Honda Hornet 600 2009 Lost some of it's "oomph"
Proc
PostPosted: 10:50 - 12 Mar 2018    Post subject: Honda Hornet 600 2009 Lost some of it's "oomph" Reply with quote
Hi all,
I have a 2009 Honda Hornet 600 and I love it. However, recently I've noticed the following:
-It used to pull like crazy and get to 125mph easily. Now, anywhere over 100mph (i.e. third/fourth/fifth gear etc) it's lost a lot of its pulling power and is a fight to get to 110mph
-Up to 90mph feels strong (first/second gear) but it's definitely lost some of its "kick" in these gears. I don't feel like I have to worry about the front wheel picking up when I accelerate hard in first and second
The bike has done approx. 20,000 miles, is in good condition, has recently had an oil change.
Does anybody have any ideas what the problem might be before I take it to a dealer?
Many thanks,
Proc
Pjay
PostPosted: 10:59 - 12 Mar 2018    Post subject: Reply with quote
Have you tried new drivers?
struan80 - I'll go first - satisfied tick 1
Pjay
PostPosted: 11:03 - 12 Mar 2018    Post subject: Reply with quote
First thing I'd check is the three things you need to get the bangs going.
Fuel, Air, Spark.
A clean airfilter - remove it for a quick test, if it runs good, job jobbed, replace.
New spark plugs - cheap and always a good thing to renew.
Fuel, check your filter isn't clogged, even a bit can mean a lot at higher revs.
PostPosted: 11:59 - 12 Mar 2018    Post subject: Reply with quote
" I don't feel like I have to worry about the front wheel picking up when I accelerate hard in first and second "
Should I worry that mine doesn't feel like that either (2007 FA& Hornet)? I thought that mine felt healthy but have nothing to compare against with it being my first bike. I must let a friend ride it who's ridden more than I have.
Maybe I'm just riding it like a wuss though.
andys675
PostPosted: 12:08 - 12 Mar 2018    Post subject: Reply with quote
Fuel, Air, Spark.
this, there is nothing wrong with a cheap hiflo airfilter if genuine pricey, plugs can be had cheap on ebay just buy from someone you know like m&P or demontweeks, and check there isn't both a fuel filter inside and outside the fuel tank?
Proc
PostPosted: 14:13 - 12 Mar 2018    Post subject: Reply with quote
@Pjay; thanks a lot for the comprehensive response. I'll check the air filters and fuel filters this evening and failing that I'll go onto spark plugs.
@garybee; I definitely could get the front wheel to float under hard acceleration in first/second gears. It's certainly lost some of its kick
@andys675; thank you for the advice. I'll bear that in mind if the problem is the filter.
I'll keep you updated in case you're interested to hear the outcome Smile
Thanks again
andys675
PostPosted: 11:37 - 17 Mar 2018    Post subject: Reply with quote
well?
kramdra
PostPosted: 13:49 - 17 Mar 2018    Post subject: Reply with quote
Do a compression test.
9 year old bike that has only done 20k? Unlikely anything is clogged but perhaps disintegrated with age if original.
As it is under used, would also check if brakes are binding. Drain the tank and try fresh fuel.
temeluchus
PostPosted: 15:24 - 17 Mar 2018    Post subject: Reply with quote
the two most likely causes will be binding brakes and a dirty air fulter.
The last post was made 6 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.16 - MySQL Queries: 17 - Page Size: 61.26 Kb
