post subject: Reply with quote
just need to get the other bolt in as i managed to drill it fractionally off to one side, not surprising as i was drilling onto a slanted surface.
Hahadumball
PostPosted: 11:39 - 03 Nov 2017    Post subject: Reply with quote
got the bolt in, trimmed the bracket and painted it Very Happy
https://i.imgur.com/mpgJ2dZ.jpg
MCN
PostPosted: 14:07 - 03 Nov 2017    Post subject: Reply with quote
Jeez.. is no fucker going to mention the elephant in the room here or what?
That hooring front sprocket.... WTF? Shocked
Get a chain and sprocket set onto that beast ASAP. Rolling Eyes
Well some cnut had to say it.
Very Happy
The last post was made 8 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.52 - MySQL Queries: 16 - Page Size: 139.92 Kb
