Air compressor.
ScaredyCat
PostPosted: 21:11 - 06 Nov 2017    Post subject: Air compressor. Reply with quote
I'd like to get an air compressor but I don't know a lot about them tbh. I want something that's fairly quiet and at a reasonable cost. Usage would be primarily for nail guns ( they appear to need 70-120 PSI ) and a blowy bit to blow out sawdust.
I've never used one, so any usage tips would be helpful too Smile
Any recommendations for the compressor?
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
dydey90
PostPosted: 21:18 - 06 Nov 2017    Post subject: Reply with quote
70psi should be more than enough for just about anything. Pretty sure you can run a plasma cutter on that.
It will be loud and it will be expensive to run.
PostPosted: 22:14 - 06 Nov 2017    Post subject: Reply with quote
I have a 2.5bhp 25 litre one. It was reasonably expensive but it replaced an Aldi one that was stolen.
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Hahadumball
PostPosted: 22:58 - 06 Nov 2017    Post subject: Reply with quote
i have a little 6 litre electric compressor, good for changing my own tyres and cleaning shit off of shit, will put out about 110psi but wont last long, fills pretty quick but its far from quiet.
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
BTTD
PostPosted: 09:43 - 07 Nov 2017    Post subject: Reply with quote
I have a small 8 litre one that will run air nailers, inflate tyres etc, but is noisy as hell, and has to run a lot. I have run a couple of small cfm air tools off it, but it doesn't really like it much.
I got it second hand off ebay and it is somewhat portable (heavy, but you can carry it).
I reckon a 25 litre small compressor will cover your needs without breaking the bank.
I also hacked together an old 50 litre gas cylinder and fridge motor to make a low current draw compressor for use in my lock up with my small generator. It's near silent, doesn't bog the genny down, and works well for airing up tyres and blowing out dust etc.
bugeye_bob
PostPosted: 09:55 - 07 Nov 2017    Post subject: Reply with quote
The tank size is very important, or they just run out of air, whatever your pressure.
PostPosted: 10:28 - 07 Nov 2017    Post subject: Reply with quote
So is your air pipe diameter if running tools.
I have a 25 litre one from Aldi or Lidl, can't remember which but it's a Parkway brand and was under £100. It's absolutely fine for 90% of what I need and the other 10% I have proper power tools for. It would certainly do what you want.
Triumph Trophy Launch Edition
mudcow007
PostPosted: 10:39 - 07 Nov 2017    Post subject: Reply with quote
I've just thrown away a portable compressor, it was getting on my tits, just sitting there all orange an shit plus every time i went in my shed i wacked my shins on the fucker
I know this doesn't help you at all, but it makes me feel better. Carry on
Copycat73
PostPosted: 10:54 - 07 Nov 2017    Post subject: Reply with quote
this is the one i`ve got
...https://www.amazon.co.uk/AIR-COMPRESSOR-5-7-230V-LITRE/dp/B018KAE854/ref=sr_1_1?ie=UTF8&qid=1510048270&sr=8-1&keywords=6l+compressor&dpID=41PhdweiUpL&preST=_SY300_QL70_&dpSrc=srch
its not quiet though and i only use it for tyres..
bought because the tire inflator burnt out doin my transit van`s tires
caveat emptor
nowhere.elysium
The Pork Lord
PostPosted: 15:03 - 07 Nov 2017    Post subject: Reply with quote
If you can afford a quiet one, go for it. It might well have a bit less grunt than a similarly-priced normal one, but your eardrums will thanks you for it.
Fizzer Thou
PostPosted: 22:05 - 07 Nov 2017    Post subject: Reply with quote
I bought one of these earlier this year
https://www.machinemart.co.uk/p/clarke-tiger-11510-2-5hp-50-litre-air-compres/
My previous compressor had a crack in the con-rod part as well as a badly scored piston sleeve,so would not generate the pressures that I was used to,hence the strip down to ascertain the problem.
At about the same time that my old one,which I had owned for many years,went u/s I had one of those VAT free day cards through the door from Machinemart and so on the relevant day I popped down to my local shop near Sidcup and,thirty minutes later,I had a new one in the back of my car and was on my way home.
I not only use the compressor for installing new tyres and topping up existing fitted ones,but also to pressurise my grit blaster and my air tools.The 1/2" air ratchet works much better now Thumbs Up Very Happy Thumbs Up
Always have a 'Plan B'
johnsmith222
PostPosted: 19:40 - 08 Nov 2017    Post subject: Reply with quote
You could always go down the second hand route for a compressor. I fitted my own tyres, but always put off having a compressor, as I felt £120 for the 25 litre ones weren't worth it due to not being certain if they could handle certain tools. The larger ones were too expensive for not knowing if air tools were for me.
I ended up getting a second hand stanley air compressor for £50. It's a 2.5hp, 25 litre one. Now I have it, I definitely see myself upgrading in the future and getting a fair few air tools.
Main maintenance things are:
drain the tank every use (easier with an easily opened valve sort of drain) The drain is at the bottom.
Change the oil as per the manual (maybe every year?)
If it's belt run then you might need to eventually change the belt.
Don't run it on an extension lead (I'm guilty of this, but I'm going to get myself a long hose!)
and as previously pointed out, I would wear ear defenders when using it. It's a good habit to get into when using certain tools too.
Here's a good video of why you should drain your tank:
https://www.youtube.com/watch?v=ElQH4FrhDvY
Hong Kong Phooey
PostPosted: 18:05 - 14 Nov 2017    Post subject: Reply with quote
I changed the shitty thin coil hose that came in one of the cheap accessory kits and it improved the power but my 25l tank isn't big enough for sustained high cfm tools.
Whatever you get, go for the biggest tank possible. Chuck a horse blanket over the top to dull down the noise but beware of blocking off the cooling fins etc.
The last post was made 6 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.25 - MySQL Queries: 17 - Page Size: 91.86 Kb
