Charging a bike battery off a car?
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2, 3, 4, 5  Next
haroman666
PostPosted: 16:05 - 18 Nov 2017    Post subject: Reply with quote
Howling Terror wrote:
It rubs both ways...as it should.
Oooh matron!
Ted
PostPosted: 16:15 - 18 Nov 2017    Post subject: Reply with quote
Nobby the Bastard wrote:
Jesus H fucking Christ, is this still going on?
Yeah, but it's turning into a marriage counseling session, only with advice being given without knowing any circumstances! Rolling Eyes
'07 Honda CBF500 / '93 Vauxhall Astra (www.fb.com/2wdOffRoader) / '04 Vauxhall Movano
Projects: '81 Honda CX500 x2 / '85 Land Rover One-Ten / ...plus many horticultural things.
||| Bike Test: DAS: PASSED 13/02/2009 ||| Car Test: PASSED 22/05/2005 |||
MCN
PostPosted: 16:20 - 18 Nov 2017    Post subject: Reply with quote
I was waiting for a mod to drop this in F&F Ws for Assault on Battery. Embarassed
You cannot charge the battery from the cigarette lighter socket as it is only 12v.
The battery get a charging voltage from the alternator 14v-15v.
It will keep taking power from the alternator until it reaches 13volts.
The alternator will not supply any more volts or amps after that until the voltage in the battery drops again.
If you charge from the cigarette lighter you will not get 13 volts in the battery you will only get the regulated 12v from the vehicle system.
To charge from the car's batter connect the bike battery in parallel from the battery posts.
Positive to positive
Negative to negative
The alternator will pump in voltage to both batteries until they are both at 13 volts
There is some risk that the less robust construction of the motorcycle battery may be damaged by power surges in the vehicle's charging circuit so if you are determined to Bodge it do not be dismayed if it shite its sel;. Smile
Ted
PostPosted: 16:25 - 18 Nov 2017    Post subject: Reply with quote
MCN wrote:
To charge from the car's battery connect the bike battery in parallel from the battery posts.
That was my plan. That's how I've always charged spare car batteries.
Mr Hammers
PostPosted: 16:40 - 18 Nov 2017    Post subject: Reply with quote
I don't know your kitchen layout, or what flavour smoothies you like, but i could still quite rightly recommend that you don't shove your fingers in a blender. Wink
A Guide To Powerbands
Ted
PostPosted: 16:51 - 18 Nov 2017    Post subject: Reply with quote
I can't, I don't have a blender. So that advice would be redundant.
Triton Thrasher
PostPosted: 17:44 - 18 Nov 2017    Post subject: Reply with quote
When did they start connecting the fag lighter to a stabilised 12 V supply, rather than the vehicle's 12-14 and a bit "normal live" and why?
Or are you just making that up?
Rrrrrrrrrrrrrrrrrr
Triton Thrasher
PostPosted: 17:47 - 18 Nov 2017    Post subject: Reply with quote
Ste wrote:
Why can't you ride it?
Same reason he can't satisfy her.
Rrrrrrrrrrrrrrrrrr
CaNsA
Ted wrote:
-charging - due to my present living situation, charging at home is difficult. It involves charging a battery inside a crappy flat with electrical issues
I would bet a grand that you already have something more "dodgy" plugged into your electrical supply than a low draw battery charger.
Phone chargers are a low draw but are made using the cheapest parts possible and are more prone to failure than any half decent battery charger.
That there central heating and hot water is a heavy draw item, still got that connected?
But hey, what ever floats your attention seeking boat.
Ted
PostPosted: 18:10 - 18 Nov 2017    Post subject: Reply with quote
I was never seeking attention. Only an answer to what I thought was a straightforward question.
But nevermind, I've learnt my lesson; should have just charged it the way I do car batteries, and not asked for advice.
Ted
PostPosted: 18:12 - 18 Nov 2017    Post subject: Reply with quote
You mean I'm supposed to have that MoT'd too? Bugger...
You've had straight forward answers to your straight forward question.
Have you jump started the bike or charged the battery yet? Laughing
This is all really quite simple... you jump start the bike or you take the battery out and hook it up to a charger.
Gagged
Ted
PostPosted: 18:33 - 18 Nov 2017    Post subject: Reply with quote
You missed the charging off the car option there. Or was that intentional?
Not even looked at the bike since. Wouldn't even know if it's still there! Laughing
andyscooter
PostPosted: 11:28 - 19 Nov 2017    Post subject: Reply with quote
so how do you shut the bonnet of the car when driving about with two massive jump leads sticking out of it Confused Confused
I know you can have window open to get them back into the car but I'm sure driving about with the bonnet unclasped is dodgierr then putting a battery on charge inside a flat
Hong Kong Phooey
PostPosted: 11:39 - 19 Nov 2017    Post subject: Reply with quote
This is the perfect excuse to explain to the wife why you now need a new bike.
Ted
PostPosted: 16:28 - 19 Nov 2017    Post subject: Reply with quote
Between the rear edge and the plastic trim, over the rubber seal.
Bonnet shuts properly.
andyscooter
PostPosted: 12:44 - 20 Nov 2017    Post subject: Reply with quote
Simple solution
Take bike battery into local independent bike mechanic ask him to chuck it on charge
Most I've known will do it cheap or for the price of a pack of chocolate hobnobs
Job done
P.
PostPosted: 13:20 - 20 Nov 2017    Post subject: Reply with quote
Or just ride without an MOT.
Ted
PostPosted: 13:22 - 20 Nov 2017    Post subject: Reply with quote
Sounds like a plan. I might save myself some cash and cancel my insurance too.
P.
PostPosted: 13:23 - 20 Nov 2017    Post subject: Reply with quote
You can ride without an MOT you know... just book an MOT far away and don't turn up.
That said, its only a fine, no points n shit.
Northern Monkey
PostPosted: 14:14 - 20 Nov 2017    Post subject: Reply with quote
I got stopped (in the car) for no MOT a while back. Got given a produce in 14 days form. Took car for mot, took mot to cop shop. No fine. No drama
Ted
PostPosted: 14:20 - 20 Nov 2017    Post subject: Reply with quote
I'm not too bothered about riding it to get it somewhere, but not really got the time to be riding it around just to charge the battery.
I'm not even sure I've got the time to own a bike unfortunately.
owl
PostPosted: 14:50 - 08 Dec 2017    Post subject: Reply with quote
OP find his balls yet?
Observation is the greatest source of wisdom.
Chris45
PostPosted: 15:37 - 08 Dec 2017    Post subject: Reply with quote
Methinks the rules state "the nearest MOT station" or words to that effect. I once forgot about the MOT being due the day before my hols, still went touring Scotland for five days, no MOT, Tax or Insurance for that matter! Couldn't give a monkeys about it either... Changed times indeed.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
The last post was made 6 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Page 4 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.37 - MySQL Queries: 17 - Page Size: 140.43 Kb
