What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 286, 287, 288 ... 407, 408, 409  Next
Courier265
PostPosted: 15:11 - 10 Dec 2017    Post subject: Reply with quote
CB250 - checked oil, lights, horn and finally replaced the old base plate
which had a rickman topbox for a new METAL base plate for a modern
Givi Top box. (Replaced the fitting kit too PLUS double bolted)
chickenstrip
PostPosted: 15:53 - 10 Dec 2017    Post subject: Reply with quote
This all reminds me...I think I've got a bike somewhere Confused
ThatDippyTwat
PostPosted: 16:25 - 10 Dec 2017    Post subject: Reply with quote
Cleared and salted a path for it, I still have to go out on it in the morning, irrespective of weather.
Fisty
PostPosted: 21:10 - 10 Dec 2017    Post subject: Reply with quote
Helped by my glamorous assistant Fret, we:-
Arrow Fitted new chain and sprockets
Arrow Fitted carbon tank guard
Arrow Fitted Carbon fender extender
Arrow Fitted Power commander 5
Failed to start it as the now 12 year old battery decided to shit itself.
https://i.imgur.com/8wtC8vT.jpg
https://i.imgur.com/BTlNbop.jpg
Still to do.....
Fit Ohlins
Fit Yoshimura
Fit Scottoiler
Fit new tyres
Fit hugger
Dyno session.
Fatter and faster than Fret
ThatDippyTwat
PostPosted: 17:02 - 11 Dec 2017    Post subject: Reply with quote
Freed brake piston off again, removed it, cleaned it, seated it back.
Replaced a bolt that disappeared sometime today that is helping to hold insturments on. Decided to replace the other that was working itself out. Split washers used to try to preventy it happening again.
Removed chainguard, cleaned it, lubed and tnesioned chain, 'adjusted' (twatted it) chainguard to not hit chain.
Liberated some grit from the gritbox to try to make my route to the main road less of a fucking ice rink.
All in 6" of icy fucking snow.
AldridgePrior This post is not being displayed because the poster is banned. Unhide this post / all posts.
kawakid
PostPosted: 12:21 - 12 Dec 2017    Post subject: Reply with quote
For the first time in 2017, I have left it at home and gone in the car.
I was bricking it yesterday coming home from work and must have been annoying car drivers as I was on the back brake doing no more than 20mph in places.
Today, the cul de sac where I live was totally frozen, that and the hill to the bottom was too. It was -4.5C tbf.
I was annoying though, on the bike my commute is 12 to 15 mins, it took me ~ 35 minutes in the car.
I've a twin and a 4.
NJD
PostPosted: 23:54 - 18 Dec 2017    Post subject: Reply with quote
Freed-up some of the rollers in the chain one by one because time on my hands followed by a generous coating of lubrication.
Used it for the first time in over a week: slightly slippy but all good fun.
DrSnoosnoo
PostPosted: 10:58 - 19 Dec 2017    Post subject: Reply with quote
I actually rode it to work!
alternator belt snapped on the car so the bike had to be dug out the shed. It was running like a lumpy bag of lumps when I set off.
Running a bit smoother after the 25 mile run along the national speed limits. Surprised by how mild it is. I don't even have the muffs on!
Hong Kong Phooey
PostPosted: 21:49 - 20 Dec 2017    Post subject: Reply with quote
Condensation filed garage combined with putting it away salty has combined to form white nodules all over the cbr Embarassed
Hosed, acf'd, apologised profusely. It's a 90's Honda so no harm.
Warmed the acf up under the hot tap, much better spray pattern.
Can't remember whose tip that was but Thumbs Up
Cranked over slowly in the cold, been stood for 2wks but eventually fired up.
Started fine tonight after the ride home from work.
ThatDippyTwat
PostPosted: 22:28 - 20 Dec 2017    Post subject: Reply with quote
De-crudded the rear drum which locked on - Road crud in the cam.
Patched exhaust again.
Kawasaki Jimbo
PostPosted: 21:14 - 21 Dec 2017    Post subject: Reply with quote
Took the Kawasaki's fork stanchions (the shiny tubes, I've only just learned that's what they're called) to Philpot's in Luton for rechroming. They kept leaking oil although to my eyes the chrome didn't look too bad, but the chap confirmed that the pitting was significant. Pick up in 6 weeks.
Wheezybiker
PostPosted: 12:49 - 23 Dec 2017    Post subject: Reply with quote
Cleaned it checked and lubed chain
Realised using a compressor to dry is quicker than cloths
Chain slack is just over 50mm Haynes says 46-55 is allowed so still got some miles in it yet then I can adjust it on the back wheel as I have some room left 2nd mark out of 5
ThatDippyTwat
PostPosted: 18:12 - 23 Dec 2017    Post subject: Reply with quote
Patched exhaust yet again. Bit bullet and ordered a new one, with studs and copper gasket. Chrome will have to go, but I can blast it in work and VHT it once I know it doesn't leak like a sieve.
Oil and filter change.
Cleaned excess road crud from motor and wrapped downpipe.
Fitted rear shoes, cleaned out road crud from drum and cam.
Wheel bearings and rear shocks also bought, need to do at some point over the xmas break.
Petemate
PostPosted: 18:46 - 24 Dec 2017    Post subject: Reply with quote
Removed the plugs and "warmed" them up over one of the gas rings in the kitchen. This after failed attempt to start the bike. My own fault - I had not used the bike in nearly ten days, and although I had turned off the fuel, I had also failed to run the engine until the carb emptied. The VB series carburettor, having possibly been designed by an ancestor of the person wot designed the Hampton Court maze, has some horrible slow running passages in which the dreaded gumming of petrol enjoys making all our lives a misery. Lesson learned; as the bike will be off the road for another two weeks or so, the carb has now been emptied of all traces of petrol.
Bah Humbug.
82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth
M.C
PostPosted: 20:04 - 24 Dec 2017    Post subject: Reply with quote
Bah Humbug.
This is why I ride bikes from this century Wink
OliGibbs
PostPosted: 15:44 - 25 Dec 2017    Post subject: Reply with quote
I drove it for a couple hundred meters and filled the tank. Embarassed
Beehive Bedlam This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
waffles
PostPosted: 15:24 - 26 Dec 2017    Post subject: Reply with quote
I went to check on both bikes yesterday, the gixer wouldn't start so I left it on trickle charge for a few hours. Fortunately it fired up so I left it on charge overnight. Bearing in mind its electrical problems this year I was pretty surprised when it fired up!
I took the grom out for a ride today and despite the oil having that lovely cottage cheese effect on it, it was all fine. It had lost a number plate bolt (they seem to vibrate out) so straightened the plate and fitted a longer bolt and nut. I need to give both bikes a clean and fit some hand guards to the grom.
Overall, some positive bike stuff for a change!
TheMadRatter
PostPosted: 17:26 - 26 Dec 2017    Post subject: Reply with quote
Technically today- I was still out there Ratting at about 2am. Needed some heat Very Happy Fit R1 tail plastics...
https://www.facebook.com/brokenbiker/videos/466150480453113/
TheMadRatter | Lurch .:. Afghan Heroes ✓, RTWR ?,Rainpal ?
CM125 X|GZ125 X|Cagiva Elefant X|GL1200 ✓|Aprilia Classic X|GSX400T X|Kymco Hipster ✓|Kymco Zing X|XV535 X|VL750P X|FZ6 ✓|FJ1100 X|Desperado ✓|Countless Chinese imports ✓|Rialto Trike ✓|Countless forgotten rides
kramdra
PostPosted: 13:06 - 27 Dec 2017    Post subject: Reply with quote
Added temp and voltmeter to bike. Cheap chinese items but had to make a case to waterproof.
https://s17.postimg.org/jukxs6rpr/IMG_20171227_083207.jpg
Seems I need to waterproof the sensor connector.. 10 miles in, started to show11 degrees while my left hand was going numb from wiping the ice off visor.
Hong Kong Phooey
PostPosted: 16:21 - 27 Dec 2017    Post subject: Reply with quote
Aftermarket clip ons, do they interfere with the fairings, looks like you've adjusted the top clamp.
kramdra
PostPosted: 17:05 - 27 Dec 2017    Post subject: Reply with quote
Yes they are wose than the originals for it, one of my hates about the cbr6, the throttle and master are designed to interfeer.. However the right bar is bent from a slow speed drop which makes it not as bad. However its cheap to replace the bars when they bend.
I am tempted to machine up some new clamps to be more like the originals yet allow replaceable bars. I would prefer to find a remote res master with the same piston size and a better throttle housing.
The last post was made 6 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 287 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.57 - MySQL Queries: 17 - Page Size: 137.33 Kb
