Author |
Dave70 |
Dave70 World Chat Champion
Posted: 14:55 - 08 Feb 2018 Post subject: |
Back to top |
M.C |
M.C Super Spammer
Back to top |
Howling Terror |
Howling Terror Super Spammer
Back to top |
Kawasaki Jimbo |
Kawasaki Jimbo World Chat Champion
Back to top |
haroman666 |
haroman666 World Chat Champion
Posted: 09:33 - 09 Feb 2018 Post subject: |
Back to top |
MCN |
MCN Super Spammer
Posted: 14:14 - 10 Feb 2018 Post subject: |
I just MOTed, (Failed) fitted a new tyre (£170). MOT Passed. Taxed the hoowur for another year and parked it up.
Now I have the other fcuker to deal with.
TAX and MOT ending this month and I am not anywhere close enough to use the bastirt so....
SORNed.
I just fitted a new battery to the beast too.
Now have the MOT and Tax to look forward to next month.
Get a bike they said, it will be cheaper than a car...
____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Back to top |
TheSmiler |
TheSmiler World Chat Champion
Posted: 23:28 - 10 Feb 2018 Post subject: |
Today I did some simple work on two bikes, removed the pannier rails and cut the mudguard down to size with the dreme ready for the seat measuring. Don't fancy altering the frame on this new bike so going to try and keep it original with a bit of editing.
On the to do list is following;
Sorting out seat
New headlight
Service
Tail light
New number plate bracket
Indicators.
Fork Gaiters
https://i.imgur.com/Rmv4Du0.jpg
After
https://i.imgur.com/z01GwDq.jpg
Then drilled and fitted the indicators, neatened up the poppy on the tail to "not cause offence" and cable tie the monkey into position after drilling.
https://i.imgur.com/9nSgvJ4l.jpg ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
A2 completed 23/07/15 Ready for the Golden Crisp Packet |
Back to top |
Ste |
Ste Not Work Safe
Posted: 23:50 - 10 Feb 2018 Post subject: |
Needs less subframe, approximately one foot less subframe.
I hope you're doing useful servicing as well as tarting it up. |
Back to top |
Howling Terror |
Back to top |
TheSmiler |
Back to top |
Beehive Bedlam |
Beehive Bedlam World Chat Champion
Posted: 14:17 - 11 Feb 2018 Post subject: |
Weekly checks came up with a few surprises.
The front brake light switch the terminal had snapped off so the brake light wouldn't come on when I applied the brake.
Fixed.
https://i.imgur.com/PYGn3mm.jpg
Also the rear brake pedal spring was knackered the brake light wasn't coming on immediately so I replaced that as well.
https://i.imgur.com/syGJH2w.jpg
Also a light smear of oil on the left fork stanchion nothing too alarming but the forks will benefit from a overhaul I might replace the tired old springs for some Ohlins whilst I'm at it.
https://i.imgur.com/2499PxB.jpg
Oil level, chain tension, etc etc all fine. |
Back to top |
ThatDippyTwat |
ThatDippyTwat World Chat Champion
Back to top |
Courier265 |
Courier265 World Chat Champion
Back to top |
MarJay |
MarJay But it's British!
Back to top |
pepperami |
pepperami Super Spammer
Posted: 17:46 - 11 Feb 2018 Post subject: |
After taking the Chinese pos out last week when it was wet, windy, dirty, salty and generally shite, I cleaned it today.
Nothing has corroded away or fallen off
ACF is a wonderful thing ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
Back to top |
Pigeon |
Pigeon World Chat Champion
Back to top |
redeem ouzzer |
redeem ouzzer World Chat Champion
Posted: 00:55 - 12 Feb 2018 Post subject: |
YR5 just about done. Fought me at the finish though. QR coupling on the tank balance pipe leaked, drained tank, fitted spare. Spare leaked, drained tank again, hard piped it. Having to drain the tank to remove it is a pain in the arse so I do need to figure out a solution.
Plugged laptop in to check map settings and also that the shift light on my funky new clock set up worked (turned it down to activate at 3k to test, then back up to 9k as per usual).
https://flic.kr/p/KjyFna
Finally got to have a ride today after solving fuel leak issue. Was pretty clogged up for the first few miles but then cleared ok. Rides well, 6 speed box is much better and the clutch actually lets you find neutral now it doesn't have any bent plates. Having a functioning rev counter pretty much tallies the dyno curve. Nothing below 6k, good power at 7k through to 9. Riding position with clipons is good, not comfortable but then it's not a bike you'll spend much time in the saddle on as it needs lots of fuel stops!
https://farm5.staticflickr.com/4707/39314570735_6e6875d06b_k.jpg
https://farm5.staticflickr.com/4710/39500953304_e576f42d37_k.jpg[/url]
Few jobs to do, gear lever is a bit low and speedo seems to under read so need to find another one. ____________________ Be a REAL MAN! |
Back to top |
pompousporcup... |
pompousporcup... World Chat Champion
Back to top |
redeem ouzzer |
Posted: 18:55 - 12 Feb 2018 Post subject: |
Back to top |
Fizzer Thou |
Back to top |
Hong Kong Phooey |
Hong Kong Phooey World Chat Champion
Back to top |
Pigeon |
Back to top |
haroman666 |
Back to top |
Fizzer Thou |
Back to top |
ThatDippyTwat |
Back to top |
The last post was made 6 years, 116 days ago. Instead of replying here, would creating a new thread be more useful? |
