Preferred method for soldering clusterfucked wiring?
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2
ThatDippyTwat
PostPosted: 19:31 - 16 Feb 2018    Post subject: Reply with quote
chris-red wrote:
ThatDippyTwat wrote:
Twist wire neatly.
Don't twist them, you get a better join if you just overlap them. Twisting them means the solder will not get into the middle.
If you want bomb-proof, do a linemans splice. If the cable moves a lot (it's on the bars, etc) then I use it. Overkill for anything else really.
Pre-tin, 90 degree bend with equal tension, 3-4 wraps on each end, solder the whole shebang.
cb1rocket
PostPosted: 23:46 - 16 Feb 2018    Post subject: Reply with quote
Any photos on the bomb proof soldering?
MCN
PostPosted: 11:34 - 17 Feb 2018    Post subject: Reply with quote
https://www.youtube.com/watch?v=rZoTzYhLHkw
It's inaccurate as he calls Solder Sawder. (Twaaaats)
ThatDippyTwat
PostPosted: 12:21 - 17 Feb 2018    Post subject: Reply with quote
This is a decent enough example. It's the proper way to do it. Some people/tutorials miss the initial hook out, which is important.
https://www.youtube.com/watch?v=O-ymw7d_nYo
PostPosted: 12:51 - 17 Feb 2018    Post subject: Reply with quote
Melty insulation though.
ThatDippyTwat
PostPosted: 13:28 - 17 Feb 2018    Post subject: Reply with quote
I'd personally heat-shrink it afterwards, fuck NASA standards.
MCN
PostPosted: 06:17 - 18 Feb 2018    Post subject: Reply with quote
She reminds me of an Asian Nicholas Sturgeon with her Alex Salmond-esque puncturing with her head.
https://www.theguardian.com/politics/2017/may/14/sturgeon-independent-scotland-may-need-phased-return-to-eu
And what an ugly fukin' joint too.
Codemonkey
PostPosted: 20:51 - 19 Feb 2018    Post subject: Reply with quote
Try solder sleeves. Easy to use, results in a strain-relief'd waterproof soldered connection. I think the RayChem ones are the originals, and they were avionic spec so no problems with vibration etc.
This video shows how easy it is:
https://www.youtube.com/watch?v=24FjjIVpk9U
Test Passed 10/05/2011 Current bike: XJ6-N
Speedy23
PostPosted: 19:21 - 21 Feb 2018    Post subject: Posilock connectors Reply with quote
grr666 wrote:
I use these. And they are reusable. I've had my Parrot kit in and out of about 6 different vehicles. I leave one of these
on the end of each of the main power wires. Pricey but worth it. Robust, easy to use. I got a mixed box in Maplins a long
time ago, I'm deeply aggrieved if I have to leave one in a vehicle, they are easily as strong as an unbroken wire so movement
isn't an issue, Where I've needed a more watertight connection then a bit a dot of clear silicone in the ends first then heatshrink
over the top has done the job, most recently fitting the Stebel Nautilus to the Sprinter, just behind the grille, so watertight was
important. Also completely idiot proof requiring no more skill than it takes to unscrew a lid and put it back on again which
I find very handy.
https://www.posi-products.com/posilock.html
Heres some on Ebay.
https://www.ebay.co.uk/itm/POSI-LOCK-PL1416-Connectors/222691295736?hash=item33d96f81f8:m:m4W1_hpARvy-06o-XD6rwiQ
How many do you get in the packet?
The last post was made 6 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.68 - MySQL Queries: 17 - Page Size: 65.67 Kb
