Hug Trees a little.
Bike Chat Forums Index -> Politics & Current Affairs Goto page Previous  1, 2, 3 ... 8, 9, 10 ... 14, 15, 16  Next
PostPosted: 09:05 - 03 Nov 2017    Post subject: Reply with quote
Sun Wukong wrote:
Yes, yes, kill the humans, end their culture, I'm onboard with that part.
Lord Percy wrote:
[NASA]
Obama's NASA.
It'll be your turn to scoff at the truths that Trump's NASA and EPA will unearth soon.
Lord Percy wrote:
Here, the models [...] the model projections. [...] models [...] models [...] models
Oh, look, a field of cows.
Hey, that cow is pointing north.
Therefore, all cows can be used as compasses.
chickenstrip wrote:
a) not like Rogerborg will have any effect on the issue.
Inertia is my religion. Folded arms
Lord Percy
PostPosted: 09:21 - 03 Nov 2017    Post subject: Reply with quote
Rogerborg wrote:
Obama's NASA.
I think it's time for me to admit I'm only continuing this discussion because it's fun to see what lunacy you'll come out with in each new reply Very Happy
Sun Wukong
PostPosted: 09:32 - 03 Nov 2017    Post subject: Reply with quote
I like to see what we're up against Thumbs Up
It's not going to be fixed easily, clearly.
Top cat
"Hard times lead to hard people. Hard people lead to good times. Good times lead to weak people. Weak people lead to hard times." Smegballs
"Oh and STE balloons would be one of the nicer things we would receive at the office, the amount of dog turd in jiffy bags is not funny." Jsmith86
PostPosted: 09:36 - 03 Nov 2017    Post subject: Reply with quote
Jinx!
Sun Wukong
PostPosted: 16:09 - 03 Nov 2017    Post subject: Reply with quote
Rogerborg wrote:
Jinx!
Creation.com - Missing Links Parade
Why would a loving god allow suffering and death, Borgy? Why?
Top cat
PostPosted: 19:24 - 03 Nov 2017    Post subject: Reply with quote
Only when She's on the blob.
PostPosted: 16:36 - 06 Nov 2017    Post subject: Reply with quote
https://i.imgur.com/ZrotNe9.png?1
Shrieks Al Beeb, with a little help from Tense Adams, given that they backtrack to 'very likely' will be.
Death, doom, panic, worst ever, extinction, inexorable rising trend, hotter and hotter and hotter, woe, woe unto us.
Al Beeb wrote:
The analysis suggests that 2017 is likely to come in 0.47C warmer than the 1981-2010 average.
This is slightly down on 2016 when the El Niño weather phenomenon saw temperatures that were 0.56C above the average.
That, right there, is why this whole 'debate' is mirthsome, as the language has already been decided, and the playing field tilted, polished and oiled.
When the planet warms, that's down to climate change.
When the planet cools, it's just weather.
The headline should be "Planet cools an unprecedented 0.09 degrees in just one year, climate alarmists perform desperate damage control".
Lord Percy
PostPosted: 04:12 - 07 Nov 2017    Post subject: Reply with quote
Clearly still using hysterical news sources rather than any of the bumf I threw at you before!
Long term predictions are right - rapid warming and all the negative results that go with it. Short term predictions however will always be plagued by uncertainty. A colder year does not mean the trend stops. Indeed it really hasn't stopped at all.
Sun Wukong
PostPosted: 11:39 - 07 Nov 2017    Post subject: Reply with quote
Stop trying to explain science to him, it will only end in tears.
"Never argue with an idiot, they'll drag you down to their level and beat you with experience"
Borgy, you understand a lot of things to an impressive level. This is not one of them, sadly.
Top cat
PostPosted: 11:42 - 07 Nov 2017    Post subject: Reply with quote
Al Beeb? Sure, they're True Believer alarmists, which can be seen by them producing an article that shriekingly asserts the opposite of the one fact contained in it, which is that the planet cooled his year.
I miss your point. Are you in favour of hysterical alarmism, or in favour of challenging it? Eh?
If this the same definition of reality that depends on "correcting" recent temperature measurements up while "correcting" historic ones down in order to produce the "correct" trend?
Do you honestly not see the problem with making a firm, absolute statement about reality that appears to be based on nothing more than belief that there must, there must, be some model out there that can predict the future?
OK, you've failed the two decades prediction challenge, that's clear enough.
So here's an easier one. Can you find a model that correctly predicted the amount of this year's drop? Should be easy enough, right? I mean, if we can really predict reality a hundred years ahead, it's first necessary to predict one year.
So, astonish and enlighten me: where will I find a record of that prediction? One must exist, there are enough climaticians out there that one of them must have got it right just through sheer dumb luck accurate modelling.
Then for bonus wokeness: what does that model predict the global temperature will be in 2018?
We can come back to this in a year or so and see how reality played out.
asta1
PostPosted: 16:16 - 07 Nov 2017    Post subject: Reply with quote
In Fairness Rog, the effects of the El Nino/ El Nina cycle are fairly well documented:
https://www.carbonbrief.org/interactive-much-el-nino-affect-global-temperature
Look at the graph, general trend is NASA data 1951-2010, so a fair bit more than just 'Obama's NASA'.
Shows a general upwards variation of approx. 0.8 degrees centigrade over the period. Variation for El Nino: +/- 0.15 degrees for the complete cycle in extreme instances and maybe +/-0.1 degrees on average. It does appear to support the results seen for the 2016-2017 El Nino variations of 0.09 degrees centigrade right?
A further point on 'corrections'. On the face of it, these do seem suspect, just 'correct' the results to get the expected trend right? However, they are sometimes valid for the data or model required.
For example, lots of the climate models of the 90s and 00s had corrections for sulfate aerosols. These are effectively 'smog' particles produced from SO2 and which absorb 1-2 W/m2 of radiant energy cause a cooling effect on Earth. Sounds fine right? Except the main causes of the particles are volcanic eruptions and human sources. They are short lived and crucially, decreasing globally due to clean air initiatives etc. Therefore, if you don't 'correct' for them, you get models which underestimate future warming and which are wildly out due to taking past volcanic events into consideration. This has been proven to effect global temps. For instance look again at the graph in my link above, specifically 1992. Effects of volcanic activity and El Nino can be seen very clearly and the net effect of both acting together (in this case cancelling each other out.
Oh, and bonus points for 2018: BASED EXCLUSIVELY ON EL NINO, 2018 should show similar or marginally lower temps than 2017, based on El Nino cycles generally acting over at least a few years and the current one increasing through 2014 and 2015 before peaking in 2016.
Bonus prediction for even more points, 2020 or 2021 will be the next hottest year on record, based on data not adjusted to mitigate El Nino effects.
CBT Acquired: 09/07/2015
A2 Licence Passed: 12/02/16
Current Bike: Yamaha MT-07 bought 02/07/16
chickenstrip
PostPosted: 16:47 - 07 Nov 2017    Post subject: Reply with quote
Y'all know what we need? We need a massive reduction in the human population. Funnily enough, one relatively quick and easy way to achieve this would be to increase global warming as much as we possibly can, with all the associated disasters that would bring - in short, we're not really trying hard enough to cause global warming if we really want to save the human species Thumbs Up
Kawasaki Jimbo
PostPosted: 19:47 - 07 Nov 2017    Post subject: Reply with quote
Climate oscillations (the ones we've detected). It's complicated.
https://en.m.wikipedia.org/wiki/Climate_oscillation
We'd be quite right to combat pollution where possible, but it could be said that activities which return carbon back to the system are just life-forms doing what life-forms do; increasing the entropy of the system. Gaia wants it.
Itchy
PostPosted: 00:56 - 15 Nov 2017    Post subject: Reply with quote
Just saw this in my feed.
https://www.youtube.com/watch?v=RyNmgSefNA4
Sun Wukong
PostPosted: 09:18 - 15 Nov 2017    Post subject: Reply with quote
No.
Top cat
Sun Wukong
PostPosted: 09:33 - 15 Nov 2017    Post subject: Reply with quote
Itchy wrote:
Yeh, can't argue with any of that, sadly.
https://wehaveconcerns.com/wp-content/uploads/2015/01/end-is-near.jpg
Top cat
PostPosted: 09:49 - 15 Nov 2017    Post subject: Reply with quote
No.
Yes.
Wait, CO2 directly increases food production?
There's a technological "solution" to the "problem" that's been "caused" by technology, you say?
FAKE NEWS! VERY BAD!
Falco
PostPosted: 16:17 - 15 Nov 2017    Post subject: Reply with quote
Police Tut Tut That isn't what it says at all. Tut tut Roger. 1 mark for memeing, 2 marks for actual technological solution. 3/10. No mention of tiny scale its currently on and the huge challenges to scaling and deployment.
We have a plethora of technology that could *if magically scaled and deployed globally* solve these problems. Add this one to the pile and call me when any actual political will develops to do much about it (outside of china I mean..... Shocked )
I tell you what, mathematically, I'm having it
Itchy
PostPosted: 16:23 - 15 Nov 2017    Post subject: Reply with quote
Sun Wukong wrote:
Can't detect sarcasm or not.
It's merely that some solutions actually make the problem worse.
It's like hybrid cars. Ah yes better for the environment says the headline. Except we don't consider the manufacturing of them and losses in transmitting electricity from the coal power plants. Then you're lugging around a ton of batteries that need replacement every 10,000 miles.
PostPosted: 16:58 - 15 Nov 2017    Post subject: Reply with quote
Fusion power, brah. 20 years, you wait and see.
Sun Wukong
PostPosted: 23:31 - 15 Nov 2017    Post subject: Reply with quote
No sarcasm, genuine exasperation for "can't do right for wrong".
I was enjoying my moral superiority moving away from milk, and then almond milk becomes the new devil.
I am moving towards occasional chicken, and less dairy stuff, but in reality the battle seems lost whatever.
I should join Borgey on the good-ship-climate-change-denial, the parties have better catering.
Dance! Dance!
Top cat
Kawasaki Jimbo
PostPosted: 00:05 - 16 Nov 2017    Post subject: Reply with quote
No.
Concise, assertive. Karma But not rising to it? Crying or Very sad You're no fun anymore! Smile
The end of what though?
Falco
PostPosted: 00:39 - 16 Nov 2017    Post subject: Reply with quote
I agree that externalities are often not considered but that's not a great example, equivalent power generated in a power plant is far more efficient due to the scale of generation, ability to reuse waste heat generated etc . Dropping current and boosting voltage drops resistive losses during transmission so the overall loss for transmission is around 8-10%. So in terms of power generation electric cars are better for the environment.
Battery production and disposal though? Yeeesh, what a nightmare. Whichever physical chemist (or their company) cracks decent battery tech is going to be so rich that they'll be throwing money at Bill Gates like he was a homeless man
Kawasaki Jimbo
PostPosted: 00:58 - 16 Nov 2017    Post subject: Reply with quote
Falco wrote:
equivalent power generated in a power plant is far more efficient due to the scale of generation, ability to reuse waste heat generated etc . Dropping current and boosting voltage drops resistive losses during transmission so the overall loss for transmission is around 8-10%. So in terms of power generation electric cars are a tiny bit better for the environment whilst not being as practical, capable, convenient.
FTFY.
Falco wrote:
Battery production and disposal though? Yeeesh, what a nightmare. Whichever physical chemist (or their company) cracks decent battery tech is going to be so rich,
Not going to happen. 100 years of development, the most remarkable century of innovation and still no solution. It's a dead end.
asta1
PostPosted: 04:36 - 16 Nov 2017    Post subject: Reply with quote
Really? I'm just thinking about the last 10 years and there's been massive improvements. We're not there yet, granted, but there is still huge progress.
Take phones as an example. '80's phone had a battery the size of a brick. They provided sufficient power for a couple of hours call time and to power a two line black and green screen.
Fast forwards to the 90's. A phone battery is the size of a pack of cards, same functionality or better. 00's, battery even smaller, offers 3x the call time and has enough juice to start thinking about colour screens, 3G, internet, music. 2010's, an iphone lasts all day and has more processing power than an early 00's laptop. Full internet use, touch screen, games, ipod etc.
It's the same with everything. I remember with model helicopters (yes, I'm a nerd) in the late 00's when electric started beating glow fuel and petrol for performance. Why? Partly brushless motors sure, but the newfangled LiPo batteries started costing reasonable money, giving you 10minute flight times and the ability to pull stuff off that no glow fuel bird could do.
Cars will be the same. It'll take more time, but if we can continue improving the tech as we are, we're only talking another 30 years before a £500 battery will do 500miles and charge in 30mins. At that point, you have to ask what petrol is really providing to the average commuter...
The last post was made 6 years, 184 days ago. Instead of replying here, would creating a new thread be more useful?
Page 9 of 16
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.23 - MySQL Queries: 17 - Page Size: 158.05 Kb
