GSX 400 spark issue
Farmingstock
PostPosted: 16:09 - 02 Jan 2018    Post subject: GSX 400 spark issue Reply with quote
I have a GSX400 bandit and one of the coils doesn’t produce a spark.
The other side sparks and when I plug the coil into the other side of the loom (instead of the other coil) the coil is fine and sparks fine so it’s not the actual coil.
The good coil doesn’t work either when wired to the bad side wiring!
The voltage is the same as the battery on both sides of the wiring with ignition on!
Any other ideas to try and rectify this?
redeem ouzzer
PostPosted: 18:04 - 02 Jan 2018    Post subject: Reply with quote
You can have +12v on both sides of the coil circuit (orange wire) and not have a spark. I would be checking continuity from the other side of the coils (white wire one side, black / yellow other) to the CDI plug for a start. If you have a spark i can't see it being the pulser coil as there is only one output (uses a wasted spark).
Be a REAL MAN!
Farmingstock
PostPosted: 18:58 - 02 Jan 2018    Post subject: Reply with quote
Thank you for the reply, much appreciated.
Is there two seperate supply’s from the CDI? One for each coil? I will be checking the continuity in the morning definitely.
The right side wiring sparks absolutely fine with either coil, so I’d say the coils are fine!! I’m thinking it’s likely to be a possible wiring/CDI issue, am I on the right lines here??
Or
Would the right side not spark either if it was a CDI issue??
Thanks again, I’m learning so maybe silly questions
redeem ouzzer
PostPosted: 19:35 - 02 Jan 2018    Post subject: Reply with quote
The coils share a common 12V feed (orange or orange / white depending on the model). If you have 12V between the orange wire and earth from both coil plugs (and both coils fire if tried on one side) then the issue must be between the coils and the CDI. You need to measure continuity between the other side of the coil plugs and the CDI multiplug to elimnate the possibility of a broken wire in the loom. If the wiring checks out it could well be the CDI that's at fault as there is a transistor for each coil feed and they can fail with age.
Be a REAL MAN!
Farmingstock
PostPosted: 19:53 - 02 Jan 2018    Post subject: Reply with quote
Thanks again,
I’ve just been out and there is continuity from each wire at the coil back to the corresponding wire at the CDI!!
This would point towards an issue with the CDI I presume??
Is there any other tests I could do on the CDI? Before I start the search for a replacement??
Much appreciated
PostPosted: 20:53 - 02 Jan 2018    Post subject: Reply with quote
CDI ignition works by having the coil powered at all times and the ignition unit switching the return side to create the spark.
From your diagnosis it seems that you have power to both coils but only one sparks and if you plug the non-sparking one into the other side it then does spark.
You don't say if you tried the sparking one in the non-sparking side?
My next move would be to pull the CDI plug and carefully inspect both male and female terminals. Any sign of black or green crud could indicate a poor contact. I'd also be tempted to pop the pins out of the CDI plug and reverse them, to eliminate a wiring fault. If you do both of those and it's still dead I would say the CDI is a goner.
Farmingstock
PostPosted: 21:10 - 02 Jan 2018    Post subject: Reply with quote
Yeah I have tried the good coil on the bad side but that makes no difference!
No crud or green stuff but it does look like something has got hot around there, I will try swapping the terminals over tomorrow but yeah I think it’s the CDI to be honest.
Thanks again
redeem ouzzer
PostPosted: 21:17 - 02 Jan 2018    Post subject: Reply with quote
Without the Suzuki test unit I've yet to see a 100% accurate way of checking the CDI unit, so i'd assume if wiring and coils check out ok then the fault must be within the CDI itself (usually a blown transistor).
Plenty of chinky CDI's on amazon / ebay, just make sure you get the right pin layout as later bikes are different which coincides with the 54ps limit.
Be a REAL MAN!
Farmingstock
PostPosted: 22:01 - 02 Jan 2018    Post subject: Reply with quote
Would it be possible to try the gsx 600/900 CDI? They look exactly the same and the first few numbers are the same or would they be completely different?
There are lots on ebay for £20/30
redeem ouzzer
PostPosted: 22:15 - 02 Jan 2018    Post subject: Reply with quote
If the pin configuration is the same then they should work, the Rev limit and ignition curve won’t suit the 400 engine though.
Be a REAL MAN!
Farmingstock
PostPosted: 17:10 - 03 Jan 2018    Post subject: Reply with quote
Managed to sort the sparking issue, well all four plugs spark now!! So it’s a start, after trying to get the engine started tho (it hasn’t been started for a while) some how managed to set on fire, luckily I dragged everything out including the petrol can that was on fire!!
Anyway!! The carb was leaking and there must have been a short on the starter that’s just underneath or something I don’t know, but next job is rebuilding the carbs! I have stripped and am now soaking! All jets were bunged so no wonder it didn’t start! But I need some parts!
They don’t have a model number on them anywhere just Mikuni that’s it!
Any ideas on model number??
redeem ouzzer
PostPosted: 18:58 - 03 Jan 2018    Post subject: Reply with quote
You’ll need these for a start.
https://www.litetek.co/Carb_Kit_Suzuki_GSF400.html
Be a REAL MAN!
Farmingstock
PostPosted: 18:35 - 04 Jan 2018    Post subject: Reply with quote
That’s great thanks for that, I think I’m gonna need both sets and some sort of washers that hold the springs down! The carbs look like they are off a different bike as they don’t match the gsf carbs maybe the RF400.
This engine is for a project I am working on and it’s not going in the original bike! But should it have an electronic fuel pump to actually run as a start up test or in general and where does the carbs get the vacuum from for the top pipe.
Thanks again for being so helpful
PostPosted: 19:01 - 04 Jan 2018    Post subject: Reply with quote
See those four off-white plastic housings in the big tin, they plug into the carb bodies with o-rings to seal. You should carefully inspect those things because they look like all they do is hold the floats but the ones on my sister's bike had little jets in them that fed the cold starting circuit and they were so clogged up with crud you couldn't even tell that the jets were there.
Farmingstock
PostPosted: 21:12 - 04 Jan 2018    Post subject: Reply with quote
Thanks for the heads up, I will check them out not noticed a valve tho tbh
Farmingstock
PostPosted: 20:33 - 20 Feb 2018    Post subject: Reply with quote
Does anyone know the firing order on the Suzuki 400 bandit engine?
I’ve got spark, rebuilt the carbs but am just getting nothing or intermittent backfiring from the exhaust.
I know one coil is 1 and 4 and the other coil is 2 and 3!!
But looking forward from the carb side, is number 1 on the left and should it matter which coil wiring on which side??
Thanks
PostPosted: 21:07 - 20 Feb 2018    Post subject: Reply with quote
Thanks
1-4 left to right as you sit on the bike. The HT leads are usually obviously the proper length and it doesn't matter if you get 1/4 or 2/3 backwards but it DOES matter if you put the wrong 12v wires on the coils.
Farmingstock
PostPosted: 21:59 - 20 Feb 2018    Post subject: Reply with quote
Thanks for the info, much appreciated.
I’m trying to get the engine running on a stand off the frame, so have had a lot of figuring out to do.
Looks like I may have the coils on the wrong wiring!!
Farmingstock
PostPosted: 19:45 - 21 Feb 2018    Post subject: Reply with quote
I’ve tried different combinations and still can’t get it to start!! After 30 seconds or more of turning it over the plugs are dry, although it should be getting fuel as the carbs have been rebuilt and the jets are clean and clear??
Any ideas???
Raffles
PostPosted: 21:50 - 21 Feb 2018    Post subject: Reply with quote
Farmingstock wrote:
....I’m trying to get the engine running on a stand off the frame....
Farmingstock wrote:
....the plugs are dry, although it should be getting fuel as the carbs have been rebuilt....
Any ideas???
How is fuel being delivered to the carbs?
Farmingstock
PostPosted: 22:16 - 21 Feb 2018    Post subject: Reply with quote
Raffles wrote:
Any ideas???
I have just got a gravity fed temp tank, fuel it getting to the carbs as it leaks out when I undo the overflows, but the plugs are completely dry! If I put my hand over the carbs when turning over there is plenty of suction and fuel comes out on my hand.
Farmingstock
PostPosted: 21:41 - 22 Feb 2018    Post subject: Reply with quote
Any other ideas?? There is definitely spark, compression and fuel, I’m not sure on weather the vacum part of the carbs are opening as I can’t see them?? How do they lift??
I haven’t tried any easy start yet, it just seems to either do nothing or spit out of the carbs or backfire!!
I’m banging my head against the wall
The last post was made 6 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.55 - MySQL Queries: 17 - Page Size: 116.39 Kb
