Brakes Stuck On
Renton
PostPosted: 15:19 - 27 Jan 2018    Post subject: Brakes Stuck On Reply with quote
Regrettably, the bike has been left untouched for the last month...outside.
I've gone to move it today, but it will not budge anywhere. It looks as though the front brakes are stuck on.
How do I go about taking the callipers off to clean them, if I cannot even move the front wheel. So bad that I was able to lift the bike off the ground by holding one of the front wheel spokes.
Yes, I am suitably ashamed of myself.
This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless.
PostPosted: 15:25 - 27 Jan 2018    Post subject: Reply with quote
There's probably nothing wrong with the calipers the pads will be rusted to the disks. Give the front tyre a few good clouts with a big hammer right on the front. Take care not to hit the wheel or the mudguard.
Irn-Bru
PostPosted: 15:39 - 27 Jan 2018    Post subject: Reply with quote
Wouldn't advise pushing it, recently ripped the rear pads clean off on my KTM doing that Laughing
Renton
PostPosted: 15:44 - 27 Jan 2018    Post subject: Reply with quote
I'll give it a go Thumbs Up
The other bike moved straight away without any problems, and I've not had this issue in the past, so it was a little worrying at first.
Shocked
Courier265
PostPosted: 16:05 - 27 Jan 2018    Post subject: Reply with quote
Spray the calliper with brake cleaner then try rolling the bike forward, if that doesn't work break out the G clamp and push the pistons in and pray... Once you get the wheel moving remove the calliper, strip it down.
Had this on my CB250 during winter months, brake cleaner does the job but I did find the sliders needed a grease up.
Pjay
PostPosted: 16:42 - 27 Jan 2018    Post subject: Reply with quote
A nice soak in WD40 is probably a bad idea but would free them up lovely.
struan80 - I'll go first - satisfied tick 1
PostPosted: 16:44 - 27 Jan 2018    Post subject: Reply with quote
Don't do this BTW.
PostPosted: 16:55 - 27 Jan 2018    Post subject: Reply with quote
Pjay ...You bellend. Rolling Eyes Laughing
Pjay
PostPosted: 17:00 - 27 Jan 2018    Post subject: Reply with quote
I'm not sure anyone is stupid enough to WD40 their brakes.
If they are, I've done the world a favour.
PostPosted: 18:02 - 27 Jan 2018    Post subject: Reply with quote
Agree with Pete. One of the few times a bit of brute force and ignorance is called for. Laughing
Irn-Bru
PostPosted: 18:38 - 27 Jan 2018    Post subject: Reply with quote
Renton wrote:
Shocked
Worst part was it was in front of a mechanic that came to collect the bike for a service... hang on a minute *clunk* oops... right, I've got another job for you Laughing
PostPosted: 19:36 - 27 Jan 2018    Post subject: Reply with quote
Doesn't say much for the bonding of the pad material. In fact, I'd go so far as to say it must have been defective. If it came off with you pushing the bike, there's no way it would have stayed on if you stood on the brake at 100mph.
Bozzy.
PostPosted: 20:34 - 27 Jan 2018    Post subject: Reply with quote
^^^^ inb4 knock off eBay Goldfrens.
SV650S>>>Street Triple R
RhynoCZ
PostPosted: 20:51 - 27 Jan 2018    Post subject: Reply with quote
I thought no one would be stupid enough to weld the front sprocket to the output shaft of the gearbox. So it would not surprise me if anyone did the WD40 treatment.
After all, the worst that can, and will, happen is swollen seals. Which gives you/op/anyone a great opportunity to rebuild the calipers. Razz
Nobby the Bastard
Harley Gaydar
PostPosted: 21:09 - 27 Jan 2018    Post subject: Reply with quote
Belt the callipers with a mallet at 90 degrees to the direction of travel.
Triumph Sprint ST 1050
kerr
PostPosted: 21:30 - 27 Jan 2018    Post subject: Reply with quote
Ha, i remember years ago a thread on a yank muscle car forum, where a guy tried to flush his engine with tap water after someone on the forum told him to do it as an obvious joke Laughing Laughing Laughing Laughing
As far as people could tell it wasn't a troll thread.
EDIT:
and yes he seized his engine solid.
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
PostPosted: 22:39 - 27 Jan 2018    Post subject: Reply with quote
Good idea if you want to bend the aluminium disc carrier.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:44 - 27 Jan 2018    Post subject: Reply with quote
If the pistons are so seized that the disc carrier bends then the brakes are pretty fucked anyway.
MCN
PostPosted: 02:08 - 28 Jan 2018    Post subject: Reply with quote
You fucking piece of shite.
No one uses WD-40 on their brakes now-a-days. Shocked
3 IN 1 Oil is what we use now.
Very Happy
Then to clean the 3 in 1 off one simply immerses one's head in a pot of boiling water. Thumbs Up
Teflon-Mike
tl;dr
PostPosted: 05:34 - 28 Jan 2018    Post subject: Reply with quote
Once upon a time... it was 'more' common for an unused bikes brakes to rust-on.... bain of metalised pads and cast discs... (mental anguish scream BLUDI-GUZZI!!)
Since stainless discs became the norm, it's not been so common.... but getting more so.... probably chitty non OEM Chinky un-stainless discs to blame
Otherwise, and especuliarly on Honda's, more likely a gummed up floating caliper... tendency is to grab the brake when you grab the bars.. corroded caliper grips disc, corrosion makes it stick there.
Brute force over ignorance can 'un-stick' them, but ht is that calipers probably need an overhaul, & thorough clan de-gunk, and grease.
I am rather loath to use the G-Clamp trick to press piston back into caliper body... if there's enough ali-fir in the caliper and or the piston is sufficiently corroded to stick, whats that crud going to do when forced back past the seals? Good way to promote a failure to my mind... pistons should self retract.
Loose caliper bolts, pry from forks or carrier with a tyre lever or similar, clean and inspect, and work fro there when you can see how bad it is.
PostPosted: 10:03 - 28 Jan 2018    Post subject: Reply with quote
No, they are just stuck.
There won't be anything wrong with the discs - until you twat them with a mallet of course.
andyscooter
PostPosted: 10:39 - 28 Jan 2018    Post subject: Reply with quote
try a bit of mr sheen on the disk
it will burn off when you use the brakes again but may get enough doen behind the pad to free it off
I'm not joking either I often clean my disks with it
PostPosted: 12:37 - 28 Jan 2018    Post subject: Reply with quote
Yeah wax your brake discs. Another world-beating idea. That would be the only circumstance I would advocate smashing them with a mallet afterwards.
PostPosted: 13:40 - 28 Jan 2018    Post subject: Reply with quote
The only thing you should deliberately put on brake discs is brake pads.
Islander
PostPosted: 15:28 - 28 Jan 2018    Post subject: Reply with quote
And brake cleaner, of course... Wink
The last post was made 8 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.07 - MySQL Queries: 16 - Page Size: 140.72 Kb
