Plus Gas
cb1rocket
PostPosted: 13:17 - 16 Dec 2017    Post subject: Plus Gas Reply with quote
Who sells the plus gas from shops like halfords etc?
except halfords don't sell it Rolling Eyes
bugeye_bob
PostPosted: 13:20 - 16 Dec 2017    Post subject: Reply with quote
Toolstation & Screwfix off the top of my head. .
Islander
PostPosted: 13:22 - 16 Dec 2017    Post subject: Reply with quote
Most decent motor factors type shops. It doesn't have to be Plus Gas either, as long as it's a penetrating oil it'll work just fine. Thumbs Up
Commuter_Tim
PostPosted: 13:30 - 16 Dec 2017    Post subject: Reply with quote
Wickes and B&Q both had it last I checked. (granted this was a long time ago)
I ride a Bandit 600... badly.
Itchy
Screwfix does a no nonsense penetrating fluid. I bought a can a few weeks ago it's pretty much the same but smells a bit weaker.
cb1rocket
PostPosted: 13:31 - 16 Dec 2017    Post subject: Reply with quote
i hear time and time again......everyone believes in plus gas Vs WD-40
Islander
PostPosted: 13:42 - 16 Dec 2017    Post subject: Reply with quote
Well WD (Water Dispersant) 40 isn't designed as a penetrating oil whereas something labelled "Somebrand Penetrating Oil" will actually be designed to do the job. Plus Gas just happens to be the original brand.
PostPosted: 13:45 - 16 Dec 2017    Post subject: Reply with quote
Euro Car Parts, Tool Station, pretty much any auto factors, etc etc etc.
Wickes sell their own brand one and I think B&Q also sell their own one.
There's a specific flavour of WD40 which is a penetrating oil.
tl;dr everywhere sells it. Apart from Halfrauds.
kramdra
PostPosted: 15:11 - 16 Dec 2017    Post subject: Reply with quote
Halfauds did sell penetrating oil as I had a can with their branding. I did not find it any more effective than water dispersant oils.
Some time ago it was said that a 50;50 mix? of transmission oil and petrol works better.
cb1rocket
PostPosted: 15:48 - 16 Dec 2017    Post subject: Reply with quote
Ideally after plus gas, all the shops you guys have mentioned don't stock it .
Online it is then Sad
PostPosted: 16:15 - 16 Dec 2017    Post subject: Reply with quote
Your local auto factors stock it. Wink
ZebraDriver
PostPosted: 16:29 - 16 Dec 2017    Post subject: Reply with quote
Don't know exactly what you need Plus Gas for but Diesel fuel makes a pretty good penetrating oil ,and its cheap enough that you can submerge items in a bucketful of the stuff. It also makes a pretty good drill lubricant/coolant.
ZD
bugeye_bob
PostPosted: 17:05 - 16 Dec 2017    Post subject: Reply with quote
Bizarre, as there are multiple Screwfix stores with stock near me.
MCN
PostPosted: 17:27 - 16 Dec 2017    Post subject: Reply with quote
Jeez.. another case of a broken Google. 😲
PostPosted: 19:13 - 16 Dec 2017    Post subject: Reply with quote
A 50:50 mix of ATF and paraffin makes an acceptable penetrating oil.
stevo as b4
PostPosted: 19:17 - 16 Dec 2017    Post subject: Reply with quote
There's lots of Plus Gas rivals all designed to do the same job. You'd get at least one brand at Wilko etc.
Sounds a bit like the ACF 50 is the only anti corrosion treatment that won't see your bike rot to dust in 5minutes flat syndrome.
Tankie
PostPosted: 19:26 - 16 Dec 2017    Post subject: Reply with quote
Some of us use ATF and acetone 50/50 mix, normally used to free two stroke cylinders , can take up to a couple of weeks to penetrate
PostPosted: 22:02 - 16 Dec 2017    Post subject: Reply with quote
To which I would always add the caveat that acetone and rubber or plastic componants (oil seals, airbox rubbers, carb gaskets etc) do not always play well together.
Jewlio Rides Again LLB
PostPosted: 22:11 - 16 Dec 2017    Post subject: Reply with quote
PlusGas and Loctite Freeze & Release both handy for cracking open stubborn nuts & bolts. Both available on eBay / Amazon.
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
ThatDippyTwat
PostPosted: 00:11 - 17 Dec 2017    Post subject: Reply with quote
Comma release oil, rather unsurprisingly, releases stuck nuts. On par with Plusgas I'd say.
cb1rocket
PostPosted: 10:12 - 17 Dec 2017    Post subject: Reply with quote
Can't see it in their catalogue?
PostPosted: 10:30 - 17 Dec 2017    Post subject: Reply with quote
It's their own brand. Works fine
https://www.screwfix.com/p/no-nonsense-penetrating-lubricating-oil-750ml/19320#_=p
Toolstation have their own as well...
https://www.toolstation.com/shop/p62311?searchstr=penetrating%20
As well as WD40's version.....
https://www.toolstation.com/shop/p20970?searchstr=penetr
Don't get fixated on brand names.
Triumph Trophy Launch Edition
cb1rocket
PostPosted: 11:45 - 17 Dec 2017    Post subject: Reply with quote
Cheers for all.
I was fixated on plus gas as people swear by them.
Ie in other words nothing comes close to it. And thats coming from topics off the workshop section here
Cheers for all the other tips on diesel/atf etc etc
dydey90
PostPosted: 18:35 - 17 Dec 2017    Post subject: Reply with quote
Triflow is what you need.
SAS 20 also works very well too.
PostPosted: 21:20 - 17 Dec 2017    Post subject: Reply with quote
Duck oil is also still on the market. It was one of the first penetrating/releasing oils. It has the advantage of coming in a can as well as an aerosol which makes it more cost effective if buying in bulk.
The last post was made 8 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.62 - MySQL Queries: 16 - Page Size: 131.69 Kb
