ER6-F battery problems
Jt19912
PostPosted: 21:01 - 21 Feb 2018    Post subject: ER6-F battery problems Reply with quote
Wondering if any could help with a problem am having with a 07 plate er6-f.
I have fit 2 new battery in the space of a year, I have checked the batterys and found out that the batterys have no acid in them. I have topped them up with some more distilled water and put it on a slow charge.
Anyway managed to get the bike started again and checked the charging rate its at 15 volts, Now I know that is too much and should be about 13-14 volts. Should these bike run at this? Or could it be another problem?
Thanks
Ed Case
PostPosted: 21:51 - 21 Feb 2018    Post subject: Reply with quote
Sounds like your Rectifier/Regulator has 'thrown the towel in', it's not regulating and the battery is being boiled !.
sickpup
Old Timer
PostPosted: 13:23 - 22 Feb 2018    Post subject: Re: ER6-F battery problems Reply with quote
How have you checked, they use a YTX9 or 12-BS battery which is sealed?
PostPosted: 13:55 - 22 Feb 2018    Post subject: Re: ER6-F battery problems Reply with quote
Levered the filling cover off I expect, unless it blew off Laughing
Triumph Trophy Launch Edition
PostPosted: 14:17 - 22 Feb 2018    Post subject: Reply with quote
A lot of bikes use 'AGM' batteries these days (Absorbed glass mat) which have no 'acid' in as such. But it does sound like your regulator rectifier is on the blink.
Chris45
PostPosted: 15:49 - 22 Feb 2018    Post subject: Reply with quote
Should be charging at 14.5v - no more, so it does sound as if your RR has been slowly frying the batteries. I know +0.5 v doesn't sound much but over an extended period it's definately enough to knacker a fresh battery.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
sickpup
Old Timer
PostPosted: 19:07 - 22 Feb 2018    Post subject: Reply with quote
Marjay worked it out. Once you fill them the glass matt absorbs and holds the acid.
It may be an old wet cell battery but may not which is why its relevant. The Reg/Rec on the ER-6 lasts at most 40k na d generally fails within 10k. It is a service item.
Ed Case
PostPosted: 21:46 - 22 Feb 2018    Post subject: Reply with quote
Rec/reg Kawasaki part number 210660705 £113.60 (Cradley Kawa) or off net a pattern one £98.00.
Jt19912
PostPosted: 20:22 - 23 Feb 2018    Post subject: Reply with quote
Thanks, and yh I pulled the seal off to refill it Rolling Eyes . Had the battery tested and it is all good so going to put a Rectifier
The last post was made 6 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.42 - MySQL Queries: 17 - Page Size: 61.52 Kb
