Wiring lights into a top box.
Ted
PostPosted: 21:08 - 06 Dec 2017    Post subject: Wiring lights into a top box. Reply with quote
I'm thinking about fitting lights to my top box. It's a Givi V46, I know they do a brake light kit, but it's not that I'm after. I'm thinking something like this:
https://youtu.be/kNuLyxDf5Ms
I'm thinking coloured LED strips, anyone got any recommendations?
What sort of connector can I use, needs to be waterproof and easy to plug and unplug?
Something like a trailer socket would be good, but much smaller.
Needs to have 5 pins (earth, tail, brake, left, right).
'07 Honda CBF500 / '93 Vauxhall Astra (www.fb.com/2wdOffRoader) / '04 Vauxhall Movano
Projects: '81 Honda CX500 x2 / '85 Land Rover One-Ten / ...plus many horticultural things.
||| Bike Test: DAS: PASSED 13/02/2009 ||| Car Test: PASSED 22/05/2005 |||
PostPosted: 21:32 - 06 Dec 2017    Post subject: Reply with quote
Any good?
https://www.ebay.co.uk/itm/Sets-Kits-Electrical-Waterproof-Connector-1-2-3-4-5-6-Pin-Way-seal-Car-Boat-wire/151989337465
Ted
PostPosted: 21:50 - 06 Dec 2017    Post subject: Reply with quote
I'm unsure how well those would hold up. When I've had to keep unplugging those in cars, they end up getting broken...
PostPosted: 21:57 - 06 Dec 2017    Post subject: Reply with quote
Can you solder? SP17 connectors.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0128.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0133.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0154.jpg
Ted
PostPosted: 22:02 - 06 Dec 2017    Post subject: Reply with quote
That looks likely! Do you know the name of that type of plug?
PostPosted: 22:07 - 06 Dec 2017    Post subject: Reply with quote
SP17 connectors.
Ted
PostPosted: 22:17 - 06 Dec 2017    Post subject: Reply with quote
stinkwheel wrote:
SP17 connectors.
You Sir, are a star! Thumbs Up
Ted
PostPosted: 22:29 - 06 Dec 2017    Post subject: Reply with quote
Just realised you had linked to them above your photos. I was too busy staring at the pretty pictures to notice! Laughing
jakebrownbass
PostPosted: 22:48 - 06 Dec 2017    Post subject: Reply with quote
jakebrownbass wrote:
Installed some lights into the top box. (Not technically today but over the weekend and finished off this evening)
1. Started things off easy with a couple of resistors & a diode on to some board. Added some tails to either end, then heat shrunk it all over.
https://cdn.img.versys.co.uk/IMG_7546.jpg
2. Spliced into the rear cluster, soldered & heat shrinked (no picture)
3. Time to start cutting, soldering & sealing with a glue gun on all the strips.
https://cdn.img.versys.co.uk/IMG_7576.jpg
4. Testing each one as i go.
https://cdn.img.versys.co.uk/IMG_7577.jpg
5. All done, heatshrinked the ends & ready to go.
https://cdn.img.versys.co.uk/IMG_7581.jpg
6. One side on.
https://cdn.img.versys.co.uk/IMG_7582.jpg
7. Second side done, wires wrapped, holes drilled & threaded through.
https://cdn.img.versys.co.uk/IMG_7583.jpg
8. Internal wires twisted, soldered and screwed into a temporary block for now until i decided how to finish it off as neat as possible.
https://cdn.img.versys.co.uk/IMG_7584.jpg
9. Neutrik XLR connecter wire up on to the tail, with a chassis mount connector mounted to the base of the top box via rivets & sealant. Means its a quick plug & play when taking the box on & off.
https://cdn.img.versys.co.uk/IMG_7587.jpg
10. And we're all done.
https://cdn.img.versys.co.uk/IMG_7586.jpg
Still to do......
One of the rows is out on the LHS, not sure when it happened because i tested each strip at every stage, will investigate further when i finish off the inside to a happy standard.
Hyosung GTR 125 ---> Suzuki GSXR 400R ---> Kawasaki 636 ---> Break ---> Kawasaki Versys 650
Ted
PostPosted: 22:53 - 06 Dec 2017    Post subject: Reply with quote
That's looking good! Where did you get the LEDs, and would you say they are a good brightness? (Always hard to tell in photos)
Ted
PostPosted: 15:05 - 07 Dec 2017    Post subject: Reply with quote
Had a quick look on eBay and found these:
https://m.ebay.co.uk/itm/4-X-5050-LED-Strip-Light-12V-Car-Van-White-Blue-Red-Green-Warm-White-10-30-cm/262729654098
I was thinking 10cm ones,
- x4 red for tails,
- x4 white for brake (lens is red, figure white will show up brighter)
- 4x orange for indicators
Would that be enough?
Hahadumball
PostPosted: 15:24 - 07 Dec 2017    Post subject: Reply with quote
i made my own on my old topbox, wired to brake light using a contact switch and contact terminals.
was ite.
used blue wire for testing coz pikey
https://www.youtube.com/watch?v=CxmunEUJ25o
i also made skywaterfriend
https://www.youtube.com/watch?v=VyGQazXv6gU
donate to my crowdfunding for never release
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
The last post was made 6 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 17 - Page Size: 84.78 Kb
